Question about Dewalt Air Tools & Compressors
DeWalt D55140 appears to be a continuous air leak from around the motor will get up to pressure then leak and tank pressure drops to 50 psi
  • 1388 Answers
SOURCE: No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Posted on Dec 13, 2008
  • 52 Answers
SOURCE: wont pressure up
Most likely your portercable piston ring/seal broke. Its not hard to fix if you are mechanically inclined. See portercable site for rebuild kit.
Posted on Jan 14, 2009
  • 323 Answers
SOURCE: low psi in reserve tank on a dewalt air compressure
This is a fairly common problem in small pancake compressors. I would start by making sure no air is escaping from the condensation drain valve on the bottom of the tank.
Next Pump it up as much as it will hold and turn it off. Listen for air leaks around the fitting on the bottom of the regulator that screws into the tank. These really need teflon tape and to be screwed in well.
Next check the regulator itself. These are rather inexpensive and don't last long when the compressor is used a lot. Also it doesn't take much of a bang when jostled around.
Is the regulator for tank pressure set correctly? Thump the glass covering the dial with your finger. Sometimes it sticks and you'll think it's set correctly when it isn't.
Lastly, check each connection for tightness with teflon tape. If all looks good, gamble about $20 on a new regulator. Odds are that's where the problem lies. This has happened to me a few times.
Posted on May 12, 2009
bozcro
  • 867 Answers
SOURCE: kobalt air compressor will not go above 80PSI
if this is an older or much used unit, cylinder/piston may be worn, unable to push higher psi, which would explain no leaks. if newer unit, seems like regulator unit/valve faulty
Posted on Jul 24, 2009
SOURCE: Was working normal suddenly will not build pressure
Maurader1 an apprentice has this problem solved and is spot on. All these gurus and wiz need to stick to the basic and common sense. The first place your pump will give out after use or abuse is the gasket. All this garbage about defective reeds and defective pressure switch is a lot of nonesense if you first don't rule out the most common problem the head gasket. I'm cheap and this thing has paid for itself 10 time over. You can get a gasket kit for $7, but I fabricated a gasket out of the back of my notebook and sprayed some gasket spray and been working like a charm ever since.
Posted on Jan 04, 2010
Dewalt Emglo 55168 motor starts to slow down as pressure builds to about 30 PSI. It really starts to labor. Any thoughts as to what could be causing the motor to strain and slow?
Most likely in tank check valve is leaking or belt is slipping. Belt tension easy to check, should not deflect with thumb pressure. Check valve should not let air escape out of tank. Easy to check. Run compressor till pressure builds to around 50 psi. Then unplug machine from power outlet. Listen for air leaking out of tank. In bad cases, air will actually leak out of intake filter. Replace check valve as needed. Good luck
Oct 26, 2016 | Dewalt Air Tools & Compressors
How do I stop my compressor from prematurly turning on ?
you can adjust the "cut in" set point to a lower pressure. your pressure switch has a screw that you can turn out to lower the set point.
Dec 09, 2014 | Dewalt D55140 1 Gallon 135 PSI Max, Trim...
Air compressor not unloading
Check the pressure switch. The unloader valve is actually in the pressure switch where the small air line from the tank check valve attaches to it. When the pressure switch turns the motor off it then lets the head pressure bleed off so the motor can restart the next time pressure drops in the tank. If it's not working and bleeding off the head pressure the cold start valve (the one with the pin in it) also won't open so the motor can restart and warn up properly.
Sep 09, 2012 | Dewalt D55153 1.1 HP Continuous 4 Gallon...
Motor "bogs down" at roughly 120 psi...almost stops
You suspect this unit as being a two stage because of the unusually high cut off pressure. It is a single stage and the motor really has a difficult task and is being pushed to the limits. to reach this pressure. We usually reset the pressure to lower setting ~~ say around 140. Your pump probably has a leaking intank check valve (brass fitting at tank) or leaking valve plate in pump. Simple tests : with pressure in tank unplug compressor from outlet and listens for air leak around pressure switch. As you unplug the running compressor from outlet you should hear air leaking from pressure switch for just a moment as air is let out of airline from pump to tank. If air leaks out till zero pressure then change the valve. If tank holds pressure then valve probably ok. Next test, with no air in tank and air filter removed, plug in compressor and feel intake port for strong suction. If the valve plate is bad, suction will decrease as pressure neers the 120 mark till the point of feeling that air is actually blowing out of intake. With good valve plate there will be strong suction untill unit reaches set pressure. If valve plate is bad also change the cylinder and piston ring. Good luck with your repair.
Jul 28, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
How do I adjust the cut-out pressure on my DeWalt D55140 compressor? The relief valve is activating at 140psi before the compressor cuts off.
I had the same problem. The relief valve loosened up after a couple years of use. Right around the center pin in the relief valve is a ring that has a slot in it that you can fit a small straight blade screwdriver into and tighten in a clockwise direction. This should tighten the spring on the relief valve and raise the pop-off pressure above the 150 psi setting of the cutout switch.
Apr 10, 2010 | Dewalt D55140 Heavy Duty 1 Gal, 135 Psi...
I have a model FP209501 Air Compressor 2 Gallon,
2 gallons is small to begin with u need to buy an in line pressure adjuster/regulator their a few bucks and can be attached to the paint gun or line and will keep the pressure at ur adjustment the regulator on the tank sets the tank pressure at 50 so when u us it will let it drop down to about 45 than start up to build the pressure up to 50 than shuts off than repeats it self the inline keeps pressure steady even if tanks are at 200 psi
Jan 18, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Air Tools & Compressors Logo
256 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
