Question about Bosch Axxis WTL 5410 Electric Dryer
WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
THE DRYER HAS ONLY BEEN USED FOR APPROXIMATELY 18 MONTHS. IT TUMBLES JUST FINE BUT JUST DOES NOT PROVIDE HEAT. I'VE CLEANED THE HEAT EXCHANGER, WIPED THE MOISTURE SENSOR WITH WHITE VINEGAR AND CLEANED THE LINT FILTER.
  • 51 Answers
The thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Posted on Feb 02, 2010
I have the same problem. Where is the thermostat?
Posted on Jun 27, 2010
E1 code. water is being pumped out dry and start dryer and 3-5 min code comes back. cleaned everything inside checked all hoses and switch. everything looks fine
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
25808741-gtkp3url2ghtdqenstp5bokb-1-0.jpg Dado
Aug 04, 2015 | Bosch Axxis WTL 5410 Electric Dryer
My dryer WTL 5410 electric condensation dryer is cutting on and off.
this is normal operation it turns the drum one direction then the other this is because of the way it condensates
Apr 06, 2014 | Bosch Axxis WTL 5410 Electric Dryer
No heat after 2 mins
if it is a condensation dryer try wiping the inside of the dryer in a damp rag with water & vinegar. this will clean any deposits of the sensors.
Nov 08, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Dryer not starting
Check your lint filter first, and then try to restart it. Also, make sure the door is completely shut. If this doesn't do it, check your condensation hose for blockage. These dryers are very sensitive to lint build up, so make sure to change your lint trap after each load. It's not only a good practice, but it's necessary with this machine
Feb 27, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
The condensation hose is missing from my bosch 5410, what is the correct size of the hose and what material, thanks.
I assume you mean the vent hose, they are usually 4" in diameter,, measure the opening to be sure, you can usually buy one from a supermarket in the plumbing department.
Please rate my solution.
Thanks.
Sep 28, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Error Code
open the thing up and locate the service manual. once located it should list what that error means. alternatively call bosch and ask them.
Aug 25, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
1,121 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
