Question about Toshiba Portege M700-S7002 Tablet PC
Computer keeps slowing down like a caching problem. Must be hard disk
  • danderson986 Feb 02, 2010
    The computer has done a full checkdisk, malware and virus checking, disk cleanup, removed startup programs. Computer runs really fast for awhile and as the day goes on it becomes more sluggish. We are using the Toshiba Portege as a wireless laptop. The real problem is the guy who has this computer crashed his hard drive. I replaced his hard drive with another drive from identical laptop. Did all of the configuring to make it run faster. Now he says it is fast but then slows down. Once you reboot it starts to run fast again. Not sure how to clear cache or something like that since it seems like something bogs it down.
    tried this will let you know.
  • 4,281 Answers
For that when you power up the computer press F8 key then if you are able to see safe mode and other menu then enter in safe mode.
Then go to start menu ->run type in "chkdsk /r" then press ok then restart computer then it fix errors on harddrive.
But if you are not able see windows logo and safe mode menu when you press F8 then open back panel of laptop if you have desktop then open cpu cover then reseat the RAM memory.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Feb 02, 2010
  • You need to increase virtual memory.
    For that right click on my computer icon then click on property.
    Then go to Advanced then Click on performarmance settings.Then click on advanced then click on change virtual memory Then custom size then set initial size to max size Then apply and ok.Then it works fast.
    Also remove all temp files and run again "chkdsk /r" command without "" then it recovers error on harddrive.Then it speedup again.
My tablet is running very slow and freezing. I can't clear cache
Hi, I hope you have anti-virus on it. You may have adware on it that is slowing it down. Do that first. Download Malwarebytes the free version and run it. I bet you will find lots of junk in there. Hope this helps you. Good luck.
Feb 11, 2018 | Tablets & eReaders
My tablet has started running really slow and sometimes freezes up. How can I fix?
hi Debbie.
The cache on your Samsung tablet is designed to make things run smoothly. But over time, it can become bloated and cause slowdown. Clear out the cache of individual apps in the App Menu or click Settings > Storage > Cached data to clean all app caches with one tap.
Speed up a slow Samsung tablet - Which Computing Helpdesk
https://computing.which.co.uk/hc/en-gb/.../209878085-Speed-up-a-slow-Samsung-tablet
How do I make my tablet run faster?Turn off or reduce animations. You can make your Android device feel snappier by reducing or turning off some of animations. You'll need to enable Developer options in order to do this. Go to Settings > About phone and scroll down to the System section to look for Build number.6 Aug 201411 tricks to make your Android run faster - Android Authorityhttps://www.androidauthority.com/11-tricks-make-android-run-faster-414542/Search for: How do I make my tablet run faster?
or go to this link should help you out some more.
tablet running really slow Google Search
Nov 26, 2017 | Tablets & eReaders
Asus zenpad10 tablet stuck in fastboot mode
KEEP HOLDING THE POWER BUTTON UNTIL YOUR PHONES SWITCHES OFF OR PULL OUT THE BATTERY DIRECTLY(If Required) to exit the FAST BOOT MODE and then start your phone normally by pressing only the power button.
Also in case you were trying to enter the recovery mode to wipe cache or hard reset then keep holding the power button and volume DOWN button until you get vibration and release the power button and keep holding the volume DOWN button to enter RECOVERY.
Jun 16, 2017 | ASUS Tablets & eReaders
Why is My Pyle astro tablet has slow responding after I downloaded some apps
A cleaner program might help. I like ccleaner. After you download it and run it . It will say analyse and. Clean. Tap the analyse button and it will show you how much cache has built up in your files and is s!owing down your machine.Think of a drawer with things just thrown in it and after organizing it there is much more room. Works the same in a computer. I hope this helps.
May 12, 2016 | Tablets & eReaders
How do I fix the freezing of keyboard and slow process.
It helps to wipe the cache partition every now and then if your device is a bit sluggish. This helps for better performance.
press the VOLUME UP + POWER buttons all the same time and HOLD THEM DOWN. release only the POWER button when the device vibrates. release the other buttons when the ANDROID SYSTEM RECOVERY screen appears. using the VOLUME DOWN / UP buttons to navigate, select WIPE CACHE PARTITION. After that is complete select reboot system and the device should start
Jan 17, 2016 | Tablets & eReaders
WHY MY TABLET FREEZE AND NOT MOVING
FIX Slow, Frozen, Android CRASHES! Cache/RAM TIPS ...
? 7:50
https://www.youtube.com/watch?v=bKt3UEBpD44
Aug 31, 2013 - Uploaded by p1nesap
And no, adding yet another app is NOT the answer! ... So if your Samsung Galaxy phone or Nexus tablet is ...
Android Tablet stuck on boot screen ! Bypass it in easy steps ...
? 4:36
https://www.youtube.com/watch?v=HErn0-GcQqE
Jan 4, 2014 - Uploaded by My Tablet Guru
1) Press the volume up or volume down or home button when thetablet start, this is hit and trial method and ...
Device keeps crashing, freezing, or restarting ' T-Mobile ...
Dec 29, 2015 | Tablets & eReaders
The screen will not work on my tablet everytime I try to swipe or touch something its like its froze up how do I fix it
Press the Power button longer until your tablet shuts down. If you can restart it, find a cache cleaner software to clear the cache for more space. Sometimes, the cache takes up nearly all the available space from the tablet's ROM. This slows down the tablet considerably and also causes malfunctioning of the OS.
Jan 23, 2015 | Tablets & eReaders
My sony viao pcgn505a is very slow when i open it. It has also a samok virus and very slow internet connection. Please help how to reformat it and where to get drivers for it. Thanks.
I would suggest try avoiding formatting. Because if you do that, then the next problem you will face is to find, download and install all the drivers.
If you are using the Genuine Windows operating system, then download 'Microsoft Security Essentials' for free from the Microsoft website. This should take care of your viruses.
Second get the latest Service pack provided by Microsoft and this should update the drivers.
And basic things, like removing unnecessary files, Defrag you hard disk, etc should also add up to the speed.
Mar 25, 2010 | Tablets & eReaders
Set up did not find any hard disk drivers installed on computer
Your notebook has SATA hdd. Got into the bios (keep pressing F2 key on startup) then in the bios screen find HDD and press enter. Select IDE mode. Press f10 to save changes and exit. When this is done install XP.
Alternatively connect external usb floppy drive and unzip sata drivers into that. When booting from xp cd press f6 to load drivers.Follow onscreen instructions to load drivers and continue xp installation.
Please let me know if issue not solved for futher ts steps.
thanx
May 28, 2009 | Fujitsu LIFEBOOK P1510D Tablet PC
Computer running slow
Hi;
Running slow few possibilities:
You need more RAM memory -cheap to buy off ebay,
Hard disk space running low - cheap again on ebay,
If its running slow because you are running a high graphics application then you may need a better Graphics card. But ultimatley it will com down to those and finally your CPU and motherboard.. but by then it would be ccheaper for you to buy a newer system.. Again thats cheap from ebay too.
I hope this helps, please don't forget to rate my solution.
Thanks.
Mar 15, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba Portege M700-S7002  Tablet PC Logo
82 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
