Question about Dishwashers
1. My dishwsher has filled with brown stains over
1. My dishwsher has filled with brown stains over the last few months. Is there a way to clean?
2. The racks are starting to fall apart. Is there a way to get a replacement, and would that be easy to install?
    Sniper:
  • 71 Answers
Several methods for cleaning the brown stains. Assuming they are rust stains you need to run a cycle without any dishes and a cleaner. Suggested cleaners are lemon juice or Iron Out. Some people use vinegar.
Racks should be available at your local appliance parts store or online. Appliance Parts at http://www.appliance-parts-warehouse.com and some at sears.com. Most are not difficult to install. Some require some thought to figure out how to get the old ones out.
Posted on Feb 02, 2010
My Hoover 2X PetPlus Pet Stain & Odor Remover (64 oz) turned my off white carpet rusty orange! The liquid itself was orange brown. Is this the normal color?
I don't believe this is normal. I would contact the company. I would use 1 part white vinegar to 2 parts water and put it in a spray bottle. Use that to clean pet stains.
Sep 19, 2016 | Hoover Vacuums
Dishwasher does not clean tea stains from teacups- we have tried a variety of soaps and have used sani-clean. Machine is only one month old- new fully integrated model.
Method #1
  • Wet a cloth then rub the inside of the mug with baking soda. If the stains are stubborn, soak overnight in hot water and baking soda.
Method #2
  • Soak the mug in bleach OR vinegar for several hours or overnight.
Method #3
  • Fill mug with boiling water, add two spoonfuls of dishwasher detergent then soak overnight.
Method #4
  • Try a paste of corn starch and vinegar, apply and let sit for a few minutes then scrub away.
Method #5
  • Drop two denture tablets in the mug, pour hot water over top then soak overnight.
After soaking mugs and removing the stains, rinse and wash very well before using-especially when using the bleach method.
May 06, 2011 | Samsung Dishwashers
Random brown stains in random loads of laundry
Hi from Australia
Ok the problem with your washing machine is that there is grease and oil stuck in the machine and the oil will dribble out when you run the machine on a different cycle if you rince with cold water then the oil stays in there and the hot water lets a little bit out as it is stuck in the pipes of your machine ok the first thing is run an empty load on full hot water even the rince cycle with 1 cup of bleach nothing else let that go through the long cycle then do the same again with 1 cup of white vinger and 1/2 cup citric acid which you should be able to get over there or baking soda try that it will clean your machine and your pipes it is great way to keep it all clean by the time you have done this you should not have any brown stains
Have a great weekend
Jan 22, 2010 | Kenmore HE2 Plus Front Load Washer
Will not start. few months old. maybe bad gas
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 15, 2009 | Homelite Consumer Products Backpack...
Brown stains in the drum of my whirlpool dryer
Apparently a common problem with 4-5 year old Kenmore and Whirlpool dryers. The paint is rubbed off the back panel by the felt seal attached to the rotating drum. The bare metal gets rusty from the damp clothes. The rust is rubbed off by the felt seal. The entire felt seal will turn brown. The stains are transfered to the clothes. The rust stains can generally be removed by additional cleaning.
I'm going to replace the felt seal on the drum, clean the rust off the back panel and see how long it lasts. Seal w/ adhesive is $30-40.
Some have suggested painting the back panel, but i don't think fresh paint is going to last long. The original paint was probably electrostatically applied and maybe baked on.
Nov 05, 2009 | Dryers
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
Apr 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have a brown colored stain in the bottom of my white franke white fireclay sink (maybe coffee stain, not sure) I can't get it clean with regular hand soap which is what franke told me to clean the sink...
I used Cerama Bryte for the dark colored stain, I left it on for about 5 minutes and then rubbed it clean, the stain is gone. Now I tried it on the small aluminum scratch marks, no thank you, it couldn't help that problem. Still seeking a solution. Thanks
Mar 02, 2009 | Herbeau Creations HERBEAU "Luberon" Art...
Whirlpool duet front loader washer/dryer
It is not the dryer causing the problem. We get the brown streaks on our white clothes before putting them in the dryer. I have ruined more white clothes over the past six months with this Duet washing machine!!! We also don't use bleach so I don't think it is the HE/Clorox combo that somebody mentioned earlier. Anybody know what exactly is causing this yet... before I throught the moldy stain causing Whirlpool duet out?
Aug 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dark brown stains
Try running a cycle on hot with 1/2 cup dishwasher detergent (powdered) in it. Stop it before it pumps it out and restart again, Do this a few times to get a long scrub action. I don't think its oil as a front load machine doesn't have a transmission. If you think this is a rust stain use a rust remover type product instead of dishwasher detergent.
Jun 07, 2008 | Frigidaire GLTR1670A Front Load Washer
Cleaning
deacaled it use a special descaler produit not vinegar 1 part descaler 1 part water fill up water tank start let it drip for few second turn off leave it for 15 minute repeat untill empty after rinse very good very corosif stuff that descaler the machine is gonna work fine the brown stuff should come of but coffe is like dye calcium in machine is a killer brown stuff is not nice but the coffee is great cheers
Feb 03, 2008 | Coffee Makers & Espresso Machines
Dishwashers Logo
119 people viewed this question
Top Dishwashers Experts
Owen Barnes
