Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Oil pump not suppling oil to chain
How do I remove the oil pump, and where is it located?
    President:
  • 2,220 Answers
The following is applicable to a Poulan PP3218Anything (doubtful it matters). The "Type" may be important so I must defer to you to ensure applicability.
IPL example (PP4218 Gas Saw Type 2):
http://www.ordertree.com/modelinfo/PWE/PP4218-Gas-Saw-Type-2/75.PP4218-Gas-Saw-Type-2.1.59.1.html
Oiler components are on the "Handle, Chassis & Bar Assembly" print.
All Poulan IPLs:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
It has an inboard clutch both videos apply for complete removal (oil pump behind the clutch):
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
Use the IPL as a guide for disassembly. Good luck with your project. If you have unanswered questions please reply below and I will get back to you. I hope you found this most helpful.
Lou
Posted on Feb 03, 2010
  • dontbother10
    dontbother10 Feb 03, 2010
    ~4218Anything~
  • dontbother10
    ~Poulan PP4218Anything (doubtful it matters).~
2002 bmw 530 I oil pump located
Your oil pump is located inside the oil pan but is part of the chain assembly. The first picture is with the oil pan removed and the engine upside down (the red arrow) the second is right side up red arrow pointing to the oil pump. That gear with the chain on it is left handed thread when removing and installing. Hope this helps....
Oct 28, 2012 | 2002 BMW 5 Series
Husquavarna 455 chain oil problem
is the tin plate on the right way?(not blocking the hole)did you change the bar and the replacement blocking the oiling hole
Aug 19, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Replacing Oil pump in Ford Expedition
the oil pump is on the crank behind the balancer and timing chain cover:
REMOVAL
1. Remove the timing chain.
2. Remove the oil pan.
3. Remove the three (A) oil pump screen and cover bolts and the (B) oil pump screen and cover.
4. Remove the two oil pump bolts and the oil pump.
INSTALLATION
1. Clean and inspect the mating surfaces.
2. Install the oil pump and loosely install the two oil pump bolts.
3. Install the oil pump screen and cover and install the three oil pump screen and cover bolts.
4. Install the timing chains.
5. Install the oil pan.
Apr 25, 2012 | 2003 Ford Expedition
I have a rancher 455 and it's not suppling enough oil to the bar. Is there an adjustment for this?
The 455 has a 3 position adjustable oil pump, the adjuster screw is up under the crankcase, sprocket side, you need a flat blade screw driver.
Oct 11, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Not pumping oil to chain, bought a new pump and oil pickup but I`m not sure where the oil pump is located and what I have to disassemble to get to it.
Most oil pumps are situated behind the clutch and sprocket, these will need to be removed before you can acsess the old pump, if it has an inboard sprocket you will need to remove the clutch first, these are a left hand thread and just spun onto the crankshaft, they need to be jarred off against the compression of the saw, you may need a special tool if there is no nut on the outside of the clutch, this tool fits most Poulon clutches 530035560, once removed it is a fairly straight forward job to change the pump.
Sep 13, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to replace oil pump on 2004 bmw 545i
M62 ENGINE TURN OFF RADIO FIRST. YOU NEED TO INSTALL A MEMORY SAVER BEFORE DISCONNECTING NEGATIVE BATTERY CABLE. TO KEEP FROM LOSING PCM MEMORY. TO REMOVE OIL PUMP.YOU NEED TO LOWER OIL PAN.REMOVE THE LEFT AND RIGHT ENGINE MOUNTS AT THE BOTTOM.REMOVE POWER STEERING PUMP AT THE HOLDER.REMOVE OIL PIPES AT THE POWER STEERING PUMP ALSO ON AUTOMATIC TRANSMISSION, REMOVE BANJO BOLT FOR THE OIL RETURN PIPE FROM THE OIL FILTER AT THE OIL PAN.REMOVE THE MOUNTING BOLT ON THE SPROCKET FOR THE OIL PUMP AND REMOVE THE SPROCKET ALONG WITH THE CHAIN,REMOVE 3 OIL PUMP MOUNTING BOLTS AND REMOVE THE OIL PUMP.REMOVE THE OIL PIPES OUT OF THE CRANKCASE. BEFORE INSTALLING NEW OIL PUMP, CHECK SEALS ON THE OIL PIPES AND REPLACE IF IT NECESSARY.LUBRICATE THE SEALS WITH OIL AND THE OIL PIPES.CHECK THE SEAL IN THE OIL PUMP AND REPLACE IF NECESSARY, SCREW THE HEXAGON ADAPTER BACK INTO THE OIL PUMP UNTIL IT STOPS.INSTALL OIL PUMP AND 2 RIGHT SIDE OIL PUMP MOUNTING BOLTS .TORQUE BOLTS 14 - 17 FT LBS. POSITION THE CHAIN ON THE PUMP AND SPROCKET AND INSTALL THE SPROCKET.TORQUE BOLT TO 35 FT LBS VERIFY THAT THE CHAIN IS POSITION CORRECTLY. ADJUST THE CHAIN SAG TO 0.315 - 0.472 INCHES 8 - 12MM BY TURNING THE HEXAGON ADAPTER IN THE OIL PUMP, THEN INSTALL THE LEFT SIDE MOUNTING BOLT. INSTALL OR CONNECT THE FOLLOWING. INSTALL BANJO BOLT FOR THE OIL RETURN PIPE FROM THE OIL FILTER AT THE OIL PAN, INSTALL THE POWER STEERING PUMP AND CONNECT THE OIL LINES IF EQUIPPED.INSTALL LOWER OIL PAN, INSTALL THE ENGINE OIL.INSTALL THE NEGATIVE BATTERY.
Mar 19, 2011 | BMW 545 Cars & Trucks
Where is the oil pump located on a 2000 chevy tracker
THE 1.6L ENGINE OIL PUMP FRONT OF CRANKSHAFT TIMING COVER.YOU HAVE TO REMOVE CRANKSHAFT PULLEY AND WHOLE TIMING CHAIN COVER.YOU HAVE TO REMOVE OIL PAN TO REMOVE OIL PUMP PICK UP TUBE AND SCREEN.. THE 1.8L ENGINE OIL PUMP IN THE OIL PAN.YOU HAVE TO REMOVE OIL PAN TO REMOVE OIL PUMP FROM ENGINE.
Dec 08, 2010 | 2000 Chevrolet Tracker
How do i change the oil pump in a 2000 dodge intrepid
I'm assuming that you are talking about 2.7L, the check this procedure...
Removal & Installation - 2.7L Engines
  1. Drain the engine oil.
  2. Remove or disconnect the following:
    Crankshaft damper Timing chain cover Timing chain Crankshaft sprocket Oil pan Oil pickup tube and O-RING Oil pump
To install:
Fig. Oil pump mounting bolt locations-2.7L engine
  1. Fill the oil pump rotor cavity with clean engine oil.
  2. Carefully, install the oil pump over the crankshaft and into position.
  3. Install the oil pump mounting bolts and torque to 21 ft. lbs. (28 Nm).
  4. Lubricate the new pickup tube O-ring with clean engine oil and torque the pickup tube mounting bolts to 21 ft. lbs. (28 Nm).
  5. Install or connect the following:
    Oil pan Crankshaft sprocket Timing chain Timing chain cover Crankshaft damper
  6. Fill the engine with clean engine oil.
  7. Start the vehicle, check for leaks and repair if necessary.
Hope helps (remember to rate this).
Oct 02, 2010 | 1999 Dodge Intrepid
How do you adjust the oiler on a husqvarna 268 xp chainsaw
use the control screw on the oil pump
it is located on the top left side of the oil pump casing to the left of the sprocket with the chain and bar off
turn it anti clockwise the check oil output
( no chain and bar on ) if still not right try the other direction
and retry if still not putting out enough oil
may need to clean tank and pickup filter
check pump driver and drum , check oil oulet line
check oil pump itself - it could be worn or air is getting in on the oil inlet side and it not drawing oil
to get these pumps out remove clutch and drum , remove pump drinver
undo 4 x screws and remove pump assy plate
here is web site for parts
http://www.partstree.com/parts/?lc=husqvarna&mn=268+%281997-01%29
go to oil pump clutch you will see parts relationship
cheers hope it helps
Aug 11, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Oil pump replacement
This MAY seem Strange But It IS ALL necessary for Oil Pump Replacement. And Please Don't Forget to Rate Me as Most Folks Do Not. Thank You and GOOD LUCK with the Oil Pump Job Also
OIL PUMP
It is necessary to remove the oil pan, oil pickup and chain case cover to service the oil pump rotors. The oil pump pressure relief valve can be serviced by removing the oil pan and oil pickup tube. Refer to Timing Chain Cover Removal and Installation for procedures.
DISASSEMBLY
  1. To remove the relief valve, proceed as follows:
  2. Drill a 3.175 mm (1/8 inch) hole into the relief valve retainer cap and insert a self-threading sheet metal screw into cap.
  1. Clamp screw into a vise and while supporting chain case cover, remove cap by tapping chain case cover using a soft hammer. Discard retainer cap and remove spring and relief valve.
  2. Remove oil pump cover screws, and lift off cover.
  3. Remove pump rotors.
  1. Wash all parts in a suitable solvent and inspect carefully for damage or wear.
Oil Pump Assembly
  1. Assemble pump, using new parts as required. Install the inner rotor with chamfer facing the cast iron oil pump cover.
  2. Tighten cover screws to 12 Nm (105 inch lbs.).
  3. Prime oil pump before installation by filling rotor cavity with engine oil.
  4. Install chain case cover. Refer to Timing Chain Cover Installation.
REMOVAL of Timing cover
REMOVAL
  1. Disconnect negative cable from battery.
  2. Remove timing chain cover.
REMOVAL Of Oil Pan to gain Access to OIL PUMP
  1. Disconnect negative cable from battery and remove engine oil dipstick.
  2. Raise vehicle on hoist and drain engine oil.
  3. Remove bending brace to transaxle attaching bolt.
  4. Remove bolts attaching dust cover to transaxle housing. Lower dust cover to gain access to oil pan bolts.
  5. Remove oil pan screws and remove oil pan.
INSTALLATION
  1. Clean surfaces and apply a 1/8 inch bead of Mopar (R) Silicone Rubber Adhesive Sealant or equivalent, at the parting line of the chain case cover and the rear seal retainer.
    1. Use a new pan gasket.
    2. Install pan and tighten screws to 12 Nm (105 inch lbs.).
    3. Install dust shield and bending brace to transaxle housing.
    4. Lower vehicle and install oil dipstick.
    5. Connect negative cable to battery.
    6. Fill crankcase with oil to proper level.
Mar 27, 2009 | 1998 Chrysler Town & Country
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
223 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
