Question about Nintendo 64 Console
I'm looking for a nintendo power,adapter cord.
I'm looking for a nintendo power and adapter cord.
  • 903 Answers
You can find power cords for the Nintendo 64 on eBay. Here are some that are for sale right now:
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=nintendo+64+power+cord&_sacat=See-All-Categories
Posted on Jul 11, 2010
My wii will not turn on
Hi,Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
First:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
Second:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
Third:
- it might be cheaper to replace the AC adapter with another one
Fourth:
- get the unit repaired
Thanks and good luck
Jun 03, 2010 | Nintendo Wii Console
Wii console power light is not on. The console is plugged in.
Try the following (this was taken from Nintendo's website and the following link
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
  2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
  3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  4. While you're waiting, check the AC Adapter for the following:
  • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
  • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
Also, see if you have a friend that has a Wii, and try their power cord on your unit. You may have a faulty cord.
Good luck.
Jan 19, 2010 | Nintendo Wii Console
Hello my name is greg and we were having trouble with our electricity and we shut off the wrong sircut breaker and now our WII doesnt turn on but we are unsure if it is the power cord
The best way is checking the power cord with voltmeter or some unit like charger for mobile phone (plug it and look the phone charging).If the power cord is OK plug the Wii AC adapter.If Wii not turn on check the AC adapter with voltmeter.If working the problem is in your Wii console and it need repairing.If AC adapter not work just buy new.
Nov 09, 2009 | Nintendo Wii Console
My wii concole will not power up.
Try unplug the AC adapter from power cord then wait 30 min and plug it again.If this not help you may need a new AC adapter.Look here.
Oct 18, 2009 | Nintendo Wii Console
Wii no power no lights
I copied this from nintendo.com hope this helps you.
No Power
    Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
      1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip). acunplug.png
      3. While you're waiting, unplug/remove all accessories from the system (including game discs, SD Cards, Nintendo GameCube controllers, memory cards, hookup cables, and Sensor Bar). Remove all of these from the outlet and the Wii.
      4. Also check to see that controller cords, AC adapter, and Stereo AV cables/Component Video cables are not frayed and do not have exposed wires. If you find any frayed cords or exposed wires, you should replace those parts.
      5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. Check to see if the power light comes on.
      6. If the system works, plug the Sensor Bar into your system, then turn the system on to see if it still works. Repeat this process with one accessory at a time. If your system doesn't work once you've connected a particular accessory (Sensor Bar, Game Disc Nintendo GameCube controller, Memory Card, SD Card, etc.), there may be something defective with that accessory.
Aug 27, 2009 | Nintendo Wii Console
The WII does not turn on, what do I check to fix it?
First:
Second:
Third:
Fourth:
Hope that helps!
Aug 12, 2009 | Nintendo Wii Console
My Wii console won't turn on.
First:
- THEN, buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Second:
Third:
Fourth:
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
No power
You may try to reset the AC adapter by following steps below.
If the steps above didn't work, I suggest you go at http://www.nintendo.com/consumer/repair/wii_repair_home.jsp?problem=PWRNOPOWER and send the unit and power adapter for repair.
Jul 27, 2009 | Nintendo Wii Console
Lost oem power cord
You need to be sure the actual current supported by the generic universal adapter as some cant fit the requirements of your device so the nintendo will lack of current no matter the voltage you have.
Other thing you must take in consideration is the polarization of the plug as you can put inverse polarization and damage your console. Not like your case as you have a blinking light so looks more like and system error.
Try finding an original data for the current requirements in mA (i.e. 500mA) or the power also works before you make some calculations (i.e. 10w).
Dec 01, 2007 | Video Game Consoles & Games
Nintendo 64 Console Logo
77 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
