Question about Refrigerators
Water collects under the crispers. I con't tell
Water collects under the crispers. I can't tell where it comes from. Occasionally water comes out under the bottom also. I looked at the back of the box at what I assume is a drain from the freezer and it has some gunk in it but I don't know how to clean it out.
  • Refrigerators Master
  • 8,220 Answers
Use a wet dry shop vac
Posted on Feb 02, 2010
Water collects under crispers in wood's all frig
The drain is plugged. My preferred method to clear it would be to use compressed air. Even the type of canned air you'd blow off your computer keyboard with might work (just tape around the nozzle until it fits tight to the drain under the crisper bins). If you don't have that, try fishing a wire from the top, but be careful not to cut open the drain hose.
Jul 10, 2017 | Refrigerators
Water appearing on glass above crispers and onto the floor under the crispers. Happens only occasionally. No obvious source of leak. Back of fridge wall not wet.
Do you have a cooling plate at the rear or the fridge with a narrow tray at the bottom to collect the defrost water? Check the drain hole for obstruction.
Apr 08, 2016 | Refrigerators
There is water collecting continuously at the bottom of my fridge under the crispers. Do you know how I can fix?
Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
Jan 03, 2015 | Refrigerators
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
Water collecting under crispers
Probably a plugged drain.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the refrigerator side as well.
Good Luck,
Gilsh
Nov 28, 2009 | Electrolux Refrigerators
Large amount of water collecting inside refrigerator
water drainage passage and pipe is blocked stop the refrigerator and clean the pipe
Sep 08, 2009 | Whirlpool Refrigerators
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Water collecting under the crispers
Defective thermostate switches off the compressor and then switches on the compressor before time. Please replace the thermostate to solve this problem. There is no defect with the compressor or there is no refrigerent leak too since you have good cooling. Only it require replacement of thermostate.
Jul 06, 2009 | Refrigerators
Water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Teacuptess my GE top freezer Refrigerator has water under Crisper
Could be but more than likely the drain is clogged. Open fridge door look at the top back to see if you can see water running down back of liner.
Jun 06, 2009 | Refrigerators
Refrigerators Logo
153 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
