Question about Thermador SC302T Electric Double Oven
Thermador Built-in oven model cm301
F-24 is flashing on the control panel.  The instruction manual says to shut circuit off for 20 min, however that did not do anything.  Any suggestions? Jeff
  • cherylpace Nov 30, 2008
    I have same problem. It just started a week ago and it is driving me nuts. I flip the breaker switch off for several minutes, then turn it back on. The oven will work for a while (a couple hours or one day at a time) but last night in the middle of cooking potatoes, it started beeping and shut the oven off. I had to finish the potatoes in the microwave.
    I need a new gas cooktop and was VERY seriously thinking of buying the Thermador this January but after reading all the internet posts on Thermador service, I absolutely will not. I will probably buy Viking now.
    I will call a serviceman and let you know what I find out.
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Posted on Nov 21, 2008
My 15 y/o Thermadore C3O1US oven began beeping whenever it was cooling down after cooking a meal. Most of the time it would eventually display error code F24. I tried letting it cool down, setting the temp to 100 to keep the cooling blower running. It helped a little, but still a nuisance. The controller was no longer available anywhere, including Ebay. I tried repair shops but none of them could help. Out of desperation, I removed the electronics panel and thoroughly blew it out with compressed air. I tested it by running the oven cleaning cycle, and no beeping. It has been fine ever since.
Posted on Jan 22, 2016
Frigidaire oven temperature unreliable.
Is this an electric oven? Sound like a bad breaker to me if it is.
Dec 22, 2016 | Frigidaire Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
F82 error
door switch not sensing properly or a bad power relay board.
Oct 01, 2012 | Thermador Ovens
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
F7 and beeping
oven starts to beep and shuts off. I shut the circuit breaker off and it re sets itself and hopefully when I power it up it will start to work. We have replaced the front panel and all th PC boards and reset the reset button behind the panel. If there was a was that I could disconnect the shut off that's built in I would keep the oven.
When this oven work, it's great however at this time i am losing patience and maybe I should toss it out and get a new oven which I really don't want to do!
I am very capable of taking it out and opening up the panel an re setting all the boards once again if that would help? Thermador has had a recall on this unit as some people claim it will overheat and go on fire? The stove has little mileage on it and we would like to keep it but if you have a way of fixing it or if not we would love to hear from you! .
Mar 20, 2011 | Thermador C302U Electric Double Oven
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
How do i self clean
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following products. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of Product: Thermador� Built-In Ovens
Units: About 37,000 (42,000 built-in ovens were previously recalled in June 2007)
Manufacturer: BSH Home Appliances Corp., of Huntington Beach, Calif.
Hazard: The ovens can have gaps in the insulation where overheating can occur and when used in the self-cleaning mode it can cause nearby cabinets to catch fire. This poses a fire hazard to consumers.
Incidents/Injuries: BSH Home Appliances has received three additional reports of incidents, including two that resulted in fires that damaged surrounding cabinets. No injuries have been reported.
Description: The recall involves Thermador Brand built-in double ovens with model numbers C272B, C302B, SEC272,C301U, SEC302, SECD272 and SECD302 and serial numbers between FD8403 through FD8701. Model and serial numbers are located on the underside of the control panel.
Sold at: Appliance and specialty stores nationwide from June 2004 through July 2007 for between $3,000 and $4,400.
Manufactured in: United States
Remedy: Consumers should immediately stop using the oven�s self-cleaning mode and contact the firm to schedule an inspection and free repair, if necessary.
Consumer Contact: For additional information, contact Thermador at (800) 701-5230 24 hours/day, 7 days/week, or visit the firm�s Web site at www.thermador.com
Dec 05, 2010 | Thermador C301U Electric Single Oven
Hi I need the operating instructions for an aeg cooker pnc 944 185 047. ive set the time but I cant work out the timeing settings it keeps switching off after about 20 mins and turns its self back on...
hi you can get instructions fron serviceforce.co.uk . follow the instruction link and enter pnc no. however i think your problem is a controling stat for the cooling fan if the fan does not switch on the oven overheats the cabinet and switches off like you describe. its located in the wiring loom behind the control panel. the part is 899661927356-9 costs circa £26. hope this helps
Nov 21, 2010 | Ovens
Flashing on oven F54 shut off oven at circit
HI. This code is an indication of a shorted upper door latch circuit. This could have be caused by a malfunctioning relay board.
The necessary actions are to gain access to the upper door latch assembly, and test the circuit with a meter. Use the procedure below.
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. Set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use caution when testing.
NOTE_ If the upper door latch switch passes the test, simply replace the relay board.
Jan 01, 2010 | Thermador Ovens
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
1,592 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
