Question about Bosch Axxis WTL 5410 Electric Dryer
WTL 5410 tumbles just fine but just does not heat
  • shelley120 Feb 02, 2010
    yes it is an axxis condensation electric dryer
  • moneysourcek May 11, 2010
    is it electric?
    Novelist:
  • 101 Answers
Hi there, First of all, check to see if your lint trap is cleaned. On this machine, you should do this before and after each load. Also, check the air-inlet / heat exchanger to see if this needs cleaning. It's recommended that it be cleaned 3 to 4 times per year. It's very important to disconnect the power cord before doing this. Make sure to pay attention when removing this, because when you wash and clean it, you have to put it back exactly - or the door won't close. It's not difficult, but maybe writing down the steps on a piece of paper will help when putting it back. Make sure it's completely dry before putting it back in. It sounds like this is most likely the problem, so once cleaned - everything should work fine. Remember, just run water through the heat exchanger, clean it out good, and then let it dry completely before putting it back in. If these solution's don't work, feel free to contact me again. But it sounds like you have your machine in a very well ventilated area, which can also affect the dryer. But this would've happened awhile ago if this was the problem. But the biggest feature and task with this machine is the lint build-up. It's a great machine, and it's very sensitive - which is a good thing, because it will protect your dryer and its longevity. Best of Luck, and I hope you've already had this problem resolved.
Posted on Mar 14, 2010
2 Suggested Answers
  • 51 Answers
SOURCE: WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Posted on Feb 02, 2010
WTL 5410 getting E1 error message. Condenser hose seems unblocked. Pool of water behind the heat exchanger
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
Dado
Jul 02, 2015 | Bosch Dryers
Bosch 5410 Electric Dryer heat issue The dryer tumbles fine, but the heat turns on for about 30 seconds and then stops. If I stop and start again this scenerio is repeated. I have check out the following:...
There is also another overheat module below the front door too. Check that.
Also, forgive me for asking the very obvious, but have you checked the entire exhaust pipe to make sure that there is no restriction that would cause overheating.
Mar 18, 2017 | Bosch Axxis WTL 5410 Electric Dryer
Feb 02, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
My Bosch Axxis WTL 5410 will turn on and spin but no heat comes out of it. I cleaned the heat exchanger and wiped down the moisture sensors inside the drum, but still can't get heat out of it. I've read...
How long have you had the dryer (is it still under Warranty) and do you have the owner's manual and have you looked in it for a solution?
If not then you can contact the manufacturer on line to pose the problem to them.
There may not be a reset button on it at all. If there isn't then it is more than likely the heating element and you will have to replace it.
Oct 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Re-set button location?
you need to remove the back panel the smaller one that covers heater matrix you will find a thermostat with a red reset button on it when you push it it will click and reset however you should find out why this happened before you use it again as it only does this if it overheats.
hope this helps
Jun 29, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Load capacity of WTL 5410
7 kg is the max this is quoted as dry load not wet halfed when wet.
May 30, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL5410 condensation dryer does not heat up
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
May 03, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
144 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
