Question about Sharp PGF312X DLP Projector
Shutting down in the middle of presentations
Sharp PG-F212XL DLP projector shuts down in the middle of presentations. It won’t power back on for a while. Then it works again. There is no pattern on how long it will operate. Thank you.
  • 2,237 Answers
It's overheating from excessive dust or lack of air flow. blow the dust out of it with canned air and make sure all of the vents are free from obstructions.
Posted on Feb 03, 2010
Sharp XR-30X starts up then shuts down after 30 seconds.
sounds like it is overheating -- are the fans installed pointing the correct direction, all spinning up well?
Jan 21, 2014 | Sharp XR-30X DLP Projector
On my sharp pg f212xl projector when i turn it on i hear a click and the start up sound then i hear another click about 5 seconds later it shuts down and the power led blinks red
SORRY - it needs a new lamp. It is a protection for the projector so the bulb doesn't explode.
I purchase hitachi projectors with 3 year bulb warrenties now for our school as cheaper in long term
good luck
Jan 23, 2013 | Sharp ELECTRONICS PGF212XL PROJECTOR ...
How do you cool down the system after a presentation?
hi,
To cool down the projector after use just press the Standby button and leave it in standby mode. The projector itself will cool down and will shut down itself. Only after this remove the power.
ok
Mar 19, 2011 | Sharp PG-A20X Multimedia Projector
Hello, i have a sharpe PG-M20S, and just replaced the bulb. I accidently threw the power cable away; I found another in a drawer; i plugged that in; I power the projecter on, and it stays on for 1 second...
There is no problem with the cable as the voltage ident on it is the maximum safe voltage that may pass through it without risk of electric shock.
I would imagine that you have to find your instructions and reset the lamp life now.
Hope that helps.
Feb 17, 2011 | Sharp Notevision PG-M20S Multimedia...
LCD projector shuts off durning use
u have not mentioned how long u have been using this projector. either the lamp life is low or the circuitry protecting the lamp temperature is defective or even the air intake of the fan is inadequate, a filter is fitted for air flow if this is clogged or blocked, lamp temp will rise and unit shuts down. if lamp indicator is yellow or red it is time to change the lamp. if it is red - lamp is totally out, if u turn on the unit four times without replacing lamp, the unit simply wont turn on. one other possibility is power cable and power connections. check power cable too.
Apr 07, 2010 | Sharp Notevision PG-A10X Multimedia...
Sharp PG-M20X digital projector runs 2-5 minutes then shuts off
the Fan has the problem , I had the same of yours. I noticed some particle was inserted in the center of the fan and removed it , worked perfectly. If old one produce little particles.
Good luck.
Dec 03, 2009 | Sharp Notevision PG-M20X Multimedia...
My sharp xr-20x projector wont turn
are there any leds on? if not, the power supply is shot. if there are leds on, the color and number of flashes will tell you the problem.
Aug 12, 2009 | ViewSonic PJ402D DLP Projector
Projector shut down after replacing the bulb and wont turn on now
are any of the leds on the top of the projector lit? if so, which ones? red or green?
Apr 09, 2009 | Sharp Notevision PG-B10S Multimedia...
Sharp dt500 projector
if none of the keypad keys work, it might be in lockout. if they do, the projector may need to cool down before it shuts down so the bulb won't retain the heat and cause damage. could also be button failure (or if the buttons are rubber, the contact underneath may be worn or dirty thereby causing no contact).
Mar 25, 2009 | Sharp DT500 HD-DLP 16:9 Front projector...
Sharp PGF312X DLP Projector Logo
109 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
