Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
The diverter spray worked well for a couple of weeks. Now there is little pressure. There is a sharp, water-hammer like click when I shut it off as the main faucet engages. I've opened up the diverter valve at the end of the faucet, but no noticeable build-up or blockage. What now?
  • kivatrading Feb 02, 2010
    Thanks -- I was worried it would come to that!
  • 43,501 Answers
There is some kind of dirt in there somewhere... it can be very good at hiding...
The best thing I have found to do is to take everything apart...spout, valves at handles, and hoses to valves. Blow compressed high pressure sire through every passage way and you will fix the problem. Time consuming yes, but the alternative is replacement. Teflon tape can make a mess of thing AND be hard to get out sometimes, becareful if you are using it or have used it...
Heatman101
Posted on Feb 02, 2010
Spray and single flow both running at same time on Moen single-handle kitchen faucet. How do I correct the problem ?
there is a diverter inside the faucet that works with water pressure possibly has some debris or calcium build up.turn off water supply and take out cartridge. you should see the diverter
Apr 21, 2012 | Moen Plumbing
I have water hammer when using shower only
Your Delta faucet is open and close the valve very quick. This will produce back pressure on pipes. You need an anti water hammer / back pressure suppressor to avoid this problem. You can find it in local market.
Regards
Mar 30, 2011 | Delta Faucet Delta RP17453 Pull-Down...
I installed new moen muirfield sink. It worked just great. Water flow just smooth. Then few hours later, it started making thumping sounds but when I use the spray, it stopped. But when stopping using...
That is called 'water hammer' and is usually coming from an old fashioned stop valve. The stem with the washer is bouncing up and down.
http://www.moen.ca/kitchen-bar/faucets/kitchen/muirfield/_/N-6a2Z1z141ulZ1z141o8 ]
Water hammer - Wikipedia
https://en.wikipedia.org/wiki/Water_hammer
A water hammer commonly occurs when a valve closes suddenly at an end of a pipeline system, and a pressure wave propagates in the pipe. It is also called hydraulic shock. This pressure wave can cause major problems, from noise and vibration to pipe collapse. ‎Hydraulic ram · ‎Nikolay Yegorovich Zhukovsky · ‎Surge tank
How To Stop Water Hammer - How To Fix Pipes ' HowStuffWorks
home.howstuffworks.com > ... > Home Improvement > Home DIY > Plumbing Water hammer is a specific plumbing noise, not a generic name for pipe clatter. It occurs when you shut off the water suddenly and the fast-moving water rushing through the pipe is brought to a quick halt, creating a sort of shock wave and a hammering noise.
Waterhammer - YouTube
? 2:34
https://www.youtube.com/watch?v=f9LY0-WP9Go Nov 27, 2013 - Uploaded by IAHR Media Library
From Effects of Fluid Compressibility - (Hunter Rouse) Courtesy of Dr Marian Muste, IIHR - Hydroscience ...
What is water hammer and how to prevent it - PlumbingMart.com
www.plumbingmart.com/water-hammer-information.html Find Water Hammer - PlumbingMart makes it easy to do plumbing and even misspelled pluming and plumming.
What is Water Hammer? Plumbing Tips on How to Solve It - The Balance
https://www.thebalance.com > ... > Construction > Materials > Mechanical Systems Mar 4, 2017 - Water hammer is a common plumbing issue where water changes direction suddenly. Use any of these 4 options to solve water hammer issues.
water hammer Google Search
Jul 11, 2017 | Moen 87530 Touch Control Single Handle...
Installed Delta 16955-SSSD Stainless Steel Victorian Single Handle Kitchen 16955-SSSD a couple months ago. About a couple weeks ago experienced low flow for about 4 hours then started working fine. Now...
Remove spay head from the end of the sprayer hose and turn the water on. If you have good pressure without the head, call Delta and ask for a new spray head. If you still have low water pressure without the spray head attached, call Delta and ask for a new ceramic disc cartridge free.
Sep 01, 2010 | Delta 16955-SSSD Stainless Steel Victorian...
I just installed a series 13/14 single valve tub/shower faucet. When I try to turn on just the tub spout, the shower comes on as well. What could be causing this?
most likely problem is to much pressure in water lines if u have shut off valves on to feed lines turn them down a little will decrease pressure to the valve other problem the spout {tub} diverted is partially engaged, loose,debris or defective if u can reremove the spout and observe the valve for proper function
Feb 13, 2010 | Delta Monitor 13 Series Chrome Trim...
I have the PP Marielle Kitchen Faucet with spray and soap. My water pressure is extremely low. I tried to go online for guide to show me how to fix valve and where it is located but site tells me my model...
you have dirt in the deverter valve its in the fachet part under the sink turn off the water remove the spring it slides out then pull the devert out clean the parts and reinstall i have 3 of them doing the same about 6 mounts old a bad fachet desigen
Aug 19, 2009 | Price Pfister Marielle Kitchen Faucet with...
New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
May 04, 2009 | Price Pfister Marielle Kitchen Faucet with...
No water flow in kitchen sink
Sorry to say, you will need to replace that faucet, and also when you are shopping for a replacement, inquire about a rosette to cover the hole left by the voided sprayer.
Good luck...
Feb 24, 2009 | Home
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Low Water Pressure in Kitchen Faucet
Ihad the same problem. It is not the screen. What you need to do is get a spray diverter the old one disintergated and is blocking the flow. You have to take the collar off and underneath is the diverter. This is after you take the ball and rings out.
Oct 25, 2008 | Plumbing
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
