Question about Bose Wave Radio
Wave radio emits intensely loud high pitch noise when switched on
My wave radio gen 1 now emits an intensely loud high pitched note when we switch on. This started with no warning after we were away on vacation. No problem before. Radio was off during this time, and no apparent signs of a power surge elsewhere in house.
There is no way to turn down the volume on this sound - it is so loud it hurts your ears. Only way to kill it is to hit the on-off button again.
There is no reset button I can see. It doesn't matter if radio is on AM or FM or AUX setting - the radio doesn't play the radio, just this very loud noise.
4 Suggested Answers
DigidocTN
  • 22 Answers
SOURCE: Bose Wave Radio AWR1 1W
I can tell you what to check if you know how to use an ohmmeter. But I warn you you could get shocked if you do not know what you are doing. The transformer has 3 windings, two are for DC voltages, and the other is 3V AC.Your meter can measure those using the AC scale. Next, check the voltage on the 3 terminal regulator IC. One leg will have 18V, the output will have 10V. Again please use CAUTION! Finally, the to-92 transistor Q1 is used as a 5V regulator. Check it (with power off and unplugged) for any shorts, especially base-emitter. If non of these ideas work, I would offer to buy your non working unit if you decide to get rid of it.
Posted on Jun 30, 2009
  • 3287 Answers
SOURCE: Just installed a Bose Wave system, but the radio
There is probably a source of interference near the radio. Move the radio into another room and tune 96.1 again. If the interference is still present, try again - further away still. You should be able to find a place in your home that the interference is not present. If you are unable to find such a location, try another radio tuned to the same frequency and repeat the steps above. If the interference is present on the new radio - there is an electrical device nearby (not the radio) that is causing the noise.
You could try a battery operated radio (not plugged into the outlet) to determine if the noise is coming into the radio via antenna - or by the power cord. If the noise is gone, the problem is on the wiring in your home. It could be caused by any appliance in your home - or from the utility itself. You'll have to go around unplugging everything (or shutting circuit breakers off) one by one until you find the source. Don't forget to plug the radio into a different circuit after you've gone thru every circuit - just in case it was plugged into the circuit that was the source of the noise.
IF the noise was present while on battery power, the above test will help determine if the noise source in your house, too. You may have to contact the utility about the noise problem - or it may be a problem within a neighbor's home too. Walk around with a battery operated radio on 96.1 and listen for a stronger sounding noise from the speaker. The closer you get to the source will provide a louder sound.
I hope this helps! Good luck!
Posted on Aug 23, 2010
rockmeister
  • 2047 Answers
SOURCE: Bose Wave Radio, Model AWR1-1W When turned on
Loud buzz is usually caused by static and radio interference in radios. If none of this is affecting you unit presently there there is a probability that some cables which aid the fm antenna in receiving stations this could act as static which brings about the buzz on the unit. Either way it is caused by interference on the fm receiver end and all you have to do is get that serviced and the problem is solved.
Hope this solution has been helpful?
Posted on Dec 30, 2010
I have a Dell Latitude D630. When the laptop is switched on it emits a high pitched scream and will not boot. I disabled microphone in BIOS and machine boots fine. Re-enabled microphone and same probl
It sounds like a driver problem, normally the microphone is off on-boot-up. It should only be opened by a program wanting to use it.
Have you tried turning it off in the operating system, rather than the BIOS?
Download the correct drive here.
Product Support Dell US
Feb 11, 2015 | Dell Latitude D630 Laptop Computer PC...
Samsung DLP HLN5065WX/XAA
that's from a thermal switch, to keep the innards cool, post use. Seems to me that you might just check to see that all vents are open and clear of debris, for starters.
May 07, 2008 | Televison & Video
Cassette deck high pitched noise when playing
Sometimes this is caused by the record circuit being activated due to some kind of faulty switch. At other times it's caused by a fault on the pre-amp circuit. Possibly in the power supply to it. Perhaps a faulty capacitor?
Dec 09, 2013 | Audio Players & Recorders
My laptop charger, after about 1 and a half years of use, has begun to make a strange, high pitched noise and refuses to charge my laptop.
In most modern laptop chargers, this high pitched sound it emitted when a "safety switch" has been activated in the charger. It is possible that there may have been damage to one of the components in the charger. The only solution is to replace the charger.
Mar 30, 2011 | Sony Vaio PCG FR415S Laptop AC Adapter...
Philips HTS3450 - high pitched humming noise until warmed up
Jeremy,
Read one of my posts:
I used a hairdryer and blew hot air into the grill on the bottom of the subwoofer enclosure which reduced the delay time from ~1hr to 5 minutes. (The high pitched noise was still there for about 1-2 minutes)
Oct 16, 2009 | Philips HTS3450 System
Panasonic TX32POL1 high pitched noise
The high pitch sound is comming from a power supply transformer that will resonate (or vibrate) at the operating frequency (12-14KHz).
This is usually affordable to repair -at least worth the estimate.
Oct 14, 2009 | Televison & Video
High pitch sqealing noise
This is caused be a bad record switch. As a temporary solution, incert a blank tape, push the record switch, then stop. Repeat about 10 times. This may clean the contacts of the record/Play switch but it will probably need to be replaced.
May 20, 2008 | Panasonic RR-830 Desktop Cassette...
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
High pitch sound being emitted
It could be a harmonic noise caused by dust inside the monitor. If you are qualified (brave enough) to remove the back cover, blow the entire inside of the monitor out with compressed air (carefully) that may help. It could also be the flyback transformer. In that case, you would have to have the transformer replaced (I wouldn't recommend doing it yourself unless you are a TV technican as the CRT can contain a static charge of 14,000-25,000 volts- even when unplugged)
Oct 15, 2006 | Philips SoHo 107T21 (White) 17" CRT...
High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Jun 13, 2006 | Smeg FAB28
Bose Wave Radio Logo
366 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
