Question about Tatung Computers & Internet
Tatung mod v32gcgi problem left side of screen ok right side loss of sync or pixel syn loss on right side exactly from center to right.
  • stsj55 Feb 09, 2010
    thanks for your reply remove cover there is only a main module and a switch mode pwr supply. found a leaky cap on pwr supply. replaced it didnt help i agree with you yet there is no visible sign of a problem. also a heat sink was laying in the main board cover the set is a cheap one it was glued on. cant find any technical drawings or information on any of the high def.sets. any help will be appreciated.
  • 644 Answers
It seems to be a problem with the inverter board, some inverters send out the signal in two halfs, signal for right hand of the screen and one for the left, it seems the left side electronics have failed, the only way to look for any blown componants is to take the back cover off and have a little route around to see if you can see anything suspect, the reason i say the left side has failed, is because if you look at the board with the screen face down, the right side of the screen would become the side of the board. have a look and get back to me, the other option is to replace the inverter.
Posted on Feb 02, 2010
  • jimnuggats Feb 09, 2010
    It sounds like the power supply is an inverter/power supply then you have the seperate signal board, check the tops of all the capacitors, if they are slightly domed or pretruding they will need to be changed also. On the the power board have a look for a four legged componant, looks like an ic, its the optoisolater, this may be faulty and also needs to be swapped out. The heatsink that you mentioned may be off the power ic which should stand upright on the board and have about 5-6 legs, you are right though it should be screwed onto the ic not glued, this would just coarse it to overheat and again could be caursing the problem. It is very hard to get hold of schematics for a singal make of monitor, they are generally all the same, just built a different way. hope this is of some help. thanks Jimnuggats
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Block on left side of screen 1 inch from left side from top to bottom
Either your screen is out of sync (go to monitor settings to adjust), or you have a bunch of dead pixels, in which case you need a new monitor.
Nov 24, 2013 | Computers & Internet
When in gmx,letters are too large .How do I set the display back to normal.
right click on the screen then select properties..while on display properties click settings..under the screen resolution, adjust the slider bar to the right until the pixel is 1024x768..adjusting to the right decreases the pixel and to the left increases the pixel.. under the color quality select highest (32 bit)..click apply then OK..when prompted to keep the settings click OK..
Jul 19, 2009 | Acer Computers & Internet
Need to replace power supply for Tatung V32GCGI
Just time and patience. If possible use a pencil iron. A gun is too much heat for the board. If you have the exact replacement be aware how the old one comes out.
Feb 16, 2009 | Tatung V30DMTT 29.6 in. LCD Television
Polaroid monitor picture is shifted to left about an inch
Hi you may try
1)to key the auto(adjust) button at TV monitor keyboard if not ok,
2)to change display pixels density from PC display setting because TV monitor could not support the display pixels you using and sync.the picture on well.
3)also you may adjust monitor screen H position(it maybe not convenience for back TV).
Dec 21, 2008 | Polaroid Computers & Internet
Olympus Stylus 1030SW. The LCD monitor is pixelated. The pictures that are taken with the camera are crisp and perfect. When reviewed on the camera, they are very pixelated. When searching through...
You can try to reset the camera to factory defaults to see if this improves the monitor. You go to Menu and then left arrow to Reset and press Ok. Up arrow to Yes and Press ok this will put the camera back in factory default settings. If the screen still shows as pixelated, you might try to do a function of the camera called Pixel Mapping. Go to Menu and then right arrow to Setup then down arrow to Pixel Mapping - right arrow to Start and then the camera will try to repair the CCD processing chip inside the camera. If after this completes if the screen is still pixelated, then you want to send it to an Olympus service center for repair.
Aug 30, 2008 | Olympus Cameras
Tatung lcd 42
This is a known Tatung Issue. If you still have your warranty, deliver it to the repair shop. They will fix it in a day.. That's what I did
Mar 20, 2008 | Tatung P42BSKT 42 in. HD-Ready Plasma...
Computers & Internet Logo
46 people viewed this question
Top Tatung Computers & Internet Experts
Tony
kj henriksen
kj henriksen
Are you a Tatung Computer and Internet Expert? Answer questions, earn points and help others
