Question about Kenmore 22422 Top Load Washer
Water leaking from underneath,even when water is off
  • 5,911 Answers
If you have a leak, the most common cause is a worn drain pump, leaking drain hoses, leaking dispenser hoses coming from the water inlet valve, or the hose to the air dome has come loose. You will need to remove the exterior case of the washer to be sure. DO NOT attempt to lay the washer on its back. The gearcase (transmission) contains oil and it may leak out through the breather hole.
The following link explains how to inspect your washer for leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the drain pump is leaking, it is not serviceable and must be replaced, the following link explains how to replace one:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts (if required) may be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare.
Read through the instructions provided and let me know if you need further assistance. Please post back with a complete MODEL NUMBER so that I may be able to povide you with better assistance. I hope this help you.
NOTE: For future reference, if you would like to a have a complete repair manual for this model washer, Repairclinic.com has a one available for Whirlpool manufactured direct-drive washers (includes Kenmore) for about $20. The item number is 1170635.
Posted on Feb 02, 2010
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Samsung dishwasher leaking from bottom
Whenever this happens to me, there is food/debris covering the plastic mesh screen that covers where the water exits underneath. It starts dripping because, with it clogged/impaired, the water inside rises slightly and starts leaking out of the bottom front door seal. After I clean up the debis (and sometimes there is debris near/in the drain itself - that's why the mesh pops off so that you can get to it), the leaking stops. I also put a new foam seal on the bottom of the door (just added self-sticking insulating foam strip like you would use on a front door of a house, right on top of the lame seal that was already there), worked great. Good luck.
Jan 25, 2018 | Samsung Dishwashers
Machine leaks water after the final spin cycle even though a significant amount of water is pumped out.
Could be a hose split or leaking underneath or even the pump might be leaking,check hoses going to the taps also.
Apr 11, 2016 | Washing Machines
Power vent rheem mod pvw50 underneath is leaking
You have a water leak coming out of side of tank?
Water heater must be replaced. It is rusted, and could rupture.
Inspect and replace anode rod to prevent rusted tank, so water heater will last longer.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 09, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Keurig special edition leaking water underneath
Reset and Descale with mix of soulutions Page 18 Manual.
May 15, 2012 | Keurig Special Edition B60 Coffee Maker
Water leaks from bottom of freezer side even though the water is turned off. Also makes a humming noise prior to leak. Leaks about every 3 days.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 22, 2010 | Maytag MZD2766GES Side by Side...
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
Water leaking from underneath fridge
If you have a ice maker inside your freezer, check where the water connects to the back. I think you will find a leaking connection. Tighten connection to fix the leak.
Please rate this solution
Sep 06, 2009 | Frigidaire Refrigerators
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Slow leak from the water dispenser
water or switch i beleave is the water valve
Dec 18, 2008 | Kenmore 53082 / 53084 Side by Side...
Kenmore 22422 Top Load Washer Logo
122 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
