Question about Reddy Heater-30-55,000 BTU Variable
I'm getting no spark from the spark plug...reulting in no fireing up
  • 77 Answers
Probably the transformer has failed. Take the transformer with you to a heater dealer to have it checked/replaced.
Posted on Feb 03, 2010
Why my 1996 cadillac fleetwood brougham not getting any fire to the engine?
Your question needs some additional details. Are you sure that it is not getting fire to the cylinders or are you just using the term "not getting fire" because you are not getting any response from the engine when trying to start the car? Does the engine turn over? I would assume that it probably does based on your question. If your engine turns over then the first diagnostic step to see if you are getting "fire" (spark) to the cylinders is:
- Remove a spark plug wire and remove the corresponding spark plug.
- Put the spark plug wire back on the spark plug.
- Now hold the spark plug thread against a metal part of the engine
- You may want to use rubber gripped pliers to hold the spark plug
- Have someone turn over the engine.
- Watch the end of the plug to see if you are getting a spark jumping the gap to the ground electrode (little metal arm suspended in the air at the end of the spark plug).
- If you are getting spark then you are getting fire and your issue is most likely fuel related or timing (spark synchronization to the cylinder cycle).
- If you are not getting spark, then you have electronic/electrical issues
Let me know what you find out...
Aug 08, 2014 | Vehicle Parts & Accessories
Spark plugs carboning up
Very critical, if the plug is the wrong reach and hotter or colder than specified the bike's performance will be affected. I would suggest getting an iridium plug of the correct heat range for your Harley D. Your user manual or local stockist will tell you the normal plug to use for your bike. The manual will if applicable list plugs of different heat ranges to cater for engine mods etc. A point to take note of: - plugs by different manufacturers are specific to themselves. No 2 brands of plug are the same. Similar they maybe but not identical, and this is where you can go wrong. Also you cannot mix plug brands or types. Hope this helps
Apr 08, 2014 | Harley Davidson FLSTF - FLSTFI Fat Boy...
No spark to engine 1991 ford pickup
It can be faulty or dirty spark plug itselfd.Also for reference get the fuel level checked.Is the fuel tank is empty or near to empty.
Try cleaning the spark plugs and then see if that is helpin.On some cases the black carbon layer gets collected on the spark plugs and that causes the problem,so cleaning the plugs help.But if its not helping,then spark plug has to be replaced.Spark plugs get power from ignition coil to ignite sparks.If ignitioncoils are faulty then also there will no spark.--------------
To troubleshot and confirm the issue,i suggest you to go through the help links provided below,check the procedure and it will help you to confirm the issue in your case.
Click the link below:------
Car cranks, has spark but will not ?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
How to Perform a Basic Engine Tune Up-Spark Plug and Wire Change
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up_01.html
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How does the spark plug wire go on the distributor cap in 1991 Mitsubishi Mighty?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
No spark on 2008 Chevy Avalanche?
http://schematicsdiagram.blogspot.in/2012/04/no-spark-on-2008-chevy-avalanche.html
How does the spark plug wire go on the distributor cap in 1985 Pontiac sunbird?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wire-go-on.html
Ford Plug Wires Not Coming out?
http://whoisbyme.blogspot.in/2012/06/ford-plug-wires-not-coming-out.html
Ford explorer has no spark?
http://schematicsdiagram.blogspot.com/2011/12/ford-explorer-has-no-spark.html
Chevy impala spark plug firing order diagrams?
http://technoanswers.blogspot.in/2012/02/chevy-impala-spark-plug-firing-order.html
How to gap spark plug on Chevy Impala?
http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for chevy impala?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
Chevy s-10 blazer 4.3l Spark Plug Firing Order?
http://howtobyme.blogspot.com/2011/12/chevy-s-10-blazer-43l-spark-plug-firing.html
1982 dodge rampage Spark plugs Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/1982-dodge-rampage-spark-plug-firing.html
2006 Suzuki Forenza Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
1983 Ford Ranger Spark plug firing order?
http://schematicsdiagram.blogspot.com/2011/12/1983-ford-ranger-spark-plug-firing.html
Firing Order for 1991 Lexus ES 250?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1991-lexus-es-250.html
Firing order for 1992 Chevrolet 5.0 engine?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1992-chevrolet-50.html
How to identify number one spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How to remove rear spark plugs on 1991 Buick Regal?
http://howtobyme.blogspot.in/2012/02/how-to-remove-rear-spark-plugs-on-1991.html
These details will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
Not getting spark out of spark plugs
For spark plug problem, click the help links provided below: ---
Car has no spark?
Car cranks, has spark but will not start?
How to gap spark plug ? http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for?
How does the spark plug wire go on the distributor cap?
This will help.
Thanks.
May 28, 2012 | 1996 Ford Contour
1994 mitsubishi expo not getting a spark to spark plugs
Car has no spark?
This will help.
Thanks.
May 11, 2012 | 1994 Mitsubishi Expo
Engine missing wont fire properly, i think its the spark plugs how do i change them ?
CHANGE SPARK PLUGS.YOU NEED SPARK PLUG 3/8 SOCKET.YOU NEED SHORT AND LONG 3/8 EXTENSIONS.YOU NEED SPARK PLUG BOOT PULLER AND A SPARK PLUG GAUGE SET THE SPARK PLUG GAP.NOW CHANGE 1 SPARK PLUG AT A TIME SO YOU MIX THEM UP GET FIRING ORDER MIX UP CAR BACK FIRE WONT CRANK.ALSO CHANGE PLUG WIRES ALSO.
Nov 10, 2010 | 1994 Honda Civic
Firing Order diagram for 2006 Ford Explorer
Hope this helps. The ignition coil:
  • changes low-voltage pulses from the PCM to high-voltage pulses.
  • fires 2 spark plugs simultaneously.
  • has 3 transformers.
    • One transformer fires the spark plugs for cylinders 1 and 5
    • One transformer fires the spark plugs for cylinders 2 and 6
    • One transformer fires the spark plugs for cylinders 3 and 4
Spark plug wires:
  • carry high-voltage pulses from the ignition coil to the spark plugs.
The spark plugs:
  • change high-voltage pulses to spark at the gap, which ignites the fuel and air mixture.
The firing order is 1-4-2-5-3-6.
Jun 06, 2010 | 2006 Ford Explorer
Reddy Heater-30-55,000 BTU Variable Logo
97 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
