Question about Gigabyte MA785GM-US2H Motherboard w/ AMD Phenom II X4 965 CPU Bundle (MA785GMUS2HPII965BUNDLE)
I need to install a floppy disk drive what's the
I need to install a floppy disk drive what's the best way to go i.e. internal connection type? etc.
  • 415 Answers
Instead of opening the computer case, and installing a floppy drive, I would suggest buying a floppy drive with a usb adapter.
No technicals are required and are just plug and play. All you need is an available usb port. However please note that this type is slightly more expensive.
Posted on Feb 02, 2010
How to connect 34pin floppy emulator for 24 pin floppy driver?
best to buy a floppy disk drive with direct USB cable to avoid all these problems and is recognised by PC for booting etc. No emulation required.
Oct 06, 2014 | Computers & Internet
Where is Floppy Disc Drive A located on the PC?
This notebook does not have a floppy Disc drive, the CD or DVD drive performs the sme function
Jan 04, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have panasonic floppy disk drive type JU-257A727P its green light is lit continously
The ribbon-cable connecting to the motherboard is "backward".
Swap the cable end-for-end, and reconnect it to the motherboard.
Dec 10, 2010 | Panasonic (JU257A607P) (JU257A607P)...
NOT APPEARING IN MY COMPUTER
If the Floppy Drive is not appearing in my Computer, open the PC and check that the cables are connected to the drive properly.
Also open Device Manager and check under Floppy Disk Drives that the drive actually appears there.
Aug 30, 2010 | NEC FD1231M 144MB 35" Internal Floppy Disk...
I am now unable to access a floppy disk that I had been able to access for years. I now get an error message that tells me the disk has no ID address mark. How do I fix this?
Try changing the stting switch on the disk. I think it is for formatting or something like that. Try moving it to the opposite direction and then put it in your computer again ;) Good Luck
Nov 12, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Bought this New Dell Internal / External USB Floppy Drive 1.44Mb
Hello there
you will need to check the way the device reads the disk if may have changed if you tried using a ordinary dvd then went a dvd/r some times you need to change the settings back to the way it was when you installed it ok
best regards mike
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
Memorex external usb floppy disk-drive does not appear or functio
As I understand it the computer recognizes the floppy drive.
Can you read other discs, write to them etc? If not drive is bad
If you can read other discs then your floppy disk is bad
Jan 23, 2009 | Memorex Computers & Internet
FA404M installation
The internal USB cord is made for the memory cards, install the floppy ribbon for the floppy disk. Don't forget to attach the power also.
Sep 01, 2007 | Mitsumi (FA404MBLACK) (fa404m/black)...
3.5 Floppy drive
Hi, i have installed thousands of Internal Floppy drives and there aint no conflicts between win/95/98/me and xp. all discs should be compatible, unless you took it from a apple machine for example. did it work when you put in a new floppy drive? all the best John
Feb 21, 2007 | Teac Floppy Drive 235HF Internal Floppy...
Gigabyte MA785GM-US2H Motherboard w/ AMD Phenom II X4 965 CPU Bundle (MA785GMUS2HPII965BUNDLE) Logo
46 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
