Laptop died!!! My laptop worked fine when I turned it off but now it will not come on at all. I have been told I may need a battery -do you know if all power goes through the battery even if it is plugged in? The cheapest battery I have found is 190.00 online, do you have any suggestions. my laptop is a model Balance 557S. Even to ac no light, no noise nothing, Ialso have another one and tried the battery from it and it still did not work. power button will not cut it on. Can't find any one to work on it.
It i use my ibm r40 battery power,just around 5 minute only well shotdown
Posted on Mar 29, 2008
  • 19,396 Answers
More than a battery you may need a power adpter or you may need to fix something else. The laptop should work even with no battery inside when connected to power adapter. However, a faulty battery may prevent the computer from starting. Remove battery and try to start laptop with power connected. If it does not work you ll need to troubleshoot the problem further. If you need a cheaper battery or power supply you can try checking on ebay.
regards
Posted on Feb 19, 2008
Hi, I really need some help. I want to know whats wrong before taking my hp pavllion dv600 to service centre. Problem is that the charger doesn?t charge the battery at all. Charger is fine with other...
If the power supply does not run the laptop without the battery, then the problem is the jack in the laptop, over time the plug breaks free of the motherboard causing intermittent operation or no power. If the power supply runs the laptop without the battery, it is the charging circuits on the motherboard that is the issue.
Jan 04, 2011 | Computers & Internet
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Inspiron 600m laptop flashes the red light at the bottom of screen as if it needs charged, but it is 100% charged and is not hot or anything. It flashed red three times then green. I powed down unplugged...
when you use battery power, does the laptop work or does the battery die right away try letting the battery die itself, like use the laptop till it dies then charge it up again
Apr 05, 2010 | Dell Inspiron 600M Notebook
Dell 710M laptop won't work with battery
hi thanks for using fixya!
If your laptop is working exclusively on AC power and battery is seems to be useless, I suggest that you purchase a new battery for your laptop.
If you need further assistance, let me know
Apr 27, 2009 | Dell Inspiron 710m Notebook
NEC ultralite SL/25C with not start up batteries(cmos, bridge)new
try to remove the battery and plug into AC.
you can also try to recharge your battery (if it is still working well) for a few hours before turning the laptop on.
let us know.
Feb 07, 2009 | NEC Versa VX Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
Laptop died!!!
u got a serious problem with ur laptop:
i duuno how that occur but u got a short circuit problem.
this may solve the problem try to sctratch the nozzles of the battery and the nozzels of the laptop and see what happen
if that not work u need to give it to a repair guy
cuz all the laptops turn on with adpter
good luck
Aug 16, 2008 | Dell Inspiron 9400 Notebook
Laptop died!!!
heyo....if you have to litterally hold the plug at the back of the computer...you will need to have the jack wires fixed. There should be a light indicator showing that it is plugged in and recharging what you hold it....if that turns off if you let go, it is the jack....that is a flag to get it repaired.......or use a lot of duct tape. :-)
Wayne
Jan 01, 2008 | Acer Aspire 3100-1405 Notebook
Toshiba Satellite R15-S822 will not turn on
toshiba batteries, not all .. but many just have problems ...
try this ...
pop the battery out ...  and plug in the ac w/o the battery in place ... if this works .. you need a new battery ...
otherwise .. try another battery ( same model , of course ) if this works ... you need a new battery
look up your battery on toshiba and/or sony's website (battery recall program)
that's all i can think of right now .. let me know if any of this helps
Nov 22, 2007 | Toshiba Satellite R15-S822 Tablet PC
Laptop died!!!
THe power controller in a laptop manages both AC power and battery. A laptop can power on without a battery as long as it is connected to the charger. That's because both battery and AC power have same power specifications. If the laptop fails to power from AC charger, then you may have an internal hardware failure. If no LED's flash, no light and no noise is made when you connect the charger, the problem is most likely to be a simple one, a faulty connector or something like. First of all, please specify me, what laptop model you have, and, exactly, what does it do when you connect the AC charger.
Feb 13, 2007 | Balance CN6555 Notebook
Computers & Internet Logo
167 people viewed this question
Alun Cox
David Payne
David Payne
