Savin Printer Just leased a brand new Savin printer (CLP240D). And already have an error. The error title is "SD Card authentication failed". Not sure what that means beyond a memory card issue. I tried to print to it, but I can't find it on the network any more. I'm currently on Mac OSX running the latest OS. I would appreciate amy wisdom. Thanks so much! Jason
    President:
  • 2,072 Answers
There are initialization cards with printers. They look like credit cards or odd shaped key cards.
They need to be inserted into a slot reader on the machine to activate or reactivate them.
It should have come with the printer.
Posted on Feb 19, 2008
How do i fix module authentication has failed error sc 866 on Ricoh Mpc 3002
SD card authentication error
A correct license is not found in the SD card.
? SD-card data is corrupted.
1. Store correct data in the SD card.
Feb 10, 2016 | Ricoh Aficio Office Equipment & Supplies
My Samsung ssp-2040 printer cannot read my xd memory card. The xd card is type H and it works fine with my Olympus camera. When I put the card on the printer it says that there is card reading error and I...
The SD cards go up to and including 2 Giga byte.
The SCHC cards are more than 2 Giga Byte up to and 32 Giga byte
The SDXC cards are more than 32 Giga byte up to and including 2 Tera byte.
The cards not only differ in capacity, but also differ in working voltages and signalling voltages.
You can find all specifications of SD cards on the internet, but some computer knowledge and a little knowledge of electronics would be nice to read these papers.
If your printer is compatible with SD and or SDHC, but not with SDXC, you can't use the card, because the devices capable of using SDXC cards also can use SD and SDHC. Devices capable of using SDHC, also can use SD cards but can't use SDXC cards. and devices made for SD cards only can work with SD cards.
Devices are downward compatible with the cards.
Oct 21, 2014 | Samsung Office Equipment & Supplies
1. When trying to load Toshiba 4GB SD HC memory card I get error message, "memory card is not set. Insert the card after checking the direction." Doe snot occur with SanDisc 512MB card. ...
You were right to try another card to see if it would work. Some brands of SD card will not work with all brands of printer. Also, check that the SD card is of the right type and size to work with your printer.
Jan 31, 2011 | Canon Pixma iP6600D InkJet Photo Printer
Savin 9945DPE cannot Network print
Did you format the new drive through the service mode on the copier? As long as the drive is compatible then it should work once you format it.
Jan 03, 2010 | Office Equipment & Supplies
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Sep 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
Savin 9925DP multifunction unit. Printer does not initialize. Is there a way to reboot to factory settings? Thanks
IF YOU GO INTO THE SP MODE VIA CLEAR ALL THEN 107 AND HOLD THE STOP BUTTON TEH SCREEN SHOULD CHANGE GO INTO THE PRINTER SP AND YOU CN INITIALIZE FROM THERE // YOU WILL HAVE TO RE-ENTER YOUR IP AND NETWORK CONFIG AGAIN AFTER.. YOU CAN ALSO TRY TAKING THE NETWORK CARD OUT START COPIER WITHOUT AND THEN REINSTALL.. IF YOU TSKE THE SD CARD AND MEMORY OUT AND TRY A REBOOT THEN PUT THEM BACK IN THIS MIGHT ALSO HELP RESET YOU WILL GET ERRORS BUT YOU CAN RESET THESE AFTER.. GOOD LUCK IF YOU NEED MORE INFO LET ME KNOW
Jul 02, 2009 | Savin Office Equipment & Supplies
Modem fail errors between hp 4345 and savin mfp device
On fax settings set ECM to ON, JBIG to OFF, MAX BAUD RATE to 14.4, V34 to OFF then upgrade to latest firmware and make sure phone line is a 2-line phone line (look plug end of line and there should only be 2 metal strips on connector)
Mar 26, 2009 | HP LaserJet 4345mfp Printer
Memory card error
Memory cards larger than 2 GB are not supported with Photosmart printers
Jan 01, 2009 | HP Photosmart D7160 InkJet Printer
Micro SD card
Open your computer scan w/ anti virus that SD card /try insert again to your printer .
Jan 05, 2008 | Epson Stylus Photo® RX620 InkJet Printer
198 people viewed this question
jasbo
jasbo
