Question about Dishwashers
KUDS25SHWH1 Kitchenaid Dishwasher Control Panel Only CANCEL light on
If I start the diswasher, only the CANCEL light stays on, no other lights on the panel. Possible FUSE-Link ? Or the whole control panel ? I assume if the FUSE-link then no control panel lights would show.....
  • madashell1 Jun 19, 2008
    I have the same problem. Cancel light stays on. I can stop that and press some other buttoms, but then they stay on. Do I need a new control touchpad? It appears that you have to purchase the whole upper part of the door panel? Thanks for your help.
  • dglasco Aug 01, 2008
    I have the same problem. I tried shutting off the circuit breaker a bunch of times but that didn't work. Help!!!
I bought a control board for $127.00 figuring that was the problem but it wasn't. I called an appliance guy who came out and said its the touchpad that needs to be replaced. I ordered the touchpad ($325) since I already have to much invested in this dishwasher. I paid $1200 for it 8 years ago and its really a great dishwasher. My appliance confirmed that if it was the fuse-ling that you would not have any lights on.
Posted on Sep 03, 2008
  • dglasco Sep 17, 2008
    I replaced the touch-pad ($325) and that fixed it. It was not the control panel but I have a spare one in case I get some kind of electrical spike. My appliance guy replaced it within 5 minutes and only charged me $25.
I have a Kitchenaid kuds25shwh1 which doesn't start because the childlock was on. I followed all the suggestions offered and lastly turning the power off to reset. After turning the power back on a...
Getting it out of child lock can be difficult but make sure you watch the light on the front panel it will go right back to lock if your not careful.I had to try several times at first I thought it would need a doctor.. but with patience it should work and unlock with the 4 second hold.. power down does not reset unless you wait 30 minutes or longer.. hope this helps
Oct 08, 2013 | KitchenAid 24 in. KUDI01FL - Multiple...
Kitchenaid diswasher replaced control panel and dishwasher is not working again
Check the door switch, it could be a loose wire or broken door latch switch.
Feb 29, 2012 | KitchenAid KUDS01DJ - Multiple Color...
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
Aug 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Jan 13, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
Control panel cancel light blinking as well as normal and light china light cannot cancel or start dishwasher
where do i connect the upper rack water conduit tube for the kitchenaid dishwasher
Aug 16, 2009 | KitchenAid Dishwashers
Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Feb 12, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwashers Logo
1,280 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
