Question about Samsung Phone PDCSLCD12B
Phones wont allow incoming or outgoing calls.
All extensions are able to talk to each other but the main phone. Following a call this morning the line light stayed on and the other line also became engaged. When they cleared my phone is dead. I have a message on the phone screen DCS-816. Can any one offer me advice please
  • fernsmon Feb 20, 2008
    Tried this and had high hopes it would work (it made sense) thanks, but it didn't. I have just noticed that I now have a flashing red light in the box. Thanks again for trying
  • 65 Answers
Try turning the KSU( the main box) off and wait a minute and then turn it back on should reset it. It is much like rebooting a computer.
Posted on Feb 19, 2008
  • BIRDIE DAVIS Feb 20, 2008
    is there a way you can check to see if yyou have a dial tone on that line? You could check at the interface with a regular corded phone or at the KSU if you take the side panel off you will see a cord plugged in to where it says line 1&2 if you unplug it from the KSU you should be able to plug it into a corded phone and check to see if you are getting a dial tone. if you are not call the phone provider.
Talk talk my account 1008829859
You really need to contact your phone firm, your provider. I thought they must keep your phone line "alive" so you can make emergency calls.
Talk Talk must be the service coming in with the land line and works as ADSL. If the line is down, nothing works.
Jul 26, 2014 | Lands Phones
A180 just showing base and no response
Is the ringer turned off? Or is the volume on the ring tone set too low? Another possibility is that the phone isn't set to receive incoming calls - the Siemens phones I've owned allowed one to specify which handsets could handle incoming calls and outgoing calls on each line.
Jun 01, 2014 | Siemens Lands Phones
I have put a main greeting on my Norstar M7310 phone for all 5 incoming lines, however one of our incoming lines has grabbed a personal message form another extension and callers get that personal message...
You need to know what extension is causing the forward directly to voice mail. Chances are that this extension has ringing lines programmed to it and the forward on busy is to voice mail. ANY PHONE THAT HAS RINGING LINES SHOULD NOT BE SET TO FORWARD ON BUSY. If they happen to be on the phone when a call comes in it will go straight to their personal mailbox.
Aug 09, 2013 | NorStar M7310 Phone
Nokia n73
Please make sure your outgoing and incoming calls are not barred.
go to settings
go to call settings
go to call barring
and check the status of your outgoing and incoming calls.
There is also a line 1 and line 2 facility. Make sure you are using Line 1
Hope the above is helpful.
Thanks,
Kanu
Aug 04, 2009 | Nokia N73 Cellular Phone
Stop ringing at main phones when outside calls come in.
Here is a link to program line ringing.
It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
From any display phone, press Feature 11
then enter your extension number 2 times. So if you are extension 20, do this:
Feature11-20-20
see if that does it.
May 28, 2009 | Lucent PARTNER18 Corded Phone
During incoming call the line will go to others extension line.
Consult an expert he will fix it bcos normally they wont let go their codes.
Rate this
Apr 06, 2009 | Panasonic KX-T7730 Corded Phone
No connection outgoing and can't answer incoming calls
I unpluged all hand sets for an hour,when I reconnected the hand sets they worked fine.
Jan 14, 2009 | Lands Phones
Call barring
Use the network services menu for this...
Use this menu to access network services. Please
contact your service provider to check their availability and subscribe to them, if you wish.
This network service allows you to restrict your calls.
1. Select a call barring option:
All outgoing: prohibit outgoing calls.
International: prohibit international calls.
International except home: only allow calls
to numbers within the current country when
you are abroad, and to your home country.
All incoming: prohibit incoming calls.
Incoming while abroad: prohibit incoming
calls when you use your phone outside of your
home country.
Cancel all: cancel all call barring settings,
allowing to be sent and received normally.
Change barring password: change the call
barring password obtained from your service
provider.
2. Select the type of calls to be barred.
home country.
provider.
if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
hope this helps :)
Dec 16, 2008 | Samsung SGH-D600 Cellular Phone
Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
Aug 08, 2008 | Panasonic KX-T7630 Corded Phone
Omega 2000
If you mean you want to have someone on each of your extensions listening to the same conversation, it can not happen. The reason for this is the first phone to pick up makes a connection with the base. The other phone will not be able to make that same connection as long as the first one is still on.
Jan 04, 2008 | Uniden Cordless Phone
Lands Phones Logo
130 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
