Question about Garden
Stihl chainsaw 028 wb will not start it has spark, but always floods, I cleaned the air cleaner
  • dontbother10
    dontbother10 May 11, 2010
    Remove clean and reinstall the muffler. Most flooding problems are a failure to follow the start procedure as outlined in the manual. Once it attempts to start open the choke or similar is almost always overlooked in the start procedure. If not the problem reply below and we will look deeper. HTH Lou
  • dontbother10
    How long have you had this saw? Clean the muffler. You can reply below.
  • 677 Answers
Does the saw have a lot of hours on it ? What is the fuel mix you are using, Stihl recommend 40:1
You may need a CARB KIT.
Posted on Feb 05, 2010
Stihl 028WB Starts on first pull then stalls and will not restart
Its getting fuel because of the start every time you will thinking, also the fuel hoses are properly? tank airation ok ? you looked the hose but it will mostly are rigidly in the corners where the connections are if you there to draw firm because the fuel goes otherwise back in the tank if if it there air can be come in you will not see that the hoses only looking is not enough they are porous in high priority I should replace in all any cases the hoses after this kind of age and also buy a service-kit for the carburetor will also sit irrevocably dirt in it and especially in view of the pulsing membrane where the float needle is operated by the material can be hard and dry. and can be rip.
Beware on the model and machine number in priority if you order in your Country parts for your carburetor because there are used 2 brands of carburetors Tillotson or the famous Walbro WT-16b by the Stihl model 028 ATTENTION i can see only the parts and numbers of model 028 attention by this the images are not off the 028 WB the WB behind it its not in my list therefore i can not give you the correct information they are maybe not selled in our Country or is not anymore in service. the partnumbers may also be different in your Country look if it was running the same way and if it has not succeed , remove the sparkplug but connected it again with the cable and ground it to push the plug on a metal place and pull the trigger look at the colour of the spark if you see a little spark it must be having a very light blue spark sometimes you can hear the spark if thats the power is very good . if its spark is red colored replace the ignition coil but only if you have seen it by a using a new correct type of sparkplug in priority.Try first to replace the sparkplug and if that will not help then there could be a problem like a thermical problem with the ignition coil. control also the on -off button and cableisolation is not damaged and all parts are good functional.
Dec 29, 2015 | Garden
Why no power To mY 028 wb chainsaw?
Time to rebuild the carb it sounds like. You didn't give me much to go on, so please give me a few more details.
Oct 12, 2014 | Stihl Garden
Stihl chainsaw problems
Adjust the high speed screw on carb
Install a new spark plug
Use fresh fuel
Aug 05, 2014 | Stihl Garden
Stihl 028 chainsaw runs good for awile then bogs and dies
Check fuel filter, fuel tank vent and possibly clean carb and replace carb diaphrams
Feb 12, 2014 | Stihl 028 Chainsaw Crank & Case
Has spark but want start
028 is the size ofm a Stihl brand chainsaw.
Jul 30, 2012 | Garden
Where do I find a operators manuel for Stihl 028 WB?
GO ONLINE TO STIHL AND THEY HAVE A PDF SECTION YOU CAN DOWN LOAD OR PRINT
Dec 31, 2010 | Garden
028 wb how do you gap the points with the flywheel removed
You need a cam tool--probably easier to see your Stihl dealer and have them set the points. Good luck!
May 04, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Engine wont run.Stihl 028 chainsaw.
Remove and clean the exhaust port, muffler and spark arrestor screen. Also clean the air filter.
Apr 05, 2009 | Garden
Garden Logo
1,668 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
