Question about Apple Mac mini
Intel iMac: disk does not eject, does not mount, makes no noise
Intel iMac: same situation as spynonu on Jun 08, 2009. disk does not mount, have tried all suggestions (drutil tray eject, right click on mouse, etc) but does not eject. Any more suggestions?? Thanks!
    Guru:
  • 206 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here are some steps I recommend you try to resolve the issue with the disc not ejecting properly. Now you mentioned that you used the drutil tray open command- if that is correct, then for your Mac Mini, that will not work, because that command is for drives with trays only.
In your case, you have slot drive in your Mac Mini so try the command line that I have provided below. It is just a slight modification from what you stated you tried.
-EJECTING DISC USING TERMINAL-
From your Desktop:
•Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
• Locate and open the Terminal application.
• At prompt, type: drutil eject and press the Return key on your keyboard
(NOTE: If you have a CD/DVD drive with a tray, type: drutil tray open press the Return key on your keyboard).
If that procedure with Terminal does not work, there are two applications that you can try:
Disk Utility- You open the application, select the affected disc or the optical drive in the left sidebar window. Then select eject from the top of the Disk Utility menu. See if that work.
iTunes- Simply open the application, and select the eject icon at the bottom of the window.
Last but not least, I did notice you did not mention that you try this procedure:
Reboot your Mac Mini.
As the Mac Mini boots up, hold down all mouse buttons and keep holding them down until (hopefully) the cd ejects.
I am not sure if you have done all of these processes for ejecting your disc, but again these steps were not mentioned in your initial inquiry.
Let me know if these additional steps have helped or if they are in fact redundant.
Regards,
-Mactechtrainer
Posted on Feb 03, 2010
How to get c.d out od a imac stuck
A few ways of doing this
1) restart mac and press down the mouse button after you hear the startup noise
2) if that does not work try opening up disk utility which is located in applications and then in the utilities folder and click on the icon of your disk under the left hand column then go up to eject button and click eject
3) or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
4) Finally what to do is try pick up your imac tilt the
imac to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVD drives in all macs are a bit suspect and if
your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they should replace it free off charge.
Feb 16, 2013 | Computers & Internet
How to force spit CD from drive
2) if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they will replace it free off charge.
If it is out of warranty there is one other way to do it which I have used recently but IT CAN BREAK THE DVD DRIVE (Use it at your own risk), so only use it as a last resort. Get a thin piece of plastic (or credit card) and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag the DVD out.
Hope this helps.
Dec 10, 2012 | Apple 2.16GHz iMac Intel Core 2 Duo...
CD not ejecting
restart mac and hold down the mouse after you hear the startup noise
Hope this helps.
Jul 04, 2010 | Apple 2.16GHz iMac Intel Core 2 Duo...
Blueberry iMac with slot-loading CD rom drive will
It would be very difficult to open up the imac to retrieve the disc as the CD drive is totally enclosed and would probably result in it not be functional after removing the disk. Have a look at the following article on the apple website
http://support.apple.com/kb/HT3007?viewlocale=en_US as it does indicate that the slot loading imac does have a hole for paperclip ejection. You could also try opening up disk utility and and clicking on the icon of your disk under the left hand column then go up to eject button and click eject. Hope this helps.
Nov 12, 2009 | Apple iMac G3, G4 USB Keyboard 9224078
IMac5,1 DVD-R won't eject.
Hope this helps.
Oct 30, 2009 | Computers & Internet
The CD will not eject. this happened after I stopped the burning process after it began
Hope this helps.
Oct 19, 2009 | Apple iMac 24" Desktop
How i eject a stuck cd from a imac
The front of the CD Driver you can see a very small hole…use a safety pin and open it then insert the pin in that hole and push it in that will force the door on the CD to open …Let me know if that work for you and please do not forget to rate my service so I can keep providing this service to everyone and improve on it. God bless
Sep 21, 2009 | Apple iMac G5 Desktop
IMac disk drive ejects audio cds
1) Restart the computer and try again. If that fails, 2) Gently blow canned air into your CD drive slot. If that fails, 3) Bring the unit in for a drive replacement.
Aug 25, 2009 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
Intel iMac won't eject a CD
When you boot up the System, hold down the mouse button (Left click if you have two buttons) and keep it held down. This will eject the disc.
Jun 08, 2009 | Apple Computers & Internet
CD/DVD Drive Doesn't work
Hi, Sorry to hear you are having problems,
One final test to try before declaring the drive dead:
Insert a bootable installation CD or DVD and restart right away. If the system ejects the disk, simply re-insert it as soon as possible after you hear the start up sound and then, immediately press the ( C ) button on your keyboard forcing the Mac to boot from the cd....
If your Mac boots, then the drive is OK it's your system that has a problem.
If the disk is ejected again, then you can declare the drive dead. It is a relatively inexpensive repair and if your Mac is still under warranty, then apple will take care of this no charge.
Good luck
Mar 21, 2009 | Apple iMac G5 Desktop
Apple Mac mini  Logo
616 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
