Sql service is not running.please check service an restart program
  • Dracul
    Dracul May 11, 2010
    What version of SQL is it? If it is SQL 2005 or 2008 it could be becuase of a timeout error. you can force the service to reload if it fails after the first or second time by going to your services and adjusting the Recovery Options ( let me know if you need help in doing this ) Also check the System Log for errors, by right clicking My Computer and selecting Manage. Go to Error Logs and Select System. Scroll down until you see a line with an exclamation mark and double click it. Read what it says regarding the error ( do this for all errors until you have found the SQL Error ) and let me know what the errors are.
    Scholar:
  • 63 Answers
First, make sure you are logged in to the computer as somebody with administrator privileges.
If Windows XP, Server, 2000, etc, follow the steps below.
1.click start
2.click run
3.type "services.msc" without the quotes in the text box and hit ENTER
4.Look for SQL in the list of services.
5.Right Click on the Service and choose START or go to properties to change the startup to automatic (will start automatically when computer starts) then start the service.
If Vista, click the Windows Bubble (Where the start menu was previously) and type "services.msc" in the white box with the ghost characters Start Search. Follow the rest of the directions as outlined above, except you will get asked for permission to allow the program, which you will want to allow.
Hope this helps!
Posted on Feb 25, 2010
How to Change SQL Server 2005/2008 User Password
There is one SQL password recovery tool, SQL Password Genius, which would help you to successfully change SQL Server 2005/2008/2012 user password instantly, especially when you couldn't think of other ways for it.
1. Open SQL Server Configuration Management and stop SQL Server Services.
2. Install SQL Password Genius full version and run it on computer.
3. Click "Open File" button to import master.mdf database file into this recovery tool.
4. Select user in list and click "Reset" button.
Instantly, new user password would be available for SQL Server logon after you type new password for user.
Now, SQL Server user password has been changed and you can login into SAL server now. But please remember to restart SQL Server Services before you access to SQL Server with user password.
Jul 04, 2014 | Microsoft SQL Server 2008 Enterprise Full...
Tip
Reset sql sa password directly and efficiently
A few days ago, I had a painful experience that I lost SA password on my MS SQL Server database, and I almost took the whole weekend to look for an efficient way to reset SA password. I asked friends, searched on Internet and even bought some book.... Fortunately, I finally got a SQL server password recovery software and it instantly reset SA password without data loss. And I also got a couple of good solutions for sql sa password reset to save your weekend in case you have lost or forgot MS SQL Server passwords (SA password!).
Option 1 : Use MS SQL Server Password Unlocker to Recover/Reset SA Password
The most direct, efficient way to reset SA password is to take use of the third part utility - SQL server password recovery software. Just two steps:
Step 1: Access to master.mdf file, which is default at C:\Program Files\Microsoft SQL Server\MSSQL\Data\master.mdf
Step 2: Select SA password and reset SA password
So, Reset SA password successfully!
Option 2 : Recover or Reset SA Password with Other SQL Server Login
If there is any other SQL Server Login that is a member of sysadmin role, you can log in using that account and reset SA password of SQL Server. Reset sql sa password as described here :
SQL SERVER - Reset Password of SA Login Using Management Studio.
Login into SQL Server using Windows Authentication.
In Object Explorer, open Security folder, open Logins folder. Right Click on
SA account and go to Properties.
Reset SA password, and confirm it. Click OK.
Make sure to restart the SQL Server and all its services and test new password by log into system using SA login and new password.
Option 3 : Recover or Reset SA Password with Windows Login that is a member of Windows Admin Group
If there is any other Windows Login that is a member of Windows Admin Group, log in using that account. Start SQL Server in Single User Mode as described followings :
SQL SERVER - Start SQL Server Instance in Single User Mode.
There are certain situation when user wants to start SQL Server Engine in "single user" mode from the start up.
To start SQL Server in single user mode is very simple procedure as displayed below.
Go to SQL Server Configuration Manager and click on SQL Server 2005 Services. Click on desired SQL Server instance and right click go to properties. On the Advance table enter param '-m;' before existing params in Startup Parameters box.
Make sure that you entered semi-comma after -m. Once that is completed, restart SQL Server services to take this in effect. Once this is done, now you will be only able to connect SQL Server using sqlcmd.
on Oct 05, 2010 | Computers & Internet
Tip
The easiest way to reset sql sa password.
无标题文档 The easiest way to reset sql sa password. One of my friends complained that: I am not a sql db manager by any means but I've been asked to reset sa password for a sql 2005 server. My concern is ...will changing this password have any effect on applications that use sql 2005. They use Micro CRM 3.0, and I don't want to disrupt their service. The reason they want to reset the password is because they recently bought a new accounting package that will tie into CRM, and the technicians are requesting the password to complete the install.
In fact, MS SQL Server Password Unlocker can reset sql password in no snap! Just install the sa password recovery program on the computer where the sql master.mdf is saved. MS SQL Server Password Unlocker accesses to the master.mdf file directly and lists all the users to the database. For accessing the master.mdf smoothly, the password recovery program detects and stops the running SQL Services automatically
on Mar 17, 2010 | Computers & Internet
Forgot SQL Server SA password. How to reset user password to login SQL Server?
When SA password for SQL Server logon forgot, please take SQL Password Genius to install it on computer.
Step 1: Run SQL Password Genius full version and browse Master.mdf file to import into it.
Step 2: Select SA user and click "Reset" button.
After master database file imported into SQL Password Genius, you would see all user in list. SA password is unknown. Select SA account and click "Reset" button.
A new window would pop up, type new password for SA account in it. And click "OK". Instantly, SA password is changed successfully. SA password lists in software screen.
Step 3: Close SQL Password Genius and restart SQL Server Services.
SQL Server services influence SQL password reset on computer. So we stop it before using SQL Password Genius. Now, when you finish SQL SA password reset, restart SQL Server Services to run SQL Server with SA account.
How to Reset SA and Other User Passwords for SQL Server
Jun 27, 2014 | Microsoft SQL Server 2005 Enterprise...
How can i fix the problem by error message 262,level 14,state 1,line 1 CREATE DATABASE permission denied in database 'master' in sql server 2005
RecoveryFix for SQL server database recovery utility is a very powerful utilty to fastly short out your all problems to MS SQL database. By using this application, user can simply repair SQL database. Read more: http://www.sqlrecovery.org/download.html
For more information read this post: http://diskdatarecovery.jimdo.com/2013/07/23/how-to-restore-lost-data-on-server-while-running-sql-server/
Jun 22, 2010 | Microsoft SQL Server 2005 Enterprise...
Hay Bahratt, I have uninstalled the 3 SQL programs in the control panel a few times with no effect on the issue. I didn't try moving directory C:\Program Files\Microsoft SQL Server\MSSQL to another...
If you have removed it from control panel, its done. You just have to clean up any left over registry entries using CCleaner and then try installing again
http://www.ccleaner.com/download
You may also want to check out this microsoft link if it doesn;t work
http://office.microsoft.com/en-us/help/HP011128601033.aspx
Jan 10, 2010 | Computers & Internet
How to configure the sql server 2005
Enable remote connections for SQL Server 2005 Express or SQL Server 2005 Developer Edition loadTOCNode(2, 'moreinformation'); You must enable remote connections for each instance of SQL Server 2005 that you want to connect to from a remote computer. To do this, follow these steps:
  1. Click Start, point to Programs, point to Microsoft SQL Server 2005, point to Configuration Tools, and then click SQL Server Surface Area Configuration.
  2. On the SQL Server 2005 Surface Area Configuration page, click Surface Area Configuration for Services and Connections.
  3. On the Surface Area Configuration for Services and Connections page, expand Database Engine, click Remote Connections, click Local and remote connections, click the appropriate protocol to enable for your environment, and then click Apply.
    Note Click OK when you receive the following message:Changes to Connection Settings will not take effect until you restart the Database Engine service.
  4. On the Surface Area Configuration for Services and Connections page, expand Database Engine, click Service, click Stop, wait until the MSSQLSERVER service stops, and then click Start to restart the MSSQLSERVER service.
Feb 28, 2009 | Microsoft Visual Studio 2005 Professional...
I have installed sql-server management studio at Win-XP professional.. but it is while run this it is looking for LOCAL SERVER... but it is unable to find any local server at my system.... pls solve my...
First of all you need to be sure that when you installed sql server you also checked Database server. I assume you have.
Then you need to check if SQL is running.
You have to go to start and type services.msc in the search field.
then you have a list of services. go down to sql server and check if its running.
Now go to sql management studio and connect to your local server.
You also might have a instance name. like local server\sql express or an other name.
Jan 03, 2009 | Computers & Internet
Sql service restart
  • Hi, from the Desktop, (right, click) on the Taskbar, or press (CTRL+ALT+DEL) to open the Task Manager. Next in the (Tasks Man...) window, press the Services (tab), at the bottom of the window, click on the (Services...) button, the services open. Next scroll to find: SQL Server... and the InstallDriver Table...these will be services of interest to "Enable, and or "Start," also check the "Dependencies" of the services. Select "Apply and OK" once started. The next area you may want to check is the Computer Management, Type: (comp...) in the Start Search "window". Look in the Internet Info...Serv...(IIS)... "Providers category." "You may what to restart the computer, some services require ("rebooting") to "configurate" correctly." "If this helped, feedback is appreciated, thanks"
Dec 30, 2008 | InstallShield Update Service Version 3
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
