Question about LG VX-8700 Cellular Phone
"Downloading?" The 2, 5, 8, 0, and clear buttons weren't working so I was going to try turning it off and back on. It turned off, but when I try to turn it back on, the screen says "Verizonwireless LG downloading" and it won't do anything else.
  • talkr99 Jun 14, 2008
    I have had the same problem with my phone. I had just answered the phone when during the conversation, i started hearing beeping noises, and when i looked at the screen, it was saying 2 5 8 0 over and over then something about waiting 2 seconds and then it would start again, i hung up the call and when i tried to dial back, all i could get was a LG screen that said downloading.
  • 51 Answers
Please scan ur phone or format it compleately
even u dont get result then go for software download again
Posted on Apr 01, 2008
0xc18a0001 failure
You could try a power reset of the printer.
Press ON button to turn off printer
Unplug the power cord from the back of the printer
Remove all of the ink cartridges
Wait 3 minutes
Plug the power cord back into the printer
Press the ON button to turn on the printer
Install back all of the cartridges
If this does not work, you could try a hardware reset.
1) Press and hold LEFT ARROW and then press SETUP
Release both buttons
2) Press OK
3) Press & release RIGHT ARROW until LCD reads System Configuration Menu 2
4) Press OK
5) LCD reads Hardware Failure Status: Clear, Press OK to clear
6) Press OK, LCD now reads Cleared, Press Cancel to continue.
7) Press & release CANCEL until the Welcome or Ink System
Failure screen appears on LCD
8) DO NOT PRINT AT THIS STAGE
9) Use POWER button to turn OFF printer
10) Unplug power cord from electrical outlet and from back of printer
11) Wait 1 minute. plug power cord back into outlet first then back into the printer
12)Turn on the printer, Press OK
The printer will start to initiate, do not interrupt.
Dec 31, 2013 | HP Photosmart C6180 All-In-One InkJet...
Hl1440 drum indicator flashing
ok turn it off take the toner out clean all the terminals put them back in make sure everything is closed properly turn the machinie back on and let me no what happenes then
Sep 12, 2008 | Brother DR-400 Replacement Drum - 20000...
VSC error camry
Your pressure is air.. Try bleeding again then clear the codes with obd code reader.. The thing is that the brakes have nothing to do with the rotors and should have never been bled... Good luck...
Apr 09, 2013 | 2008 Toyota Camry
Radio code won't work
When you turn the radio on does it say "Code" in the display? When you enter the 5 digit code hold the button in for a couple seconds. ( I don't remember if you will hear a beep like you do when you preset your stations) Take your time and make sure your hitting the right ones. When I got my car back from the shop it wouldn't work I tried like 30 times, for some reason the buttons weren't depressing all the way. I used compressed air around the buttons followed by WD-40 and waited awhile, tried again and it worked on the 1st or 2nd try.
You can't drive without music..... Good Luck!
Jun 02, 2012 | 1993 Honda Accord
My denon avr391 just keeps flashing red when trying to turn on. I always have to do a rest but it pops then flashes red again
I had the exact same issue with my AVR-391 and tried resetting per user manual but did not help.
I unplugged all speaker wires from both ends (I only had two), made sure they weren't damaged and/or had loose strands that could have been touching the other terminals or anything else then connected them back. I also cleared the receiver of all stuff that was sitting on top of it (pic frames, remotes etc). Turned it back on and problem has not come back. That was a month ago.
Jan 15, 2012 | Denon Audio Players & Recorders
I can turn on my haier tv with a dish network remote.I need a code for it when it off from the buton I can not turn it back on with the button
Hello! I recommend that you try a programming method called a Power Scan this will allow you to search for a code and try the functions as you go. If you only receive partial functionality please repeat steps 2 and 3 until you find the code that works. If there is no functional code the TV button will flash rapidly.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Jun 05, 2011 | Haier HL32D1 32 in. TV
Xbox will not load keeps going back to open tray
Hi,Clear the system cache:
1. On the console, go to My Xbox, and then select System Settings.
2. Select Memory.
3. Highlight any storage device, and then press Y on your controller.
4. Select Clear System Cache. If Clear System Cache is not available, use the following controller button sequence to clear the system cache: X, X, left bumper,right bumper, X, X Note If you don't see a system maintenance prompt on the screen, try pressing the button sequence again.
Try playing discs without the hard drive in:
1. Turn off your console.
2. Locate the hard drive on your console.
Press the release button on the hard drive and lift the hard drive from the console.
Turn on your console.
3. Try to play a game disc.
If this resolves the problem, you will need to replace the hard drive.If not, do the same thing for your memory units. If it works without them, the they may be bad.
Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
Xbox 360 software malfunction, but no red lights
You may have a corrupted update, try this.
1.Turn off console
2.Press and hold the sync button on your console
3.Keep pressing the sync button and turn your console on
4.When the console has fully rebooted, let go of the sync button
this will clear any corrupted updates.
If you need to download any updates just google, downloading updates to console.aspx you should find all the updates you need here.
Remember thumbs up if this helps.
Feb 08, 2010 | Microsoft Xbox 360 Console
Evry time i turn on my xbox 360 it cant find update disc please reinsert the disc. whats wwrong & can it be fix
You may have a corrupt update already, try this
1.Turn off the console and press the sync button on the console
2.still pressing the sync button, turn on the console with the power button
3. when the console has fully booted up, release the sync button
Still no joy, you can down load updates onto a cd rom, google downloading updates to console aspx.
Jan 28, 2010 | Microsoft Xbox 360 Console
Clearing memory
WELL, After a year I alone, without any help from UNIDEN, FIGURED IT OUT.
1. TURN IT OFF, UNPLUG AC JACK IN THE BACK!
2. REMOVE Backup battery cover "underneath" scanner! TAKE ALL 3 BATTERIES OUT.
3. I PUSHED THE POWER BUTTON TO BLEED ANYTHING OFF IN THE CAPACITORS, IF IT HAS ANY INSIDE?
4. PUSH THE"2", "9", AND "HOLD BUTTONS DOWN, THEN PLUG THE A.C. BACK IN ON THE BACK OF THE SCANNER.
5.You WILL notice while you are doing STEP#4 THAT THE DISPLAY SAY'S "CLEAR". ALL FREQUENCIES WILL BE CLEARED IN THE MEMORY!! THEN TURN Scanner OFF reinstall the BATTERIES, TURN BACK ON AND START PROGRAMMING!! THIS WAS FOR A "BC340CRS" SCANNER
Mar 28, 2008 | Uniden BC340CRS Base Scanner
LG VX-8700 Cellular Phone Logo
143 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
