Question about Cycling
2003 Honda NPS50 Ruckus scooter Here's my situation: around last April my scooter began to feel like it was running a little sluggish and didn't sound right. Unfortunately, I knew very little about scooters and maintenance and like an idiot I assumed adding more oil would help. I now know Ruckus' don't really burn any oil and rarely need oil just added. After that, a seal in the same casing as the kick start blew. A friend who is a mechanic replaced it and it seemed fine for a short while. Soon after the engine start making a knocking sound / grinding sound and has hardly any powe
  • 169 Answers
Hello! Well, I think you have actually diagnosed your own problem. By overfilling the crankcase with oil - you very well may have just fouled the spark plug. This is best case scenario, to be honest. A very very common reason that scooter owners will experience a loss of power is due to oil over-filling.
Worst case scenario is that due to the overfilling, the oil began to cavitate, or foam, and as a result did not protect the internal parts properly and they have become damaged. The sound you described is likely (I hope that I'm wrong for your sake) internal damage that is going to result in engine replacement.
I would recommend draining the oil, refilling it to the suggested level (in your case is 0.6 Liters), and also removing the spark plug and cleaning/replacing. If this doesn't work, I'm afraid that further internal inspection will be needed, and at that point you're talking about the very high possibility of engine rebuilding/replacement.
I hope this helps and wish you all the luck. Thanks for using FixYa!
-KCGTODAD
Posted on Feb 02, 2010
    Genius:
  • 1,341 Answers
That does not sound very good and I would suggest you have it checked before you cause any damage.Start with a compression test and see what happens.
  • heeman mohun Feb 02, 2010
    Loss of power may be caused by damaged to the combustion chamber,hence i suggest you start with a compression test.
My o3 Ruckus only runs with the carb drain open,,, why is that??? please help
Hi, Bryce and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
8. Damaged petcock diaphragm allowing fuel to flow through the vacuum line into the combustion chamber.
9. Contaminated fuel tank.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Carb overflow is pouring out gas
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
Honda 2003 NPS50 Ruckus Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda NPS50 RUCKUS 2009 Owner Manual
Jul 03, 2017 | 2007 Honda Ruckus
I have a 2009 honda ruckus scooter mod nps50/s very hard starting with out using eather i'm 86 yrs old & would pay some one to help me out thanks eddy
hi eddy. get a can of seafoam fuel treatment from your local walmart or napa auto store and add some to your fuel. read the directions and dont add to much. it will clean your crab out slow but sure. good luck
May 15, 2017 | Miscellaneous
Starts and runs but will only go 25 top end and 10 going up a hill. I cleaned carb, and changed plug. Filter good. Any help about how what to try next?
Dennis, Write up found in scooter guide.net link below.This scooter was restricted to 25mph via a series of restrictions to the variator, ECU, intake and camshaft. 2009 was the last model year for this CHF50 in Canada and the USA, although this scooter was available for a few years after this due to excess inventory from the 2009 crash of the scooter market.
You can have it modified at a shop probably $$.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.motorscooterguide.net/Honda/Metropolitan/Metropolitan.html
honda metropolitan top speed test run
Honda Metropolitan Jazz Ruckus Resource page
The Fastest Upgrades for Metropolitan Scooter eHow
Apr 25, 2016 | Motorcycles
Hi I've got a honda dylan ses 125 scooter now it won't start it made to big bangs out of the exhaust whist starting the bike then just started to dye down to a ticking noise there a brand new battery
2003 Honda Dylan SES 125 Scooter Engine ebay - YouTube
? 0:47
https://www.youtube.com/watch?v=DzAByfS2OAY
Nov 21, 2012 - Uploaded by TheShamefulsin
Short video demonstrating a 2003 honda dylans engine, that it starts and runs for the purpose of selling the ..
honda dylan in United Kingdom ' Motorbikes & Scooters for ...
https://www.gumtree.com/motorbikes-scooters/uk/honda+dylan
GumtreeMy 2003 Honda Dylan ses 125, unfortunately it was stolen from me, hence the .... uk plate GF07 XJK,bike has only few scratches, last time I could not start it, but ...
Nov 29, 2015 | Honda Motorcycles
What size after market air filter do i need for my 2007 honda ruckus nps50
on ebay are sold aftermarket supplies for a air filter, the one you need depends on the opening size you are trying to cover.
Sep 06, 2014 | Adventure Power Honda NPS50, S Ruckus...
How do you remove the rear wheel from a ice bear maddog scooter ?
Hi, Anonymous the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Aug 30, 2014 | 2011 Honda Ruckus
My Honda Met.2 Chf50 runs great with handkerchief on intake of carb but when you attach breather quits
Hi, Monte the two wires are probably for the electric auto choke for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Troubleshooting
Carburetor Tear Down And Cleaning 2005 Honda Metropolitan CHF50 Scooter
Honda CHF50 2007 Metropolitan Owner Manual
Jun 11, 2017 | 2005 Honda Metropolitan Base
How do I replace the voltage regulator in a Honda RUckus?
Hi, Cp62214 for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://totalruckus.com/phpBB3/viewtopic.php?f=13&t=42490
How to wire GY6 scooter regulator rectifier and how it all works Part 3...
Honda NPS50 RUCKUS 2003 Service Manual
Honda 2015 Ruckus NPS50 Owner Manual
Jun 05, 2012 | 2008 Honda Ruckus
Cycling Logo
81 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
