Question about Asko D3251HDSS Stainless Steel Built-in Dishwasher
I have an ASKO D3251 that is not draining. We
I have an ASKO D3251 that is not draining. We checked the trap: nothing. The heavy Pots/Pan light flashes and then it stops .
  • Anonymous Mar 31, 2014
    When pots and pan light and heavy duty light symbols are flashing together what is the problem
  • jeff specer
    jeff specer Aug 08, 2014
    You will need to remove the bottom panel of the unit below the door that exposess the motor and the electrical along with water hook up. Now you will nee to manually go through the cylces (or let the machine cycle) to rinse. Once in the rinse cycle you should have heard the selinoid activate to drain the water. This selinoid click and pulls an arm down when in drain mode if you are looking under the unit you will either hear it or see this activate. If not then the selinoid is out, if you hear it activat then you need to look at the back of the motor to see if the motor itself is turning. You should be able to see the fins on the back of the motor turn once it goes into drain cycle. If you do not see the motor fins turning (you have to look through the vent slots located on the back of the motor) you acan take a small slotted head screwdriver and with the power off, you can insert this screwdriver into the vent holes in the back of the motor to spin (or move) the motor fins. If they do not move freely then the motor itself is froze up in that case a new one is needed. If the spin then try your drain cycle again since you may have unfroze the drain motor. Good luck hope this helped
  • 534 Answers
Dave
Posted on Feb 02, 2010
Start light flashing. Dishwasher wont start
I'm guessing as you did not list the model number. Something similar happened on mine. Due to a freeze, there was a small crack in the inlet and water had slowly leaked. As a safety feature, the Asko has a tray under the dishwasher inside the overall dimensions. It has a float. When the float rises, the drain pump starts and the dishwasher will not start. In my case, the drip pan is not connected to the drain which gave me the drain sound, but did nothing to remove the leaky water.
I suggest you take the front bottom panel off the dishwasher and check for water/leaks.
Oct 29, 2014 | Asko 24 in. D3121XL Free-standing...
I have an asko d3251 dishwasher that won't stop running. The device in the drain that spins won't stop. I had to shut the power off to the unit.
Our unit had leaking connection on outlet side of fill solenoid valve. Any leak will cause water to accumulate in base pan. there is a float switch in base pan as a safety mechanism when water is in pan it causes a styrofoam float to rise and make contact with switch. This tells machine there is a leak creates error code to run pump continuously until water is removed from base. Disconnet electric from unit first. you must pull dishwasher out to get at back panel. Remove lower back panel to get access to mechanicals of unit. Once you remove panel you should see water in pan. If you see water that is most likely same issue we had. soak up excess water or tilt unit to drain water out of pan. once water is gone unit should start normally. If you look underneath while unit starts up - don't touch anything while unit is connected to electricity! You should notice where water is coming from. Our unit leaked at hose connection from outlet side of solenoid fill valve. connector is a plastic cam-lock fitting with a flow sensor integrated into it. there is an o-ring between the two parts. it comes apart with a very small amount of counter-clockwise motion. perhaps only five or ten degrees of indexing and it falls right off. it is a very flimsy connection for the main water line. the o-ring on our unit Was slightly deformed and not seated correctly. could have been from original installers 4 years earlier! Asko needs to re-design this part. I replaced o-ring and unit is working again however I do not trust that this fitting will hold up over time. Very poor design in my opinion. Other design flaw I noticed while looking at mechanicals is circulating pump isolation mount is not in correct location for pump motor. rubber mount is stressed to the point of almost tearing off! No way for me to correct this since location of mount does not match position of motor. We will not replace this unit with another ASKO when it goes.
Jan 19, 2013 | Asko D3251HDSS Stainless Steel Built-in...
Hi, I have an ASKO D3250 dishwasher and it keeps stopping during the wash cycle and flashing the heavy pots and pots symbol simultaneously. I tried cleaning the filter basket and found a little plastic...
The part is a cap for the drain pump. You can put it back into position by removing the filters and placing it to the left of where the circular filter would be positioned. The part goes in with the part numbers on the bottom facing down. When positioned it should not interfere with the threads for the circular filter. You may have to scoop out the water in the bottom, to have a better look at how it is positioned. It is always normal to have a little bit of water in the bottom filter area (below the silver screen filter).
Oct 18, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
Our Asko D3112 was not draining, so we had maintenance drain the hoses to clear any blockage but it did nothing. They said it must be our pump not working. I ran one more cycle to see if things went back...
Check your manual to see if you have a drain pan at the bottom of the unit, and a 'float' that checks for water collecting there. On at least some Asko models, water collecting in the pan causes the float to rise, which then changes the operation of the dishwasher. Once that float switch turns on, the diskwasher will always run the drain pump whenever power is applied.
If this is the case for your machine, remove the kick panel. There likely is another panel behind that which covers the 'internals', including the drain pan area. You'll have to remove all of the water in the pan, and that will lower the float and return the controller to normal operation. THen you will have to diagnose the cause of the water collecting in the pan.
Another possibility is damage to the float such that it has turned on it's switch despite no water collecting in the drain pan. I've heard that in some cases a mouse will chew on the float and damage it, causing such machine operation.
In another thread, I posted my solutions to one cause of water collecting in the drain pan. In that case the drain pump was no longer reliably moving water out of the sump area inside the dishwasher. I had thought it was the manual dial control on my d1706 unit, until I learned that the dishwasher has this 'special' drain pan mode.
Jul 07, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
I have a asko d3120 and it's only draining water and will not start or stop draining :( what can i do?
check the float switch under the pan .. you could have water in the pan or float stuck in the up postion...
Hope it helps if NOT let me know more about your problem... and I will help
Jun 08, 2009 | Asko 24 in. D3120 Dishwasher
ASKO D3251 flashing error message; drain gurgling, power off
You most likely have a leaking bottom spray arm. The water is in the pan under your unit. It requires dealer service. If you are still in your 3-year warranty, good; otherwise be prepared to put out hundreds of dollars. I'm going though this now for a second time on my $1600 D3251. Asko did grant a one-time extension on my warranty since it expired a month ago. In 6 months when it breaks again, I'll buy a Bosch. I also had this same problem on a previous Asko. I can't get more than 3 years out of these units, so this is my last Asko. When it breaks again, I'll go with Bosch. Good Luck.
Mar 17, 2009 | Asko D3251HDSS Stainless Steel Built-in...
Machine wont drain and the door wont open
The solution worked thank you, drained machine and cleaned out trap as per chapter 10 of user manual and all working fine now. Note: ensure to check up the inlet line in the trap with your finger as there could be some items in there, also check fan/prop to ensure it turns freely. Was amazed of what I found in the trap see picture below, pays to check pockets prior to washing.
Jan 20, 2008 | Asko W6221 Front Load Washer
Front drain plug
I have similar issues with my Asko W660. Once it was a key stuck between the inlet to the pin trap and the trap itself. I got it out by jiggling and poking into the trap area with a narrow strip of plastic. Mostly, though, it just requires a stronger grip on the door to the pin trap--the little handle is slippery, and hard to get a good grip on. Try making a grip out of a piece of duct tape, or grabbing the handle with pliers.
Jan 05, 2008 | Asko W6021 Front Load Washer
Asko 1805 Frozen
Sounds like the controlunit is bad.
Jan 01, 2008 | Asko 24 in. 1805 Built-in Dishwasher
Asko D3251HDSS Stainless Steel Built-in Dishwasher Logo
948 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
