Question about Maytag MER5775Q Electric Kitchen Range
How to change oven coil - Maytag MER5775Q Electric Kitchen Range
  • Maytag Master
  • 8,220 Answers
Unplug the stove. Be sure to kill power to the oven because one wire to the element is hot and comes straight off L2 the power cord. You could seriously injure yourself or destroy the new part by leaving the range plugged in while you replace this element. Tip: pull out the bottom drawer and you will be able to see the power cord and receptacle in most cases and you can unplug the stove without having to move it. When you have the power removed you only need to remove 2 screws and gently pull the element towards you have the new element sitting on the oven so you can add a wire to it as you remove it from the old one so you won't loose a wire through the back. That is how I do it.
Posted on Feb 02, 2010
I have an electric admiral stove I tried changing the two 30amp fuses for oven but it still doesnt work. Would the problem be the heating element and where does one locate the element??
The oven element has probably failed. Im not sure about your Make of oven but the oven elements are either the coil type which are positioned around the oven fan at the rear of the oven or under the oven floor. The connections for either will be at the back of the oven.
Sep 30, 2015 | Kitchen Ranges
How do I change the oven light in this product
maybe a screw in bulb; you did not give make and or model..
Jul 02, 2015 | Ovens
Need coil for emerson micro wave #mwg915sl
If you are not properly trained in repair of microwave oven changing coils etc can fry you. What you are calling a coil is probably the high voltage transformer. Consider taking it to the shop or replacing it.
Dec 19, 2014 | Emerson Microwave Ovens
Oven coil will not shut off after i turn off the oven. any help would be appreciated
POSSIBLE PROBLEM WITH THE SWITCH. TAKE MODEL NUMBER TO AN APPLIANCE DEALER. CHANGE OUT SWITCH. best way is to go wire for wire as an oven switch has at least eight wires.
Nov 10, 2013 | Ovens
How to change coils on the oven for concept 2 series oven
It depends on which concept 2 you have and if the coils are on the top or bottom.
On the most common model, the bottom coils have to be changed the most often.
To do this, unscrew the supporting bracket. Once this is loose, you should be able to rotate the coils upward. Once the coils are up, you should be able to unplug the element.
Once it's unplugged, reverse the process.
Sep 06, 2013 | Computers & Internet
Whirlpool Electric Cook top Coil
there may be 2 screws on the rear/behind of the cooker top or on the front underneath the top when top oven door is open.
Sep 30, 2009 | Hotpoint RGB745 Gas Kitchen Range
Gas oven not reginiting automatically
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jul 18, 2009 | Ovens
Electric coils do not work
Check the connections on the back of the oven feeding the elements. If good, follow back to control switch and check everything there.
Jun 26, 2009 | General Electric Stove/Oven/Range Chrome...
Maytag glass top stove
Hello, open the oven door and stick your head as if into the oven...look up and you will see screws securing the top. Remove the screws and raise the stovetop. The burners are now visible. All that is required is to unscrew the support for the burner and pull the coil out of the socket. Installation is the reverse of removal.
Oct 01, 2008 | Ovens
Maytag MER5775Q Electric Kitchen Range Logo
122 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
