I need solution
I have printer panasonic kx p 1180. Window XP has driver. Micro chips
near ribbon in this position : number 6 up; all others: down. But, not work
not print. What happend?
    Genius:
  • 1,011 Answers
Hello Sir,
U check this site for ur problem
http://www.printer-drivers.com/drivers/62/62518.htm
It will be helpful. ok
Don't forget to comment
Good luck
Cheers!!!!!
Posted on Feb 20, 2008
Can't find printer driver for panasonic kx-p1121 windows xp
HI.................... NEED Panasonic KX KX-P1121 Printer Drivers???
panasonic_091012_021220_128.png NOTICE: Panasonic's current KX KX-P1121 driver release resolves driver conflicts, improves your computer's stability and restores communication with all KX Printers. The newly released KX KX-P1121 drivers are a high priority update recommended for all Panasonic users.
Description Version Estimated Download Time KX KX-P1121 Driver
(Includes, WHQL certified drivers)
Current as of
(Sep 26 2011) 56K: ~9m
512K: < 1m download.pngDownload
Installation Instructions:
  1. Click above Download link or Click here to begin installer download.
  2. Click "Run" ("Save As") if using Firefox
  3. Click "Run" Again
  4. Follow on-screen prompts to complete installation.
Important: If you are using Firefox or Netscape as your browser, you will be directed to save the application "to disk" (we recommend that you save the application to your desktop).
We recommend that you save it to your desktop and initiate the free scan using the desktop icon. Should you choose not to save the application, you may simply initiate the free scan by clicking the "Run" button on the File Download Window.
You can also search for a specific driver below:
Locating updated drivers is easy! driver_manufacturer_123.png driver_select_4.png Download Drivers New Version Of Windows? No Problem!
Upgrade smoothly by finding the correct drivers for your KX KX-P1121 printer for Windows XP, Windows Vista or Windows 7. For the first time, users can upgrade with confidence knowing that their computer will run smoothly thanks to the latest drivers and updates required for a perfect upgrade.
Why Updating Drivers Is Important
Usually the only reason we look to install or update drivers is because something is malfunctioning. This is not the only reason you should keep your drivers up to date however. Panasonic is constantly tuning and improving performance of their KX KX-P1121 printers and the only way to make use of this is by having the latest drivers. Going online and checking for new drivers all the time can be frustrating and is not an effective use of your time, and a simple tool like the driver installer above can keep all of your hardware running on the optimal drivers with top performance.
Sometimes when new hardware is installed, although it works correctly, other hardware which interacts with it may not be, because the other hardware actually needs its own drivers updated. This kind of co-dependency is another common problem and a reason why it's a great idea to have a tool that is constantly monitoring the state of all of your drivers and updating appropriately so you can upgrade and add or remove components in your computer while continuing to run without a hitch.
When your KX printer is relatively new, it may be possible to download individual drivers directly from Panasonic without incurring additional charges. If you are having problems locating the correct drivers for your Printer printer, or are unsure of the exact model, we suggest you run a system KX scan first. It's very important you know the exact model of your Panasonic KX KX-P1121 printer you would like to update to ensure that it will function properly and to prevent possible damage to your system. Click here to download an installer that will automatically scan and identify your Panasonic to make sure you are installing the correct update and will also locate and download any additional driver and bios updates your pc may need.
recommended.png Install the latest KX driver updates now.
  • Automatically Updates Panasonic KX Printer drivers and all orther missing or out of date drivers using advanced scan technology.
  • Instant access to unlimited device drivers.
  • Starightfoward and intuitive interface
  • Better PC performance and improved stability
  • Access to the largest drivers database in the industry
  • Continous updates for the latest manufacturer drivers
  • Unlimited free technical supports with our 24x7 technicians
HERE IS THE LINK OF DOWNLOADED FILE.....................
http://xpdrivers.com/printer/panasonic/kx/kx-p1121/_5_5908.cfm
GOOD LUCK..................
Sep 26, 2011 | Office Equipment & Supplies
Need Win 7 32bit Driver for Fax and Printer for Panasonic KX FM 131
Sorry no driver Window 7 for yourPanasonic Fax-Printer just for 9x--/ME/NT4/2000 and XP
Jan 10, 2011 | Panasonic Computers & Internet
Panasonic KX-P 1180 cannot print properly with win XP Pro SP2
when you loaded the driver did you select the correct port? many times I get calls where they hooked upto a certain plug in but chose the wrong port parallel needs the lpt1 port and if there are more then one listed it could be a higher number..lpt2...lpt3. goto the driver in printers and faxes and right click the chose properties then the ports tab and pick the port.
Jul 08, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Driver needed for panasonic kxp1124i printer
I found this at the bottom of the page at this Panasonic Website: http://panasonic.net/pcc/products/printer/windows_compliance/windows_xp_sp2.html
Ron
  • Regarding the following printers, Printer Drivers are included in Windows XP CD-ROM as standard
Category Model Monochrome Laser Printer KX-P4410, KX-P4420, KX-P4430, KX-P4440, KX-P4450, KX-P4410i, KX-P4451, KX-P4455, KX-P5400, KX-P5410, KX-P6500(PCL) Dot Matrix Printer KX-P1081, KX-P1121, KX-P1123, KX-P1124, KX-P1124i, KX-P1150, KX-P1170, KX-P1180, KX-P1624, KX-P1695, KX-P2023, KX-P2123, KX-P2124, KX-P2130, KX-P2180, KX-P2624, KX-P3123, KX-P3624
Mar 16, 2009 | Panasonic Office Equipment & Supplies
Need driver
can i get software of kx-flb802cx
Nov 10, 2008 | Panasonic KX-FLB801 All-In-One Laser...
56 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
