Question about Polar F11 Heart Rate Monitor
Polar watch screen is stuck on "own zone" and won't move no matter what buttons i hold or push
3 Suggested Answers
escapement
  • 2334 Answers
SOURCE: I have a Polar F11.
You have to change battery.
Posted on Mar 23, 2009
landsend
  • 1066 Answers
SOURCE: my michele watch chronograph is stuck
Have a watchmaker fix it...there isn't anything you can do.
Posted on Mar 24, 2009
How to set time on polar rs300x
Access watch settings scrolling by UP/Down button.
<Settings> <Ok> <Watch> <Time and Date Settings>
In Time Settings:
Set the local time (Time 1) and a time difference to it (Time 2).
With Time zone, you can select which time zone is used.
In Time view, you can easily change the time zone from Time 1 to Time 2 by pressing and holding DOWN.
Set the date with Date setting.
You can also download the user manual from the link below
http://www.polar.com/e_manuals/RS300X/Polar_RS300X_user_manual_English.pdf
Oct 06, 2015 | Polar RS300X Watch
Tip
How to set/ change time on Polar F6.
Having trouble setting the time with your Polar F-Series watch, here is simple quick step-by-step guide to follow.
First know your buttons:
upper right - Scroll
lower right - Scroll
center right - choose
lower left - reverse/ back/ stop
upper left - light
#1 - Push the center right button (exercise will appear)
#2 - Push the upper right button (settings will appear) use the upper right or lower right buttons to scroll if neccessary
#3 - Push the center button (a menu will appear)
#4 - choose Watch, use the upper right or lower right buttons to scroll if neccessary
#5 - Push the center button to choose watch, once highlighted
#6 - use the upper right or lower right buttons to scroll through the watch menu
#7 - Choose Time
#8 - Continue to use center button and scroll buttons to choose and set.
Important button to know - the bottom left button is a reverse button. Make a mistake, just tap that button, keep tapping to go all the way back to the main menu.
on Dec 22, 2010 | Polar F6 Wrist Watch
How to set led watch
What make and model of watch is this?
Sep 08, 2011 | Watches
Got "memory failed" measage on
push red button for 15-25 sec
Feb 17, 2011 | Polar S-725 Wrist Watch
How do I change the time on my fossil watch dq1185
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done.
Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
Jan 25, 2011 | Fossil Watches
Curtis and Co. Big Time 3 zone watch w/ temp gauge. What does the stem positioned at aprox 10 O'clock control? It is near the temp guage but does not seem to control anything.
Crown(stem) at 10 O'clock has air inlet for temperature, does not move. Crown at 8 O'clock is for setting 3rd time zone next to it. The two buttons on the right of the case, above and below, set 2nd time zone which is at the 6 O'clock position of the large dial. To set #2 push top button till min. hand moves 1 min., then push bottom button to move 1 min each time or hold for rapid movement. Large crown sets date and large dial. Unscrew it (counterclockwise) then pull out to first click, then set date turning crown clockwise, continue to pull out till 3rd click which is where you set the time on the large dial.
Dec 29, 2010 | Bulova Watch
How do I set the time?
For a complete manual visit my tips and tricks page.
The time is under: Settings>Watch
To access settings push either of the right side buttons from the main default screen
Push the red button
use the right buttons again to scroll to watch
Push the red button
Right buttons again to choose time
Push red button
The Right side buttons scroll through choices, the red button is your chooser/ confirmation button. The left side bottom button will return you to a previous screen.
All other settings can be changed in the same way.
Dec 09, 2010 | Polar S150 Heart Rate Monitor
Have a Polar CE0537 S725 watch.I want to reset my time and all the other settings,please help.
If you go to my Tips and Tricks page, there is a link to the manuals for all Polar watches, including the S725.
To reset anything you need to access SETTINGS. On the S-Series watches push either the top right or bottom right buttons until you see the screen that says settings. Then push the red button to choose. use the right buttons again to scroll to the area you want to set. Keep repeating for every function you want to change.
As an alternative, the S725 connects to software that would have come with your watch, if you are connected to the computer through this software you can reset settings from the software and import them to your watch. The specifics of this are in the user manual.
Dec 07, 2010 | Polar S410 Heart Rate Monitor
Hi there, simple question but its driving me crazy but how do I change the time on my Polar F6???
Simple: from the default time screen. Push either of the right side buttons until you see settings.
From settings: Choose Watch.
From watch choose time set.
To get the complete manual visit my tips and tricks page.
Nov 12, 2010 | Polar F6 Wrist Watch
Polar F11 Heart Rate Monitor Logo
Top Polar Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Jerry Greenberg
Jerry Greenberg
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
