Date change to 2010
I have my vcr connected and since the beginning of the year am unable to change the date to 2010
  • 3 Answers
Need to upgrade software through usb port from file at factory webb site.
Posted on Feb 02, 2010
Dear Expert, I have a problem with my Samsung L100 camera with the time and date. Somehow when I have uploaded the pictures onto my computer it gives the date of the future for example: May 21st 2013....
The date of your pictures is from the date you took it, So, it must be that last year, May 2010, when took those pictures, your camera's date was not set to 2010. You must also know that when a camera's battery is totally drained and stocked for a long time, the date will be reset. So next time make sure that your date is always right on your camera. =)
But here is a good news. You can just change the dates now after downloading it to your computer. Go to the picture you want to change the date, right click on it and choose properties. Click on details, then "date taken" and change it to any date you want.
I hope this helped you.
May 21, 2011 | Samsung L100 Digital Camera
I have a reconditioned VCR HS-521V(IR) and I want to set the date but the year ends at 2009. can I change this date.?
Unfortunately no! the vcr has a built in calender that is limited to the year 2009 that was programmed at the factory. The only way to change this, is reprogramming it with specially equipment.
Apr 08, 2011 | Mitsubishi Televison & Video
My LG KS360 phone has developed a date fault since 1 Jan 2011 whereby it is saying 32/83/2010. I cannot fix it. Please advise.
Noticed the same problem today. The "set date" option wouldn't let me reset the day, month or year to anything sensible. Changed the date format to MM/DD/YYYY (it was previously DD/MM/YYYY). Then it let me set correct month, day and year. Reset the date format back to DD/MM/YYYY and it's still correct (and will now let me change it while in this format). Don't understand it, but seems to have fixed the problem. (Guessing it was something to do with 2009 changing to 2010??). worked for 2011 also.
Jan 02, 2011 | Cell Phones
Purchased in 1996. The date setting does not extend beyond 2010
No only in service can if it posible to reprogramed the EPROM.
Mar 11, 2010 | Televison & Video
I have a Quasar VCR model VH200. Cant set year 10
Set it for the year 1999.Its the same calender as 2010. For 2011 set it for 1994.
Feb 02, 2010 | Quasar Televison & Video
Panasonic vcr will not accept 2010 date? Model #PV-4800
Pick a different year with the days with the same dates,it works.
THANK YOU FOR ASKING
Jan 28, 2010 | Panasonic Televison & Video
Can the date chip be updated in a mitsubishi VCR?
You can work around the problem. Check old calendars for a year where the days and dates correspond to the 2010 calendar. Program that year in your VCR and it will allow you to program recording times. The year 2004 will work.
Jan 23, 2010 | Mitsubishi Televison & Video
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Apr 16, 2009 | Office Equipment & Supplies
Magnavox VCR U095 39760450-can not put in 2009 YR to record
I called Magavox and Matt told me they had no information for my very very old vcr. He suggested that I trick the machine and use a date similar to the current calendar. For instance, today is Monday, January 5th. I went back to 2004 and found the same day and date. I programmed my vcr for 30 minutes to test it out and it worked. If you can't beat it, join it. Hope your vcr works too. Happy new year!
Ilene
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
