Question about Air Tools & Compressors
I have a FC350A FRAMING NAILER, IT IS IN THE
I have a Porter Cable FC350A FRAMING NAILER, IT IS IN THE SINGLE MODE. When I press the trigger, I only hear a click. There is no sign of air leaking
    New Friend:
  • 109 Answers
Check to make sure that there is not a nail jam , if the driver will not retract then the gun will not cycle . if no nail jam then replace the inner trigger
Posted on Feb 16, 2010
Can you use 30 degree nails in a Porter Cable FC350 34 degree nailer?
Yes, you can use 30 degree clipped head nails in the Porter-Cable FC350 framing nailer. The FC350A and FC350B nailers are newer models that specify the 30-34 degree clipped head nails. Make sure that the nails are between 2' - 3 1/2" in length. The manuals for each of the later models do not explicitly list the 30 degree nails. Their specifications page do list the 30 degree nails. See http://www.portercable.com/Products/ProductDetail.aspx?ProductID=11542 and https://www.homedepot.com/p/Porter-Cable-3-1-2-in-30-Degree-to-34-Degree-Clipped-Head-Framing-Nailer-FC350B/203555581 . The manual for the FC350 is available here: https://www.manualslib.com/manual/132288/Porter-Cable-Fc350.html . It is the same as the manual for the FC350B, https://www.homedepot.com/catalog/pdfimages/7e/7e0d0f88-a9e7-4411-ad0f-7fc5c1c1fbaa.pdf .
I hope this helps.
Mar 21, 2018 | Porter Cable Air Tools & Compressors
How do I release the trigger lock on a brand new porter cable nail gun
Are you depressing the nose of the nail gun against the material to be nailed first? Without doing this, the trigger will not "unlock". You can read a pretty in-depth review of this nail gun at OnlineToolReviews com Porter Cable FR350A Full Round Head Framing... which might also help.
Jul 16, 2014 | Porter Cable FR350A Factory Reconditioned...
Breather Valve
The Porter Cable FR350A has a head valve (PN A08650) and a trigger valve (PN A08368) but no part called a breather valve. What is your question?
Jan 18, 2013 | Porter Cable FR350A Factory Reconditioned...
Older coil350 doesnt fire on single fire. works as its supposed to on bump fire. Single fire just puffs a little air and thats it.
As the contact arm and trigger inner lever wear, the trigger will not push the trigger valve pin all the way in. The pin on the trigger valve also wears. One deficiency or a combination the three problem areas is causing the problem. Remove the trigger and look carefully at the inner lever (thin metal part ). If it looks rather worn and the trigger itself fits loose on the retaining pin, replace with new. Replace the trigger valve if the center pin seems loose in the valve and looks like it has worn shorter. ;Good luck.
Aug 27, 2011 | Porter Cable COIL350 3 12" Magnesium...
I have a Porter Cable framing gun with a constant air stream from the defector. I can't read the model number, but after looking thru the Internet my guess is it's a FR350A. I have used 21 degree...
Air leaking from top of the gun is caused by headvalve orings or trigger valve. Easy fix, remove the head and pop out the headvalve. Remove the orings from headvalve and clean grooves /orings. Reinstall orings and apply plenty of silicone paste lube. If guns holds pressure after cleaning and new silicone paste, order oring kit and have handy when problems start again. If the gun keeps leaking, remove the trigger valve and replace with new or change orings within valve. Good luck
Jun 15, 2011 | Porter Cable Cable No. FC350A Clipped Head...
Was trying to reload nails into my FC350A nailer. My hand slipped and the nail pusher slammed forward. Now I can't move the pusher to add more nails. What's wrong...nothing seems broken
Framing guns are a pain in the ****. It's the coil. Sounds like it broke free or jammed. Only solution is to take it apart. Take your time , not to difficult.
Feb 09, 2011 | Porter Cable Factory-Reconditioned...
I have a Porter Cable FR350A Round head framing nail gun, but I dont have none of the accessories in the box. The manuel extra trigger or what ever else that comes in the carrying box when you puchase a...
Parts /extra trigger for your gun are available at your local dewalt service center or at www.toolpartsdirect.com. Some of the triggers that come with fr350a as standard equipment had a small red button on the side that allowed you to select single shot mode or multiple. If your gun has a black metal trigger, it is better quality/lasts longer than black plastic. Good hollidays
Dec 30, 2010 | Porter Cable FactoryReconditioned DA250BR...
Porter Cable FR350 Round Head Framing Nailer not firing
check and make sure your compressor is at the right psi. 120psi. is there any nails stuck in it. there may also be a problem with the seals.
Mar 08, 2010 | Garden
Porter Cable FC350A air nailer misfiring
first off I would look at the safety to ensure it is not bent and also the driver is not stuck because of a jammed nail. You can go to Dewaltservicenet.com and download a diagram for this tool and start some disassembly of the cylinder area to check for other broken parts. I don't at this point think a rebuild kit is necessary unless it has been awhile since it has been serviced and then yes I would but you I think have some other bent or out of place item.
Oct 30, 2009 | Porter Cable Cable No. FC350A Clipped Head...
Porter Cable clipped head framing nailer with low miles. Driver blade remains fully extended when air pressure is applied. Gun is not recoiling the driver blade at all with air hooked up. Have...
It sounds like the firing valve in the head is stuck. Go to Dewaltservicenet.com and download a breakdown for this tool before doing anything else. The o rings are probably worn or stuck from being dry. Let me know if I can help further
Aug 19, 2009 | Porter Cable Cable No. FC350A Clipped Head...
Air Tools & Compressors Logo
383 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
