Question about Baby Gear
Does anyone know where I can buy a new brake part for my first wheels city twin? The brake isnt working on one side. Thank you
  • 31 Answers
Emma, try to ask your queries here'
email them at this address info@firstwheels.nl
Hope this help your problem.
Posted on Feb 21, 2010
I have been working on a Bedford m type drop side twin back wheel lorry from 1946. The problem is that whenever the brakes are applied, the fuse keeps blowing and I do not know where the switch which...
The stop lamp switch is screwed into the hydraulic pipe line and is located on the chassis frame offside side member, adjacent to the engine rear crossmembember. The switch is operated by pressure or fluid in the break system.
Sep 08, 2013 | Cars & Trucks
I have a Baby Jogger City Select (manufactured 10/2010) and have an issue with the handbrake. When you pull the lever on the handle bar the cable, which runs to the rear axis, pulls out a little metal bar...
I did not have to disassemble at all. Thanks to your comments. I just took off the wheel with the stuck pin; gripped the pin with large pliers and a tight grip; pulled slightly outward while turning pin. Did this a couple times and the pin shot back into place!
May 07, 2011 | Baby Jogger 2010 City Select Baby Stroller...
Hi i have a derbi cross city 125 back wheel problem
You can get new wheels on ebay, or at your local motorcycle dealer, and it does not have to be the exact same tyre, but it does have to be the same hight, i would reccomend bridgestone tyres as they last a hell of a lot longer than the stock, well worth your money
Aug 01, 2010 | 2008 Derbi Cross city
My aurora just got a new brake hose because when
One of your wheel brake cylinders is leaking.
Under the car, look at each wheel on the "back" side. There will be leaking fluid marks on the rims and the tires.
Oct 05, 2009 | 1997 Oldsmobile Aurora
Rear wheel bearing hyundai coupe
just remove the wheel and count the teeth on the ring on the rear brake thats all you need to do. Since you can't drive it take it off and take it in to compare parts so you don't have to go back twice. You will need a new wheel seal and race and bearings.
Sep 29, 2009 | 2001 Hyundai Tiburon
BMW R75/7 brake question
I have actually done the conversion and the best thing you can do is fit the smallest mastercylinder you can find - my guru would only fit 11mm m/c s to with ATE calipers . The best pads I found were the EBCs. Most good brake shops will be able to sleeve your existing cylinder down. Forget any piffle you may read about spongy levers and long travel- it just doesnt happen if you have the ability to bleed the brakes. The problem with going away from the BMW m/c is the switchgear and throttle - if you fit another MC you will need new switchgear , twistgrip and cables. It takes major engineering or a brave bodge to fit a different caliper to the ATE fork legs , as the mounting system is unique. The forks from most BMWs interchange , including from the K bikes , but spoked wheels which work with the later and better twin Brembos are scarce and exspensive. I have a pair of Showa forks with twin Brembos off a late K which cost $ 200- on ebay including the wheel , guard and a near new tire. Problem is it is an alloy wheel and the only person I cAn find with a spoked wheel to fit wants $600- for it. And I am not ready to put alloy wheels on my R75/7 just yet.
Nov 20, 2008 | 1976 BMW R 75-7
Separating wheel of Peg Perego Aria Twin
You will need to get a replacement wheel as soon as you can (that one will complete fail soon) there really isn't a way to repair them as such. when you get the new one. there is a little plastic cap on the center of the wheel covering the bolt... if you have a rachet and socket set you can replace the wheel yourself. if not just go to any auto repair shop and have one of the guys or gurls do it.... very unlikely they will charge you to do it as it only takes about 5 minutes. although i am in canada one of my business partners lives in brisbane and i'll ask him to let me know where you can buy one.
Robert
Sep 22, 2008 | Peg Perego Aria Twin - Metropolis Stroller
1997 Ford Expedition Driver Side rear axle
pick up new wheel studs. using a punch hammer out the old broken off studs. push in the new studs from the back side grease the threads put your lug nut on backwards and tighten up this will pull the stud into place. as long as your wheel isnt damaged or new wheel . use a torque wrench and torque the lug nuts drive a mile or so and torque again and then after 50 miles.
Sep 09, 2008 | 1997 Ford Expedition
Baby Gear Logo
114 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
