Question about Acer Aspire One Netbook 8.9" Notebook
Power wont go on
Battery is new, power cord is good, but the power button does not turn on the computer?
  • 3 Answers
You need to flash the bios its the only thing that will work. I had this problem, i just googled how to flash this laptops bios, did it up and it worked
Posted on Feb 04, 2010
The power button wont turn off my laptop
Try disconnecting the power cord from the laptop or the wall outlet, if you have a removal battery, remove it and then hold the power button down for as long as it takes for the laptop to power off.
May 04, 2014 | Gateway Computers & Internet
Wont power on
Do you see any sign of power like lights (blinking or not) in the computer?
If there no lights in the computer then do the following.
1. Check the power cord for any signs of damages. Does it still lit?
2. Remove the battery and use the power cord only to turn on your computer. If it turns on, then replace the battery. If it doesn't then replace the power cord.
However, you can also try using a different power cord which is compatible with your computer to make sure that your computer still turns on by using a known good power cord. If it doesn't turn on then get it serviced.
David
Mar 17, 2013 | Samsung Np-rv711-a01us Intel Core I3...
I have Toshiba Satellite A200-1CC. It wont give a sign of life when the power button is pressed. AC power cord with jack are okay, Wall power cords are new. It won't fill the baterry, but when the bat
first try to check if your toshiba is still part of the warranty. if this is good, much better to go to the service center and they will replace the battery pack of your laptop.
Dec 15, 2011 | Toshiba Computers & Internet
Power cord pluged in, turn on computer entered password, screen went black, power on button blinks green instead of steady on, wont do nothing else, what happened, what do i do now?
Unplug the power cord. Remove the battery. Press and hold the power button for 60 seconds then release. Plug the power cord back in but leave the battery out and try to turn it on now. If it comes on you can put your battery back in. If it still does not come on you may need a new power supply/ adapter.
Apr 06, 2011 | Acer Computers & Internet
There is no power from the battery or the adapter and the laptop does not recognise the adapter is plugged in. there are no lights coming on and the power button is doing nothing
Your battery maybe out of charge. Thats why nothing happens when you press the power button. The battery may not be charging because the power cord might not be working. Try another power cord.
Try removing the battery and plugging the power cord and switching on the computer. If its the problem with the power cord the computer wont start. If it starts, the power cord is working fine.
Nov 18, 2010 | Acer Aspire 5920-6727 Notebook
My HP Pavilion M90 monitor won't turn on. Every time I press the on button I hear a clicking sound from the back of the monitor. It sounds like it's trying to power up but it doesn't do anything. Is there...
Hello
Do a hard reset on the laptop by removing all cords and connections from the computer, including the power cord. Turn the computer over and slide the tab next to the battery, then lift the battery out of its compartment.
Eject any SD cards currently inserted in the SD card slot by pressing on them, then remove them from the slot completely. Hold the computer's "Power" button down for at least 15 seconds, then plug the power cord into the computer and turn it on.
Watch to see if the LED lights near the "Caps Lock" and "Num Lock" illuminate. If the lights do not turn on and the computer's screen remains blank, inspect the power cord and AC adapter for damage and replace them if necessary.
Leave the power cord plugged into the computer and snap the battery back into its slot. Allow the computer to sit for at least 30 minutes, then unplug the power cord and press the "Power" button again to see if the computer will turn on.
Plug the power cord back into the computer and try to turn it on again. If the computer turns on, replace the battery with a new one. If the computer still does not turn on, take the computer to a repair shop.
Oct 04, 2010 | HP Pavilion M90 Monitor
The screen wont turn on but the computer is
> try to power drain the computer by pressing the power button while the battery and the power cord is unplugged,removed the battery first and unplugged power cord then press and hold the power button for at least one minute
Jun 27, 2010 | Toshiba Satellite A100-S8111TD Notebook
Model#1825 it wont charge or turn on
Hello :
It seems that the battery is dead [ can't be recharged anymore ] . You need new battery . If you replaced the battery with new one and the device still can't be recharged , then I recommend you to take your player to the service .
You may also check the power transformer or power cord .
good luck .
please rate
Mar 30, 2010 | Toymax Impecca MP-1825 MP3 Player
Computer was fine this morning however I let the battery run flat and now the computer wont start when I connected the power source
Hello there:
What you are going to want to try is first unplug the power cord from the computer and then remove the battery. leave the power and the battery out for 5 min now take some rubbing alcohol and a q tip clean the area that the battery makes contact with really good and also clean the battery terminals it'self. Now press in the power button for 30 seconds and release.
now plug in just the power cord and try to turn on the computer and see if it will now start if so just turn off the computer the normal way and put in the battery and restart the computer and you are done ok ?
Hope this is very helpful for you
Best regards Michael
Dec 31, 2009 | Computers & Internet
Dell inspiron 1526 has problem (plugged in ,not
Hello there:
First you will want to ensure that the power cord is fully inserted at both the laptop and all the connections for the cord and that it is getting proper power. and check tosee that the connector thatthe power cord goes into is not loose if so this will have to be repaired
next remove the battery from the computer and unplug the power cord and then press in the power button for 1 minute than if this has a reset button on the back use a toothpick or a small item and pressin on the reset button for 30 seconds
now insert the power cord (NOT THE BATTERY YET)
and turn on the computer and it should now start up if so insert the battery and leave charge for 1 hour than you should be ok from here ok
Please keep me posted on this so i can assist you if needed.
Best regards michael
Dec 16, 2009 | Dell Inspiron 1526 Laptop
Acer Aspire One Netbook 8.9" Notebook Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
