Question about Makita Drills
How to remove old chuck after removing internal screw
    President:
  • 2,030 Answers
It should pull right off try using a flat bar to help coax it off the shaft.
Posted on Feb 02, 2010
How to change the chuck on 18 volt cordless drills
Set the drill to reverse. Hold the chuck, press the trigger and open the drills chuck to it wide open position. Now,, take the correct size allen wrench and insert it into the back of the chuck to remove the screw. Turn the screw clockwise to remove it. Notice I said clockwise, just the opposite of what you might think. Hold the chuck with your hand or a pair of large vise grips and press the trigger to unscrew the chuck from the drill. Rotate it counterclockwise to remove it from the drill. Reverse the procedure to install the new chuck.
Mar 10, 2011 | Dewalt 18 Volt Compact Drill Kit
How can I remove the chuck of a KR 110 hammer drill. The LH threaded internal screw has been removed but the chuck remains firmly fixed. I want to replace the existing chuck with a Jacob's type keyed...
The chuck is screwed on with RH threads. Lock the shaft and insert your chuck key into one of the key holes. using a plastic or wooden mallet give it a sharp tap in the right direction, this should free it up so that you can remove it. When you reinstall the new chuck us the same method to tighten the new chuck.
Jun 09, 2010 | Electrical Supplies
Chuck is locked open
you have three jaws in your chuck, one of them will probably have a small burr on it causing it to stick.
try this...
tap the chuck with a small hammer then try to use the chuck key gently in the opposite key hole to the hammer blows. turn chuck though 120degrees and repeat.
if this does not work chucks are fairly universal and easily replaced (i would recommend a keyless jacobs). you can get the old one off by removing the ph2 (phillips) machine screw inside the centre of the chuck... be careful!! this screw is usually soft and counter threaded... when screw removed bash off the chuck with a hammer and cold chisel...
good luck
Oct 23, 2009 | Dewalt 1/2 Hammer Drill DW511
How to change a chuck on makita 8444 drill
Hi there, the chuck will screw onto the spindle of the drill but there is also a screw to undo. Open the chuch out fully then look down the centre of the chuck and you will find a philips head. The thread on the screw is opposite to the normail way so instead of undoing to the left, undo to the right.there should be threadlock on the screw so may be abit tough for the first turn. Once removed a strong pair of grips and a good tug should then remove the old chuck, some are more orqard than others to remove so just keep trying.
Oct 18, 2009 | Makita 18 Volt Cordless Hammer Drill Kit ...
I have a very old 3/8'' elecric drill, I think it ia a Skil, The key chuck does not work properly and I want to replace it. How do I remove the old chuck?
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Turn it clockwise until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Jun 12, 2009 | Drills
Remove and replace the chuck
Most drill press chucks are held on with a screw. Open the chuck all the way. Look inside the chuck, there should be a screw in the bottom. Some are left hand threads, some are not. Good Luck
May 28, 2009 | Drills
Removing chuck
Open chuck jaws all the way open you should see a screw or a allen screw inside the chuck, remove the screw an voila off comes the chuck. You may have to rap it with a mallet ot a piece of wood if the drill is real old.
Mar 24, 2009 | Drills
I have a thor electric drill. I am unable to remove the chuck on the drill. can you help?
Open up the old chuck all the way and there is a screw down in the middle of the chuck, unless it is missing. The screw is left-handed threads. Remove the screw. Take a large allen wrench. Tighten down in the old chuck. The chuck is right handed threads. Lay the tool down on its side. Take a hammer and hit the other end of the allen wrench several times until the chuck comes off (some of them are on very tight). If it doesn't come off, then spray WD-40 down inside the chuck and let it sit overnight or for a few hours and then try it again.
Don-www.toolsandmachinery.com
Feb 20, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Chuck Replacement
Hello Mike-To remove the old chuck, you'
ll need to open the jaws all the way and l;ook inside the chuck for a screw that holds the chuck onto the motor shaft. That screw has a reverse thread which means that you'll need to hold the chuck tight while using a screwdriver to turn the screw in the forward direction. After the screw is removed, p[lace a large allen wrench into the chuck and tighten it. Then using a hammer handle, rap the allen wrench in the reverse direction for removal. Then call Alltrade Tools @ 1-800-423-3598, give them your model number so they can provide you with a replacement chuck.
Jul 31, 2008 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Drills Logo
29 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
