Question about HP Pavilion a1430n PC Desktop
Are the ports etc. labeled on the back of the hp a1430n media edition? I'm trying to connect an additional printer
    President:
  • 2,992 Answers
The connectors have legends but not labels. You can download this setup poster from HP which shows you what the connectors are for. Any printer you connect will likely be a USB printer (about the only kind available today). You can connect those to one of the front panel USB ports and not have to bother getting behind the computer at all.
You shouldn't have too much trouble. Thanks for using Fixya!
Posted on Feb 02, 2010
Tip
Trick to Setup a Thermal Printer
If you have this equipment for your needs, you should be able to establish the correct way to do functions effectively and can be exploited. To help you find information about the creative process, please read this article.
You must open the printer cover by releasing the button and the type of paper or label. If you want to print the labels, just be sure that the labels can work well. You can add other steps you can make labels to suit your needs. In addition, you must ensure that labels are also durable.
Then you need to close the lid until you hear a click. In addition, you must connect the power cord and press the feed button / tab, you can be sure that the labels have already been installed in a good way.
For the next step, you should turn off the computer and connect to the printer. In this case, you can use any USB port on your computer. Also
you can establish a connection with the use of parallel or serial port, but you must use the right cables.
After you turn on your computer. You must insert the installation CD. Here, follow the instructions arranged so that you can make the installation process is well.
After the installation process is complete, you can try to see if the printer can be used or not.
on Jan 15, 2011 | Office Equipment & Supplies
How do i set up my hp 1012 printer to print wirelessly?
1.Position the printer near your wireless network's router. Plug an Ethernet cable into the Ethernet port on the back end of the printer. Run the other end to any of the numbered ports on the back side of the router. Press the "Print Report Page" button on the printer.
2.Navigate to the setup page listed on the report page and click the tab labeled "Networking."
3.Scroll to the "Connections" heading and click "Wireless." Navigate to the tab labeled "Wireless Setup." Click the "Start Wizard" button.
4. Follow the prompts to connect the HP 1012 to your wireless network. Click "Finish" and close the browser.
5.Open the "Start" menu and navigate to "Network." Choose the "Add a Printer" option. Click "Add a network printer."
6. Click "HP Laserjet 1012" and choose "Next" and "Finish" to access the printer through your computer's wireless connection. Repeat the process of adding the printer on any other computers on the wireless network.
Please follow these steps and let me know if it works or not
Nov 01, 2010 | HP LaserJet 1012 Printer
Need manual for connecting fax to phone line and computer
Simple:
* one telephone-wire from wall-outlet to port on FAX labelled "line" or "telco";
* one telephone-wire from port labelled "phone" (or an icon of a telephone) to the port on your computer's modem labelled "tel" or "telco" (if your modem has more than just one port).
So, "incoming" telephone-calls go the FAX, to be "answered" by the FAX, while "outgoing" dial-up-Internet connections from your computer's modem "pass-through" the FAX, and to to the wall-port, and further along to the Internet Service Provider.
Jun 15, 2010 | HP DESKJET PRINTER, HP OR COMPATIBLE
To my HP Pavilion Media Center A1430N, I lost ALL video signal
Hi:
One quick thing to check is to see if your Video card is fully seated down in the motherboard? Sometimes they can pop up a bit, and you lose your output.
If that doesnt help, you could remove your memory, one stick at a time, to see if that helps. This could be the cause if you added memory from the old computer.
Oct 30, 2009 | HP Pavilion a1430n (ER900AA) PC Desktop
Printer port configuration and Zebra trouble
When you connect a printer to your pc the operating system adds a virtual port. Your pc will typically have 3 physical usb ports but can have as many virtual ports as you have devices to connect to it.
1: Ensure that your printer has media loaded and is powered up and ready to print. Connect the USB cable. You should get a message on pc screen saying device (printer) found.
Open printer driver ( double click on the zebra printer icon - Start/control panel/printers & Faxes/) Click print test page. If it doesnt print you will see a printer icon with a red question mark.on your toolbar, double click on this. This will bring up a small window showing status of the print job, Click printer/properties/ports. Select the next free usb port and click apply. Drag the print status window so that you can see the message in the status window change from Error print to error Restarting. repeat trying each of your usb ports until printer works. start with the higheat usb with highest number and work your way down.
Jul 15, 2009 | Zebra LP 2844-Z Thermal Label Printer
How do I estimate the number of ports needed on a switch?I am thinking about getting a Netgear GS 108 8 port 10/100/1000 switch to connect my DSL modem and my HP 4Plus printer to my desktop MAC and my...
an 8-port switch is sufficient for your situation
port one - modem/router
port two - PC
port three - networked printer
port four - laptop
ports 5-8 free, waiting to be used, can connect a wireless AP for a WLAN or other computers, or an IP phone, etc ....
Mar 26, 2009 | Belkin Computers & Internet
I have a sciphone i68+\\ i cant connect to the
I don't know why sciPhone or AT&T don't make this information available. I had to search the net for hours but finally found out how to connect to the internet and data on an i68. Here are the steps:
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to WAP@CINGULARGPRS.COM (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to WAP@CINGULARGPRS.COM
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Feb 24, 2009 | Apple iPhone (16 GB) Smartphone
Samsung CLX-3160FN won't print from my HP Pavilion Media Center M7467C
I have a brand new HP pavilion, but it wont print from my HP deskjet. If i am lucky i get the first p[age and a couple of lines on page 2. My new laptop (ACER) is quite happy to print using the same cable. printer etc. Conclusion...HP pav is defective. Am I wrong?
May 01, 2008 | Samsung CLX 3160fn All-In-One Printer
HP Pavilion a1430n PC Desktop Logo
50 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
