Question about Panasonic TH-42PZ700U 42 in. Plasma Television
Panasonic th-42pz70 tv, need the remote control
Panasonic th-42pz70 tv, need the tv remote control code to set up a Humax freesat remote to cover basic actions of the tv.
Can any one help?
Paul
SOURCE: Panasonic TH-50PX60U no buttons working
The software in the cpu of this set is damaged you must reload it to fix the problem..
Posted on Dec 18, 2008
SkyGuy08
  • 27 Answers
SOURCE: remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Posted on Apr 08, 2009
SOURCE: trying to find comcast digital code to use their
10250
Posted on Jun 16, 2009
  • 909 Answers
SOURCE: sony remote control codes to operate TH-37PX8B
Can't be done, the buttons for the tv functions are only for sony tv's. Sorry.
Posted on Jul 13, 2009
gopakumarg43
  • 74251 Answers
SOURCE: need a four digit code
Hello
Four digit universal remote codes for Panasonic TV are:
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Posted on Mar 27, 2011
My humax freesat model hdr-1000s remote control is not working with the box
If this is brand new call the company support number ASAP. It could be something simple you're doing wrong or it could be a defective remote that needs to be replaced under warranty but you MUST call ASAP to be sure to get the problem in the records before the unit is out of warranty.
Oct 12, 2014 | Televison & Video
Why can i only get radio stations from our humax freesat and not tv channels
There is a button on the remote labelled 'TV/Radio' which was probably knocked when the remote was dropped.
Sep 15, 2014 | Humax Televison & Video
Freesat oneforall
Check whether it has setup codes to Humax Freesat. If you wish to get more details, check these sites. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 30, 2013 | One For All URC 7740 Remote Control
Remote tv codes for humax rm-f01 freesat box remote
http://www.humaxdigital.com/global/support/rcucodelist.asp
this website has a few lists you can look at to try to find the code you need to use your remote.
Aug 19, 2011 | Samsung Televison & Video
I want to use my tevion remote to operate humax freesat box? i dont know how to use it
You will need the correct set up code to link the remote to the freesat box.
try this website http://www.xdiv.com/remotes/
Feb 18, 2011 | Televison & Video
Setting humax foxsat hdr remote to control panasonic tx32lxd60 tv
Had the same problem with my panasonic - it would appear that none of the codes will actually turn the TV off because they need a longer signal to turn off. I eventually found that code 0650 works for mine - input the code as instructed in the manual and then selected OK - holding down the standby button on the humax controller then turns the TV off. Try all the codes and see which gives most control functions. Hope this helps.
Jan 01, 2009 | RCA 3-Device Universal Remote with...
Panasonic TH-42PZ700U 42 in. Plasma Television Logo
266 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
