Question about Samsung SP43J6HD 43" Television
Showing ghost image on right hand side - Samsung SP43J6HD 43" Television
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 02, 2010
Hp 5550 patchy print
Most of the cases fuser assembly or supplies are causes of ghost image. If image is not properly transferring on media causes transfer roller or ETB.
Do this small exercise: Give print command, wait till paper grabs, once paper entered in cartridge area, power it off, open top & front cover, remove paper and see the print quality.Observed any ghost image what you observed? No ghost image? then problem with fuser assembly..
1.Remove fuser assembly, check any toner particles deposited on surface of fuser transfer roller or heater roller.. if found clean carefully with good cotton cloth while fuser having certain temperature,pl avoid metal & sharp objects to clean..
2. Clean paper path roller(You can observe the rollers to push the paper to reach the destination)
I hope this exercise will resolves the issue..
Jul 26, 2012 | HP Color LaserJet 5550hdn Printer
My TV showing double image on right side
Hello
There are two different signals comes to the the input of your TV, that is to the antenna terminal of your TV. Try reorient or reposition the antenna. This fault is called Ghost image. Changing the position of the antenna can eliminate this. Try it with different directions, and different positions to eliminate this fault, while watching a tranmission signal. OK.
Apr 30, 2011 | Televison & Video
I have a panasonic lumix DMC FZ 45 and I cannot figure out how to take panoramic pictures. When I take pictures of the room or view it just keeps saying next, retake and exit. Can you help please?
Hi. In Scene>panorama assist, a grid is shown on screen and things get confusing!
1. The initial choice needs to be made between
left >right (for a sequence of shots made while 'panning' towards the right)
right >left.
down >up.
up >down.
e.g. if 'left >right' is selected:-
2. After the first shot has been taken, a preview is displayed without the grid.
- the 1st shot can be cancelled with 'retake', or saved for the sequence with 'next'.
3. If 'next' was selected a 'ghost', of what was in the right hand panel of the 1st image, will be shown on the left as an overlay in the LCD display, together with the grid.
The camera can now be panned to the right to try to align the ghost of the right part of the 1st shot with the left side of the new view. The 2nd shot can now be taken,
The combined image is shown, without the grid, which may or may not show good alignment of the 1st and 2nd images - so you can choose to 'retake' the 2nd image, or choose 'next' again.
If you choose 'next', it's back to no.3, above
....and so on until you choose exit, when the sequence can be transfered to PC for stitching with an image editing program.
Hope that helps!
Dec 28, 2010 | Panasonic Cameras
AL 1655CS - We're experiencing ghosting...we've put in new drum and toners...could it be the fuser? Any way to verify the fuser need before we purchase it?
The best way to test for ghosting or Double Imaging caused by the fuser is to run a copy and shut the machine off just as the copy starts to exit the copier. Then open the right side door and open the fuser gate with all the teeth on it. This will release most of the fusing pressure. Gently pull the paper backwards out of the machine. About the bottom 1/2 of the page will have NOT gone thru the fuser yet and you can tell if the ghosting is present. If it is not then the ghosting is coming from the fuser. Note that ghosting caused by the fuser usually does not show up evenly across the whole page. It is usually in bands, lines or one one side or the other.
Good Luck and Thank You for using Fixya.
Sep 24, 2010 | Sharp AL-1655CS Laser Printer
Writing on tv
Ghost problem is mainly come from incoming signals - check cable.
Play a DVD player to make sure the TV works fine.
Aug 12, 2009 | Televison & Video
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Grey shading on TV
If it's still under warranty call 800-243-0000 (LG customer service) and get them to send a technician out from a different shop. After 3 (or maybe it's on the 4th) repair attempts if it's not fixed you can ask for a different TV.
Jan 04, 2008 | LG 42PX5D 42 in. Plasma HDTV
Ghost image
Try changing the toner first it's the most common cause for this fault failing this then it is going to be the fuser unit will need replacing as it is worn.
Thanks J
Dec 12, 2007 | HP LaserJet 2200D Printer
Samsung SP43J6HD 43" Television Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
