Question about HP Photosmart 3210 Printer
My HP 3210 the paper not feeding
With my HP 3210 all in one......although the feed roller spins, it does not pull paper in...therefore claims I need to "add paper"......with the hex screws on this printer, I can not pull it apart to investigate......any other ideas?
I have exactly same problem, is it an automtic "buy a new one" syndrome
Posted on Feb 05, 2010
The paper doesn't want to feed when I print.
I have a HP3210 and it would not feed photo paper (HP brand) and I put a small amount of the fingertip moistener (the same type of stuff a bank teller uses to count bills) on the two feed rollers that are seen from the back of the printer and it seems to have solved the problem. The product used is SortKwik, and it was purchased at Office Depot. HP service reps were of no help and did not seem to care..their only solution was to buy a new printer!
Jun 09, 2010 | HP Photosmart 3210 Printer
When feeding my paper it keeps pulling the paper
You need to replace the feed rollers. One side is probably worn. You should be able to buy a rebuild kit for it. Try ebay.
Nov 02, 2009 | Lexmark X2600 InkJet Printer
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Manually feeding paper
Even if manual feeding is an option the paper must be able to fit the paper tray in order to feed it through the printer.
Jan 20, 2009 | HP Photosmart 3210 Printer
HP Photosmart 3210xi All in one printer will not print 4x6 photos
Have you processed many print jobs through this printer? if so, you might be needed a maintenance kit. the kit will include new rollers that will help pull the paper into the proper feed paths.
Apr 30, 2008 | HP Photosmart 3210 Printer
Can't Print
HP Paper Feed Cleaning Kit - Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00754199&lc=en&cc=us&dlc=en&product=439488&rule=584&lang=en
ou may not have the paper width set snug to the paper to feed correctly.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00553862&lc=en&cc=us&dlc=en&product=439488&rule=584&lang=en
Consult http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00601439&cc=us&lc=en&dlc=en&product=439488 regarding "out of paper" errors Paper cleaning kit is included in this article.
Apr 19, 2008 | HP Photosmart 3210 Printer
Paper jam
I tried the Cleaning Kit HP sent me. At the time they didn't mention that it required a direct USB hookup rather than the Network setup I was using.
Another user suggested using Lighter Fluid sprayed on the defective (too hard) paper feed wheels. Crazy solution? Lighter Fluid is mainly Naptha which the user claims softens rubber.
I tried it last night and waited for the fluid to evaporate before plugging the printer in. I really expected the darned thing to go up in flames so I had a pot of water and a blanket nearby as a fire precaution.
Much to my surprise .. the PSC 3210 has been feeding sheets perfectly for the past two days! This is after sitting in a HOT attic abandoned for over a year! I had to replace one ink cartridge which had dried out completely.
I don't know how long this "fix" will continue working but Lighter Fluid is cheap. The PSC 3210 is a quality printer WHEN it prints. It's too bad HP created so much bad will in its customer base because of defective rubber paper feed wheels. I've avoided purchasing HP products for two years now and have warned others to stay away because of this fault with customer service. Instead of replacing the defective rollers in my original printer, they exchanged the printer for a refurbished printer with the same defective rollers!
Mar 31, 2008 | HP Photosmart 3210 Printer
Paper feed problem
Check all this-----
1.check the printer paper feed roller jam.
2.check the paper sensor, It is working or not.
3.check the paper tray(clean it)
4.service the printer, (If possible).
Goodluck
Mar 10, 2008 | HP Photosmart 3210 Printer
Hp 3210
The grab roller needs roughing up. go to www fixyourownprinter .com to find out how to do this
Aug 12, 2007 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer Logo
219 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
