Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Cruzer 2gig won't see usb 2.0
It worked for about 6 months now whenever i plug it into any computer with usb2 a message pops up saying"The USB device connected can perform faster in a hi speed usb 2.o slot"
A: I know I have usb 2.0 I built this system
B: I formated the drive many times
 solution = still get the error message
  • 2 more comments
  • opocolo Feb 26, 2008
    Yeah bogus man I've formatted many flash drives and they still work. And again I built this system all slots are usb 2.0.
  • Anonymous Mar 23, 2008
    SanDisk 4GB Cruzer Micro USB Flash Drive Hard Drive
    don't works in usb2.0 mode
    not only in one computer, but in all computers i have tried.
  • Anonymous Apr 13, 2008
    same problem with 4giga please advise
  • Anonymous Dec 06, 2008
    INSER DISC DANS LE LECTEUR
  • 50 Answers
1)maybe not all of the slots are USB2.0 try the furthest slot from the one you put it in or in front of your computer.
2) you should NEVER format a flash drive. It will not work after a format. You now need a new disk.
Posted on Feb 24, 2008
  • Sean  Cheren
    Sean Cheren Feb 26, 2008
    hmm when i formated my drive the system malfunctioned and it no longer would store info. sorry i couldnt help.
My pen 4gb pendrive is working very slow it works 800kbps
When you plug in your USB pendrive into your computer and you get a message "This device can perform faster if connected to a high speed USB2 port".
This means your computer supports USB1 which is much slower than USB2 and the latest USB3.
There may be a BIOS upgrade to configure your computer to support USB2.
May 26, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
It is not detected by any computer
Check you have usb 2.0 drivers installed on the computer, go my computer and right click on it, then go to device manager and for universal serial bus drivers click on the '+' sign and see if have 'Usb2 Enhanced Host Contoller' if you dont you can download the driers here: www.softwarepatch.com/utilities/via-usb2.html.
If you are still getting the problem and usb2 drivers are installed the usb flash card must be corrupted.
Jan 24, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
32gb Cruzer USB light comes on when i plug it into (any USB port) message = "New Hardware found" but i cannot access the (E) drive thru my cimputer...it ask me to insert a disk...... its been fine...
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Oct 25, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Every time I try to add a document it says enter a
2. Format
Sep 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
USB2 ports on siemens C 1020
The USB Controller is too old and only handles USB 1.1
If you want to upgrade to USB 2.0 you can do what I did for my old gateway. I bought a USB2.0 PCMCIA card. You can pick them up for anywhere from 20 bucks on up, depending on how many ports you want. Best Buy has them so I would imagine any computer retailer would be able to snag one for you.
Hope this helps.
May 01, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
ASUS P4SDX USB Ports not recognized as USB2 HS Ports
The message comes up when a USB 2 device is connected to a slower USB 1 or 1.1 port. It is only to advise you that the devise will operate faster on a USB 2 port. If your computer has only USB 1 or 1.1 ports, you will always see the message. You can buy and install a card with USB 2 ports and install it. It will come with the USB 2 drivers. Install the card and the drivers and then connect your USB 2 device to the new hardware and you should not see the message anymore.
Good luck, And let me know ho it works out for you.
~ Spoem
Mar 30, 2009 | ASUS P4SDX Motherboard
Facing problem with usb of motorockr e8 ?
There are two type of portsin USB enabled PC one is Type USB1 & Second is Type USB2. USB2 is faster and is compatible with most new devices. most of the flash drives when attached to USB1 prompt a message to attach to USB2 port to work faster. I am using E6 & it works fine with my Laptop & Desktop. So plug the cable into a different USB.
Jan 03, 2009 | Motorola Mobility ROKR E6 Smartphone
1gb cruzer micro
This is caused by 1 of 2 problems:
  1. Your flash drive is corrupted in some way, forcing the computer to reformat it before you can use it.
  2. The flash drive was formatted for a specific device (like a piano) and was made only for that device.
  3. Your PC incorrectly recognized it
  4. You do not have the correct drivers installed.
If you have problem #4, you can go onto google and search "1 gb cruzer micro drivers".
If you have problem #3, try plugging your flash drive into a different USB port.
If you have problem #2 or #1 (Which it most likely is), then you should try or buy a software application such as PC Inspector, to recover those files. Then you may reformat the flash drive.
However, I found that sometimes, just restarting the computer, and inserting and re-inserting the flash drive sometimes does work. But that's not guaranteed.
Feb 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer titanium 2 gb
sounds like it is internally shorted. stop plugging it into your computer and return it to WalMart
Nov 29, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
USB2 high speed not recognize
It sounds like your Windows XP might be missing the USB2 drivers. Try going here http://www.windowsmarketplace.com/ and download the driver needed and see if that fixes your issue.
Sep 27, 2006 | ASUS P5LD2-VM Motherboard
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
73 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
