Question about Brother MFC-5460CN All-In-One InkJet Printer
My MFC-5460 is not feeding the paper. There's no jam...
My MFC-5460 is not feeding the paper up to be printed. Is there a fix for this that I can do? I just fully dissembled and reassembled the printer to try to fix a Print Unable 51 code following the instructions of a Solution regarding the inkjet track but that wasn't apparently the problem. I think the problem occurs when the paper is trying to feed. Any suggestions?
    Scholar:
  • 185 Answers
Remove the paper and invert the printer and give it a healthy shake. just be careful not to drop it.
you may hear whatever is obstructing the pathway, rattling around. Use a small flash light to identify and remove it. Then shake again until all is found and removed.
... the ink jet track obstruct the paper?
Posted on Feb 02, 2010
Testimonial: "Problem was a broken gear head just adjacent to the print head mechanism. It had snapped free, though still attached, was slipping. Glued and fixed!"
Print unable 51 code on brother MFC-5460 CN
paper jam or some sensor error, try to clean the sensor, locate the sensor under the pump, where the printer head park the dis assemble and get the sensor, then clean with water or alcojol..
Jul 21, 2014 | Brother MFC-5460CN InkJet Printer
I have a brothers MFC 5460 CN all in one,with a paper tray jammed so it will not release.how do I get the tray to release
Hi kenttti,
I have provided link here where you can get the instruction on how you can address paper jam with your Brothers printer. It's complete with instruction and illustrations on how to release the tray as well.
Hope it helps.
Thank you for using Fixya.
Feb 16, 2011 | Brother MFC-5460CN All-In-One InkJet...
My Brother MFC-9840CDW keeps jamming every time I print mailing labels. I've had it four 1.5 years with no trouble. The label gets stuck and I have to pull out the toner tray to fetch it. I also...
hello, sounds like there are many possible solutions for you machine, first with paper jamming, are labels going thru manual feed tray, or paper tray, it might be possible that mp feed roller needs cleaning or replacing. if paper tray, simple would be feed roller, clean or replace, if jams continue with normal paper from paper tray, the problem will be front door, i have yet to be able to repair paper jams when front door assembly fails. as far as colors, both drum and toner can cause this problem, if using 3rd party toner, this will also cause some color problems. sorry no real quick fix for this machine, i've tried.
Sep 24, 2010 | Brother MFC-9840CDW Laser Printer
I have a brother mfc 7420 and every time I print it tells me paper jam, I pull the paper tray out fix the paper push start it tells me paper then I have to pull out the cartridge and pull out the paper...
Sounds like there is something in the paper track that's causing this to jam. Its not always easy to get small particles cleared just by removing the jammed paper.
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Sep 20, 2010 | Brother MFC 7420 All-In-One Laser Printer
My printer is showing an error
our printer brother mfc 5460 is not printing.....even though there's an ink....how can we fix that? pls help....
Dec 27, 2009 | Brother MFC-5460CN All-In-One InkJet...
Paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
Print Unable 50 Brother MFC5460 CN
So dont let me be a withness of murderer:
There is no paper sicking within the machine! The jam had lifted the encoder strip out of the ph. After you have fixed it simppy stick some very thin scotch tape onto the ph cover to avoid further liftings (that will happen quite often...)
same issue: (change the viwing size of your browser to enlage the pics)
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5460CN All-In-One InkJet Printer Logo
341 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
