Question about Coleman Powermate Premium Plus 6250W Portable Generator
I need to seperate the 10hp Tecumseh engine from the Generator? Best Procedure?
  • don19592000 Feb 02, 2010
    I wish it were that simple. I have removed all bolts including the bolts holding the housing covering the engine output shaft and cannot get this to release. I have opened up the mag side to continue disassembly. How are the two (Gen and Motor crank) shafts mated?
    Problem Solver:
  • 10 Answers
The rotating part of the generator{ rotating fields] is attached to the engine via taper lock. The engine shaft is tapered . you need to remove all generator parts and pieces to expose the rotating fields. Remove the long bolt that goes thru the fields into the engine crank. next take a 3 pound rubber or dead blow hammer and strike the fields(on the metal part) be sure not to hit the winding. This sometimes has to be done several times from both sides with alot of force behind your swing. eventually the taper lock will release. have patient and swing hard.good luck
Posted on Aug 08, 2010
    President:
  • 2,030 Answers
Simply unbolt it...nothing sp[ecial there remove the bolts that hold the generator to the engine housing the remove the bolts the hold the gen to the frame (if any)...REMOVE GENERATOR
Posted on Feb 02, 2010
  • Sean Wright
    Sean Wright Feb 02, 2010
    I believe on that unit they are sleeved together.
What is the recommended oil capacitiy for a pulsar 6000w generator
This unit show to have a 10HP gas engine and thus should have a dip stick where you add oil. Guess 10HP gas engine 1.0-1.5 qts?? You can always drain it and measure. Than add it back...Good Luck
Jan 01, 2017 | Electrical Supplies
Tecumseh model 100 engine 10hp on a coleman powermate generator it starts ok however after about 3 minutes the engine sputters like it is running out of gas and quits.
check the fuel mixture settings i believe main screw is 1 3/4 turns from closed and the idle screw is set at 1 1/4 turns from closed. These settings are for non OHV models. also check that if you have a fuel filter installed that it is not plugged up.
Sep 27, 2009 | Coleman Electrical Supplies
I need the setting for my coleman power generator 10hp tecumseh
If you have fire coming out of the carb, then your intake valve is stuck open. Take the head off, and as you turn the engine, tap on the valve with a plastic screwdriver handle to make it go in, then turn it more to push it back out. If you need to put a light coating of oil on it, so be it. Keep doing this until it's freed up, then put it back together.
Jun 08, 2009 | Coleman Powermate Powermate 5000W...
What carb does the powermate 6875 use?
check this web site http://www.powermate.com/productmanuals.php?cat_id=3 you can down load the manual and parts list for your gen.
Mar 24, 2009 | Coleman Powermate Powermate 5000W...
Generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Mar 16, 2009 | Coleman Powermate Powermate 5000W...
Hard to start and backfires from muffler when running
Sounds like the timing may be off or maybethe exhaust valve maybe hanging open.
Mar 15, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Need carburetor part # 1481K10 for Tecumseh cast-iron sleeve 10hp
you could try a briggs and strtton dealer as they took over generac but think with it being a tecunseh engine you will have a big problem as that side of the company went under a few years back,sorry cant be of more assistance
Dec 21, 2008 | Electrical Supplies
Coleman Powermate Premium Plus 6250W Portable Generator Logo
363 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
