No sound on VCR
I have an older model RCA VCR - model #VR617HF. It records and will play and display picture but I have no sound. When I take the tape out and use it in a different VCR it has sound and picture. How can I solve this problem so I have sound when I play a tape?
  • 4,402 Answers
If you get sound from anther recorder that tells me that the head on the current vcr is working, which leaves just the output, if using a antenna switch to channel 4 if using 3 (theres a little switch in the back) if you are using 4 change to 3, if your using audio output cables swap them with a good working pair.
if all is good it would require service (unless the mute is pushed)
good luck
please mark the post with a fixya
Posted on Feb 19, 2008
My vcr plays commercially-recorded tapes fine, but tapes recorded on it or another VCR play with the sound distorted. The picture seems fine.
Sounds like its mechanism need some alignment. Guide pole alignment. Contact any service technician. This is technically skilled work.
Jul 18, 2015 | Panasonic Televison & Video
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
Vcr hooked up, no audio
From the VCR to the tv if you have RCA cables its kind of hit and miss where the audio cord goes. Only one of the jacks are for sound but it has to be plugged in to the right input. Audio is usually the white one. Just keep touching it to inputs until you hear sound start to come out of the speakers. Hope it helps.
Jun 27, 2009 | Insignia Digital-to-Analog Converter for...
Blank VHS tapes work; Movie VHS tapes don't
Hello statman_4
I have an important question; Are you watching a VHS tape you recorded of another VHS movie? In other words did You rent Ben Hur and record it and then tried to watch the recording? If you did that's your problem. VCRs in the late 1990's (1997-1999) began to employ MacroVision circuitry in all VCRs, and DTR. MacroVision Circuitry makes the VCR record tapes with MacroVision in such a way that the horizontal and vertical sync pulses are not at the proper amplitude, and the AGC (Automatic Gain Control) is tricked into over compensating thus creating the scrambled picture. There is a way around this. You need to buy a video stabilizer SIMA makes such devices and some other companies do to. You feed the signal from your VCR into the unit and it corrects the video image by readjusting the video signal.
I hope this helps,
Thank you,
Mar 25, 2009 | RCA Televison & Video
Vcr sound but no picture
After checking the connection, played a pre-recorded tape and the picture was displayed gradually. After about 5 mins picture was completly restored. Lost of picture was due to dirty tape heads.
Mar 22, 2009 | Panasonic TH37PX60 37 in. Plasma...
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
First, have you doublechecked the video hookup? It sounds like you are using the video/audio inputs to the TV, so make sure you have VCR video out cabled to TV video input, and the TV source/input selection set to that input (video 1 etc.). If this checks out, check for a dirty video head on the VCR, though a dirty head usually results in a blank or blue video display (older VCRs, snow). You could do a process of elimination by hooking VCR to a different TV and see what is displayed then. Lastly, I assume you've tried multiple tapes, just in case a home recorded tape was incorrectly recorded?
Aug 24, 2007 | Panasonic PV-7450 VCR
RCA dvd-vrc combo model DRC8320N
Jul 23, 2007 | RCA DRC8300N DVD Recorder/VCR
How do I Record?
well, seems like your vcr is attached to your tv by the antenna cable which you need to program to get it to record. but he is an easy way to record and you will get a perfect sound and picture. Well, you need an RCA cables. you either have rca cables or scart plug. either on will do the job. you need to take the audio and picture cable OUT source of your channels IN to the vcr. now, OUT of the vcr IN to your tv. on the vcr you should change the channel to either AV or LINE..then you will get sound and picture. let me know how it goes
Jan 15, 2007 | Panasonic PV-8451 VCR
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
