Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Lynksys BEFSR41 hookup
Need help hooking up my router
  • 37 Answers
To hook up your lynksys router plug your internet connection wire in the back of the router where it says linksys then run another cable from the slot one to your computer, when you first get your router your username and password will be admin type your IP address into your internets browser window and use your username and password to log onto your linksys router, choose your router settings and there you have it,
Good luck
Chris
Posted on Feb 27, 2008
I set up my lynksys befsr41 ver4.1 using the set up disk. I hit enter at the password window and it goes to analyzing my computer. Then the password window shows up again etc. etc. etc. At the lower left I...
Are you trying to install the router.
You can do it manually without the CD.
First reset the router for 30 seconds. unplug the power to the router. wait for 5 seconds. Plug it back in.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 14, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I have a BEFSR41 v2 router. Can I hook my laptop to it wirelessly?
Unfortunately this router is NOT wireless capable
but this type of Router allows you to share resources such as
computers, printers and files. A variety of security features
help to protect your data and your privacy while online.
Oct 23, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Motorola sbvs220
Make sure that your router and computer are set to get their IP addresses via DHCP.
Either the router is not setup as DHCP server or your computer has a static IP address assigned which conflicts with the router settings.
Do you have cable or DSL service (in which case the router should be set to PPPoE)?
If you have cable service, just reset the router to factory default by pressing the reset button on the back for about 30 seconds.
Then go to your computer and
  1. Go to Control Panel -> Network Connections.
  2. Right-click your Local Area Connection and choose Properties.
  3. Scroll down and double click on Internet Protocol (TCP/IP).
  4. Make sure that all settings are set to Obtain ...automatically.
Click OK two times (the second time takes a little bit longer, because the settings are applied.
If you have any more questions or need help with the settings, just come back here and leave a comment - I'm happy to help.
May 29, 2009 | Motorola Computers & Internet
Where does the phone line go in the lynksys box.
Phone Line?
You need a cable or dsl modem to connect to the internet. From the modem you run an ethernet cable to the "broadband" or "Internet" port of your router.
Also make sure your lynksys is a router, not a switch
Hope this helps
Cor
Dec 31, 2008 | Linksys EtherFast 10/100 16-Port Workgroup...
Slow load speeds
Yes, when your router gets old it really get slow, you can try to load a updated firmware to this router and that should help for this concern, You can also contact Linksys tech support for further help this is the number 800-3267114.
Hope that helps........
Aug 23, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Blinky...
the solution buy another router you you can use other cp
Apr 14, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Lynksys is causing high blood pressure
Hello cyndilynn
OK, my friend, don't fret. Let's find out what the skinny is. First things first...
(01) Do you have the manual for your router?
If not, you can download it from HERE.
(02) Do I understand you correctly that you are able to connect to the Internet from one of your computers and not the other WHILE using the Linksys BEFSR41 router?
Some points to clarify:
(A) Your Linksys router (connected between your cable or DSL modem and your computer(s)) and your Linksys NIC (installed in your computer) are two different animals that serve different purposes.
(B) Your router should be connected to each of your computers via "straight through" (not "cross-over") Ethernet patch cables that run from the LAN ports at the back of your router to a NIC connection on each of your computers.
(C) The NIC and the ROUTER do not have to be made by the same manufacturer (in this case Linksys). Manufacturer's NICs and ROUTERs can be mixed and matched just fine.
I suspect the issue is w/ detection of your NIC on one of your computers. I doubt the issue has anything to do w/ your router.
If that is the case, please, provide details about the two desktop computers that you have tried the Linksys NIC in (one successfully, one unsuccessfully).
(03) What operating system is each computer running?
(04) Has the computer that you have been unsuccessfull connecting to the Internet through the Linksys router ever been successfully connected to the Internet?
For now, please, answer these 4 questions and provide any other information you can think of (the more details the better). Then we'll move on to the next step.
Thank you
BJ
Apr 04, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Cisco & Lynksys befsr81 linksys router
Connect a pc to port 2 on the befsr41. Push the reset button for 30 seconds, unplug the power for 10 seconds. Check pc ip address, it should be 192.168.1.xx. If that is the ip address, the router is working.
Mar 11, 2008 | Computers & Internet
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
224 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
