Question about HP OfficeJet 7310 All-In-One InkJet Printer
Hp Officejet Pro L7780 Reads "close document feeder cover" How do i fix
  • HP Master
  • 19,396 Answers
Hi.
The Automatic Feeder unit is not well closed, or a part in the unit closing mechanism is damaged. Paper stuck in the feeder can also trigger the problem if this is preventing the feeder cover from closing properly.
To start disconnect printer power cord , open and close the feeder cover, look for jams and connect back.
If the problem is still there, then please follow the instructions on this page.
If still no luck contact HP, in that case the printer is faulty (sensor, wiring, main board).
See:Customer Service / Contact HP , or use the number listed on the printer manual.
Posted on Feb 02, 2010
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
How do you clear "close document feeder cover"
Open ADF feeder cover find out the sensor location observe is there any breakage, if not insert a peace of paper in sensor, see the messiage..if its remain same it might be a problem with sensor, formatter or cable faulty.. if its gone.. used your brain...close it..best of luck..
Sep 05, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
When making copies, auto document feeder picks up paper and rollers squeal but paper gets stuck on underside. If you lift the lid about an inch the paper will feed through. HP Model L7780
open the top cover, on the very left there is a part that can be removed (running front to back) I believe you will see a scrap of paper iunder there. remove the paper, replace the part and try again
Jan 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
The document feeded is not pulling the paper. What should I do? Do you have this part for sale? How much?
Is this happening on TOP Feeder or Actual Paper Tray..
Turn off the printer
Remove the TOP ADF Cover and Clean the Rollers with lint free cloth
Remove the Rear Access door and clean the Rollers
Close the Doors and turn on the printer.
Jun 23, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Hp officejet pro L7590 - automatic document feeder will not pick up - how do I fix this problem?
Hi
Check the following
--Check the paper in the ADF (automatic document feeder)
--Make sure the ADF pick assembly is in good working condition
--Remove the document feeder and open the ADF cover.
--While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops.
--Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller.
--Clean the rollers and separator pad
Mar 03, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
The auto-document feeder on our HP L7780 OfficeJet Pro printer doesn't pick up the papers anymore. The 'gears' are spinning, but the papers aren't advancing. I've cleaned the rollers, but that still didn't...
I put an elastic band around the black roller as it doesnt seem big enough and it works nearly every time now. Have done this with another L7780 Pro as well which fixed it completely on that one.
Jun 09, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
L7780 All-in-One
I had the same problem, Lift the scanner lid there are directions there. my printer is new and apprently there is a blue thing there that the was on top of the scanner you need to make sure its under it. can't explain well eh sorry, but there are directions under the lid check it out.
Nov 07, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Hp officejet 7310
better u disconect ur document feeder wire connection. and than try that.
Aug 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
57 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
