Question about Garden
Stihl 024AV chainsaw- no oil pumping with to bar with new pump.
I have a Stihl 024AV chainsaw with the last 5 months. It has been running perfect up until just before Chrismtas. The oil pump stopped sending oil to the guide bar the last week before Christmas. I knew something was wrong as the bar and chain together started whining out for oil. After bringing it to a dealer, he replaced the pump, saying that a few of the teeth on the pump worm wheel had been damaged. Despite the new pump, there is no oil coming out and although I have brought the saw back to my main dealer, we cannot find the problem. Can you please help me? I am a college student and I need a saw 4 days a week to work with. All help is much appreciated.
  • lindsay836
    lindsay836 May 11, 2010
    Start at the oil tank, is oil flowing fom tank to pump ?
    Are the pump oil holes open ?
    You can also run a little air pressure to make sure.
  • dontbother10
    dontbother10 May 11, 2010
    Let me restate what you are saying. You took it to a professional that can touch and feel the saw. He cannot repair it. You want us to magically see over the Internet what he cannot with the saw in his hands? Try a different professional or give him a little time to solve your problem. Either way without a magic wand we cannot be any help. Do you see that? It was a Stihl Dealer correct? Using certified Stihl mechanics?
    Champion:
  • 243 Answers
On bottomside of thesaw is a adjustscrew for chainoil turn it out complete and blow out lines. make sure the holes in de sawblade are open have to take off whole blade. also check plate. on the under the blade, where oilchannel is coming out. good luck
Posted on Feb 11, 2010
Why does my stihl chain saw stall when I tilt it. Also it has a problem pushing the chain oil out to the bar
You never stated what model you're referring to. The running issue when tilted could be a fuel tank vent problem. Replace if necessary.
The oiling problem could be a number of things, check the bar groove is clean, check the oil pick up body inside the oil tank, check the oil pump/ oil worm if it has one (don't know what model yours is) check the feed line between the oil pump and where it exits to feed the bar.
Apr 07, 2016 | Stihl Garden
How do I disassemble bar oiler and tank on unidentified chainsaw?
Stihl 017& 018 repair to bar oiling system, showing oil pump ...
? 12:36
www.youtube.com/watch?v=lJFAmUz49DQ
Jan 1, 2014 - Uploaded by Andy Reynolds A common fault with the Stihl 017 and 018 is low or no oil getting ... 018 repair to bar oiling system, showing oil pump feed andoil tank removal.
Sep 30, 2015 | Garden
Stihl chain saw 024 AV , chain does not get oil
run it with the bar off and see if it pumps oil. I have drained oil tank and cleaned with gas(no run) then replaced with lite oil , run no chain and got them going ,or then gingerly run wire into oil hole and got them going, otherwise its tear apart time. If oil does come out, then clean your bar and your cover and use bar chain oil.
Mar 01, 2015 | Stihl 024av
Oil is not getting to the chain with a stihl 012av chainsaw.
I'm almost sure you have to remove the oil tank and then the oiler
Nov 26, 2014 | Stihl Garden
How do I replace oil pump on stihl ms310 chainsaw
Your oil pump works with your clutch and crankshaft. Remove clutch and you will see the cover that hides the oiler. remove cover then oiler and replace with new
Oct 03, 2014 | Stihl Ms310 Ms290 Ms390 Complkete Starter...
How to replace oil pump in stihl 031 chainsaw ?
Remove the worm, sealing ring and washer, loosen the pan head screws on the oil pump and replace. Check if the gasket is re-usable.
Jun 11, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
No pilcoming through 009 stihl chainsaw
Check to make sure the pick up line in the tank hasn't come lose. Then check the port under the bar and cover is free and clear of debris. If that's not it you probably need a new pump.
Jan 29, 2014 | Stihl Garden
Have a stihl MS180 and it is not pumping any oil out of the hole and slot that makes contact with the bar. How do you remove the oil pump?
To remove the oil pump you need the following:
Assembly tool 1123 890 2200 Removing oil pump Puller 1130 893 1400 Installer 1130 893 1500
I would recommend trying to clean out the oiler first.
Please comment on this and tell us what type of oil you were using. There are rumors of wrong oil clogging or wearing the oilers. Was it used motor oil? Thanks Joe
Feb 16, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Bar not recieving oil
The problem is related to the internal oil pump. The followings are the possibilities:
  • Clogged line from the oil reservoir to the pump.
  • Clogged line between the oil pump and the chainsaw bar orifice.
  • Faulty oil pump itself (common in well used/old device).
Hope it helps.
Jul 28, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
2.0 Cubic Inch Montgomery Ward gas chain saw, 10 inch cutting bar
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Oct 26, 2009 | Garden
Garden Logo
726 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
