Cold water fill is super slow - Washing Machines
  • 744 Answers
Do this:
1. Un-plug the washing machine
2. Shut off the cold water supply valve to the machine and then disconnect the cold water hose at the machine. Place a small container under the fitting when you do this to catch the water that will probably leak out.
3. Place the disconnected end of the hose in a bucket or the sink if you have one and SLOWLY turn the cold water back on. make sure the water pressure coming out of the hose is good. If so, the problem isn't there. Turn the valve back off.
4. Set the disconnected hose aside. Take a good look at the connection on the machine (where you disconnected the hose). There should be an inlet screen. It's common for these screens to plug up once in a while, especially if you are on well water. Remove the screen and clean it, being careful to not lose the washer. The screen can be rinsed out in a sink. Look for any other debris that may be in this connection.
5. Re-install the screen, re-install, the hose, turn the water back on slowly, and check for leaks. Plug the machine back in.
6. Try filling the machine again with the washer empty, just in case some muck also comes out so you don't stain your clothes.
7. If it works ok, you're done. If not, then the water fill valve itself may not be working properly and may need to be replaced.
8. A weak electrical connection to the fill valve can also cause this condition, but it's usually the inlet screen.
Good Luck and re-post if you have further questions!
Posted on Feb 02, 2010
Testimonial: "thank you for great advice!"
  • 51 Answers
Turn off the water valve, remove the inlet hose from the machine and pinch out the small gauze filter and wash it, it will be bunged up with like, this will solve your problem
My kenmore 80 series washing machine makes a horrible noise and cold side fills about half speed when filling with water. What should I check?
For the slow water issue, you will need to replace the water inlet valve. Here is a link to the part.
Could you describe the noise and where it is coming from?
Oct 19, 2012 | Kenmore Washing Machines
Will not fill with setting on cold weter only. How do I correct?
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 29, 2011 | Hotpoint Super 3.2 Cu. Ft. Capacity Washer
Water when filling has slowed down cold water is very slow hot is ok
heatman101
Jun 26, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Cold water runs really slow when filling up washer,starts out normal but then goes to just a trickle until filled.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Mar 30, 2011 | Washing Machines
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
SLOW COLD WATER WHEN FILLING
Remove the inlet hoses.
Clean the water valve's screens.
Feb 18, 2009 | Kenmore 24902 Top Load Washer
Stops and starts on warm water fill
Try taking the hoses off the machine and cleaning the screens in the hoses and the screens in the water valve. They get plugged and restrict the flow of water. if these are clean then the sand in your well has damaged the water valve and you must replace it. The part number is 285805 and is around 30 bucks.
Nov 20, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Slow rinse cycle fill
take the hose off the cold water valve and check the screen on the water valve ,make sure the cold water is on all the way and the hoses are on the right valves get a water bucket hold the cold water line in it open the cold water valve to check the pressure
Jan 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
253 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
