Question about HP Officejet Pro 850 InkJet Printer
I have an HP all in one 8500 pro series printer. it's only 3 months old. I cannot get it to print black ink anymore. I have cleaned the printheads and checked the ink. Even put in a new cartrige, but no luck. What am I missing?
  • 4,041 Answers
Hi .
It still looks to me as it is blocked some where so I would try.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 02, 2010
Hp officejet pro blank pages with full ink cartridges.
Try reinstalling all of the printer software. If that does not do it then something is wrong with the printhead itself, specifically the area that controls the flow and metering of the black ink.
Aug 03, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
I recently changed my carriage belt.The print quality has ever been so bad.Does not print clear lines,especially with the black ink.Always have some white lines within...Thank you. Nima
The printhead for black ink cartridge could be blocked.
It is better to run the Clean Printhead operation on your printers tools option.
You can manually clean the print head so that next time when you execute the Clean Printhead from HP solution center it will be successful.
First, remove the printheads.
then, pull up the lever at the top of the cartridge holder, this releases the print head.
The print head could be blocked, most common is the dried ink blocking the small holes in the print head.
Washed it in running tap water. It is best if you soak it in a mixture of water and ammonia and leave it overnight.
After soaking, you can spray it with canned air and blow those little holes to unclog it. Once it dry, return the print head and the ink cartridges and performed the alignment.
this video will show you how
May 25, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Office jet pro 8500 alignment failed error message -black ink intermittently fails.
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Apr 10, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
It's hard to believe this story is true, but I assure you it is all true. 1- In October 2009 we purchased an HP Officejet Pro 8500. Not long after installing it we got constant messages "Printer is...
1 you said the cartridge is low.
it happens because the ink cartridge must have been used for initializing the printer which does take a lot of ink. please purchase a new cartridge and the issue will be resolved.
2 Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.
NOTE: If error messages also display on the computer, clear the error messages after each of the following steps. You might have to delete pending print jobs from the print queue on the computer to clear the error messages. Solution : Clean the electrical contacts Follow these steps to clean the electrical contacts on the printhead and inside the product. CAUTION: Follow these steps carefully to avoid damaging the sensitive electrical components. Step one: Clean the contacts on the printhead Follow these steps to clean the contacts on the printhead. NOTE: The ink nozzles on the printheads might clog if you expose them to air for more than a few minutes. The ink nozzles also might clog if you do not use the product for long periods of time.
  1. Make sure that the product is turned on.
  2. Open the top cover of the product.
  3. Press and hold the OK button for five seconds. The carriage moves to the left side of the product. Release the OK button. CAUTION: Proceed only if the carriage is on the left side of the product. If it is not, the printheads will be damaged when you install them. If the carriage does not move over, try turning the product off and on again
  4. Wait until the carriage is idle and silent.
  5. Unplug the product power cord from the electrical outlet. NOTE: Do not turn the product off by pressing the Power button (c01602202.gif ). This causes the carriage to move out of reach.
  6. Lift the printhead latch. Figure 1: Lift the printhead latch c01817489.jpg
  7. Lift the handle on the printhead that the error message indicates is missing or damaged, and then pull the printhead out of its slot. Figure 2: Lift the handle to remove the printheadc02548320.gif
  8. Use a dry, soft, lint-free cloth to remove any ink from the electrical contacts on the printhead. CAUTION: Wipe only the electrical contacts. Wiping the ink nozzles, located on the underside of the printhead, can damage the printhead. Do not touch the nozzles. Doing so permanently damages the ink nozzles, and the ink stains clothing. Figure 3: Electrical contacts and ink nozzles c01817491.jpg 1 - Electrical contacts 2 - Ink nozzles
  9. Wipe the electrical contacts with the swab until no ink residue remains.
  10. Wipe the electrical contacts with a fresh cloth to dry them and remove lint.
  11. After the electrical contacts on the printhead are clean and dry, place the printhead on a sheet of paper or a paper towel. Make sure that the ink nozzles face up and do not touch the paper.
Step two: Clean the contacts inside the product Follow these steps to clean the contacts inside the product.
  1. Use a fresh, dry, soft, lint-free cloth to clean the electrical contacts inside the product. Figure 4: Clean the electrical contacts inside the product c01817492.jpg
  2. Allow at least five minutes for the contacts to dry. Check the contacts for lint or debris, and then dry or clean the contacts again if needed.
Dec 26, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How do I clean the printhead or do I need to clean the printhead
Only clean the print head when you are have ink issues. And you do so with a cotton swab and alcohol on the gold etchings on the print head only.
Nov 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Apr 10, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
HP Officejet Pro 850 InkJet Printer Logo
147 people viewed this question
Seeker5211
Seeker5211
