Question about Akai PDP-4216M 42 in. Plasma Television
Akai Plasma 42 no signal
Akai Plasma 42" tv - power went out during a storm tv now reads no signal...put another tv into cable box and it works fine.
SOURCE: Akai Plasma 42" PDP4294
sounds like time for a class action lawsuit.. mine went blank too.. and it seems like everyone with this model is having the same problem.. i wonder if akai has a solution i'll call them tomorrow.
Posted on Jun 04, 2007
  • 298 Answers
SOURCE: help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Posted on Apr 16, 2008
SOURCE: Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Posted on Aug 05, 2008
ron1235
  • 11 Answers
SOURCE: Need a pedestal stand for an AKAI 42" Plasma
do you have the small feet as shown in the picture? are they in your closet?
ebay?
Posted on Nov 30, 2008
SOURCE: Akai TV repeatedly turns off and on
Yeah. I had the same problem. About 1 month ago my AKAI PDP4273M1 TV began turning off...then on. I happened to stumble on a temporary solution. I held one of the buttons down on the t.v. without letting go...and what do you know....the tv stayed on. So I rigged it to where the button (the "source" button) stayed in and I stuck a small object into the hole next to it (a small nail in my case). The catch is you have to use the remote becase none of the buttons on the tv work. Wonderful...so...I got that fixed and then today my picture gave out about 75 percent. What a Piece of S%#* TV. That is all I can say. My 2 1/2 year old TV is a POS and is going into the dump. Can you say hello to a new VIZIO. Hope that helps. Remember. NEVER BUY AKAI TV PRODUCTS AGAIN!!!!!
Posted on Mar 08, 2009
I have a panosonic plasma 42 inch tv. After a storm all I get when I turn it on is black and white static but all the menus display fine
Look to see if the rear video/audio inputs work (DVD etc) and if they do the damage is at the tuner in the set (nearby lightening can discharge into the cable or wires for signal.)
If using a box (cable or satellite) it may have took the hit.
A good idea if lightening storm is to not only unplug set (static discharge can come in via the power cord also) but disconnect signal source from set.
I have in extreme cases seen a nearby strike get in via the power lines and destroy almost every appliance plugged in even if not on.
Dec 14, 2012 | Televison & Video
I have A three year old AKAI 42 inch plasma tv---PDP4273M1---Mostly used as PC monitor. It was working just fine when I turned it off. When turned back on the next day, the on indicator light came on and...
Check to see what input setting the tv is on. It could still be looking for a signal from the pc input connection and no pc is hooked up thus getting no signal. Have the device you are trying to display on the tv connected and turned on and cycle through the inputs on the tv until you get a signal.
Sep 07, 2010 | Akai PDP-4216M 42 in. Plasma Television
Hi, my problem with tv emerson plasma 42 etv4206pdp it does not turn on, after rainy and lighting day. i check the main power area and cant find anything grong. i dont know what else to do. if you had a...
It might have been blown out by the lightening storm. that happened to two of my tvs that were plugged in during a lightening storm. they both, and two dvd players, would not work after, but the ones that were not plugged in were fine. You should unplug your major electronic equipment during a storm, unless you have a power surge plug/equipment.
Oct 04, 2009 | Emerson EWL3706 37 in. LCD Television
I have a Akai DVDrw125. I've never been able to connect it between the cable signal in and the TV. It has S-Video in and S-Video out. The manual is worthless. I shouldn't have to switch the S-video cable...
The way I have it set up - cable box out to AKAI cable in, video and audio out of AKAI into TV via RCA. AKAI on channel 3, tv on RCA input. Change channels on Cable box, works fine. To watch a video, just put it in an hit play. Might have to change sources on AKAI if this is not working for u.
Mar 03, 2009 | Akai DVDRW120 DVD Recorder
Dell plasma 42 inch
fot the most part, you have solved your problem (pow bd), The main bd may also need to be replaced as well. The is a signal upon powering up the system. the pow bd communicates with the signal board. The signal bd, also is responsible for ALL of your additional I/O lines. Between the two of these, + a firmware update, i think the tv will be just fine.
Feb 03, 2009 | Dell W4201C 42 in. Plasma HDTV
Cant afford cable box need help
depending on if the dvd player has functions such as video input , but not likely
if the plasma only has certain video inputs and not the cable input you could use the vcr to get the signal
Oct 09, 2008 | Akai PDP4225M 42 in. Plasma Television
No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Aug 04, 2008 | Insignia 42" LCD Flat-Panel HDTV
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Akai PDP-4216M 42 in. Plasma Television Logo
47 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
