Question about Whirlpool Duet GHW9150P Front Load Washer
Clothes are getting torn in the washer. How do
Clothes are getting torn in the washer. How do you prevent that. Some items have even had chunks torn off of the garmet.
    Habit-Forming:
  • 84 Answers
Check the fins in the washer,and run your hand in the washer make sure there is nothing caught in the basket
Posted on Feb 06, 2010
Will not spin the clothes dry it's seem it is not balanced ?
You may have One wet heavy item (one sweatshirt or one bath towel) that is not evenly dispersed within the wash tub, and this will prevent the machine from reaching and completing the spin cycle.
Jul 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Clothes getting burnt & torn in maytag front loading washer...how to resolve this issue asap?
Check the inside of the drum. Chances are, there is a sharp object pointing out that is doing this.
Jan 13, 2014 | Maytag EPIC MFW9700S Front Load Washer
My Bush A146q washing machine keeps tearing clothes.
Run your hand round the inner drum and look for sharp edges, also overloading causes torn clothing
Oct 04, 2017 | AEG Washing Machines
Have whirpool Duet dryer....leaves brown streaks just like everyone else's. What do I do to fix the problem? Can I do it or am I going to have to pay someone? Company should have a FREE kit to repair....it...
Hello there:
If your clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore HE2t front load washer model #11047561604 serial # HLY1661717 I'm trying to wash a load of clothes and it's giving me a message F21 and it is flashing, I un- plug the washer and try to...
The F21 error code indicates a long drain. Here are some tips that should help you resolve this problem:
  • Check your washer drain to make sure that it is draining properly.
  • Check the drain hose for kinks and clogs. Make sure that it is installed properly per the instructions in your owner's manual. An improperly installed drain hose can prevent the washer from draining properly.
  • Check for excessive suds in the washer tub. Excessive suds can prevent the washer from draining properly and will result in the F21 code. Make sure that you are using the proper amount of HE (High Efficiency) detergent to prevent excessive suds.
Remove any clothes and then use a wet/dry shop vac to drain any water out of the washer.
Arrange shallow pans and/or towel in front of the large item filter shown in the second image below to catch residual water when you remove this filter.Remove the large item filter as shown below. It is likely that you will find a clog in this area that is preventing your washer from draining.
If you do not find any clog or restriction in the large item filter and none of the other issues discussed above apply to your situation, then you could have a failed drain pump. If the pump is damaged and will not pump out water then it will need to be replaced.
Aug 17, 2010 | Kenmore Washing Machines
Hair on clothing in washer
No there isn`t a lot you can do about this unfortunately. A simple shaking of your clothes may eliminate any surface hair. And if desired, for certain hair attracted items I would even runs a vacuum or a lint brush over the hairiest items. If you didn`t get the hair back on your clothes after the wash it would most deffinelty restrict or stop your pump.hope this helps.
Thanks
Oct 12, 2009 | Kenmore 23822 Top Load Washer
Black carbon/soot on the door and lint filter of my dryer
I have the same problem with a Maytag Performa gas dryer. My husband took our dryer apart and found that the burner tube which leads from the burner to the back of the dryer was full of soot (which was getting blown back into the dryer drum with the hot air.) We are cleaning it out now but would like to know how to prevent this from recurring in the future.
Dec 16, 2008 | Kenmore 62602 Electric Dryer
Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
Dec 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Burnt lines
Your problem is a bad rear drum seal-if these become worn, torn, or missing close can get caught torn or discolored in the space between the clothes drum and rear of the dryer. Replace the rear drum seal.
Aug 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
Jun 02, 2006 | GE WSM2700D Top Load Stacked Washer /...
Whirlpool Duet GHW9150P Front Load Washer Logo
301 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
