Question about Dell 966 All-In-One InkJet Printer
Hi my name is lionel whenever i try sending a fax line error message comes up fax does not go what is the problem. thanks
    Scholar:
  • 185 Answers
To activate it you should install the fax program. this will require that you register your fax adress.
this is a requirement of utilizing the system of sending and recieving Fax.
Just fill in the information as requested, and it will register your Fax adress.
As soon as you hav ecompleted this,you will be able to send and recieve fax,
and no more error messages, unless ther is a technical problem.
Posted on Feb 02, 2010
Sending fax error message."Phone
No. Most of the time this "phone line error" can be caused by the telephone connection or issue on the phone line where the fax machine is connected.
Hope this will help.
Mar 27, 2011 | Office Equipment & Supplies
The fax appears to dial the number successfully. The receiving fax is turned on. It apprears to try for a long time. The error report says "no answer."
It is not your fax line is the other party.did you try any other number?
Post back.
Solution one: Perform a fax line test Perform a fax line test to check whether the fax line is properly connected. Step one: Run a Fax Test
  1. Press the Setup button (c01395353.jpg ) on the product control panel.
  2. Use the Arrow keys (c01073166.jpg ) to select Service , select Fax Service , select Run Fax Test , and then press OK . The Fax Test prints.
    • If the report passes, try to resend the fax.
    • If the report fails with the message 'Fail - the phone line is not active,' plug the cable into a working telephone jack, and then try to resend the fax.
    • If the report fails with the message 'Fail - the cord is in the wrong port,' continue to 'Step two: Change the cable to the correct port.'
Step two: Change the cable to the correct port Make sure the telephone cable is inserted in the correct port. Remove the cord for the fax line from the port labeled with a telephone, and then insert it into the correct port. Figure 1: Fax portsc01756259.gif Scanner error message The message 'Scanner error ' displays on the product control panel while sending a fax. Solution: Check paper size This product only supports paper less than 381 mm (15 in). Use only letter, A4, or legal sized paper for sending faxes. To send this fax, copy or print the original document onto shorter paper, and then resend.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 10, 2010 | HP Laserjet M1319F Laser Multifunction...
I am having trouble faxing documents. Whenever I
Hi, you can check that your phone connection from your 7420 to line works. Listen for a dial tone in a phone connected to your mfc7420. If not, your tel comm module could be at fault.
Jul 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
Sendidng a fax
I have been sending and receiving faxes for over a year on my Lexmark X6100 printer. Now whenever I try to send a fax it will say it is sending the pages but then waits for a redial. After doing the same thing a second time it will print out "remote fax error"
Aug 11, 2008 | Lexmark X4270 All-In-One InkJet Printer
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Hi, Remote Fax Error being displayed
What happens if you dial the remote fax number as a voice call on another phone? Does that number pick up? Does it give you the modem handshake noise? If not, the remote side has a problem.
Can you fax other numbers? What happens when you dial your own fax line from another phone? If your fax does not pick up and talk to you, your fax may have a problem.
Jul 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
Paper jam, error message, fax send comes out not ledgable.
Code 43 is a line error according to Panasonic.
I had this issue trying to send to a client yet I could send faxes to other #'s. So in my case it was a dead fax on the other end of the line.
Jun 13, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Error message
Try to send the fax at a different time when telephone line conditions have improved.
Or try to disable the ECM on yuor printer, to do that to these steps:
Press SETUP
Press DOWN until you ADVANCE FAX SETUP displays
Press OK
Press DOWN until ERROR CORRECTION MODE displays
Press OK
Press RIGHT ARROW to turn it off
Press OK
Then try to send new fax. If this does not resolved your issue pls try to go to your phone provider. Thanks
Oct 26, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Jun 25, 2007 | Canon L120 Fax Laser Printer
Dell 966 All-In-One InkJet Printer Logo
127 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
